CybertronPC AMD Sempron 2400+/ 128MB DDR Memory/ 40GB Harddrive/ 52X CD-ROM/ Floppy Drive/ 3D Video/... (873633000002) PC Desktop Logo
Posted on Jan 11, 2009
Hardrive not working
I was testing out a pump for watercooling but didnt turn my computer off before plugging in the pump to the 12V supply and when i did the harddrive stop spinning and i got a blue screen error and now the harddrive will not boot and isnt recognised in the bios any help in getting the harddrive to run for even just a few mins would be great thanx in advance for your replies
  • Gerald Priest May 11, 2010
    Have you tried removing the HD and just hooking it to a 12v supply? You should be able to feel the drive spinning. If it is spinning up, try it in another working computer and see if it gets recognized. If either of these tests fail, you may need to have a professional recover any data from the drive.
  • Anonymous May 11, 2010
    did the watercooling leak ?
Anonymous
Level 1:
  • Contributor 60 Answers
  • Posted on Dec 25, 2009
Anonymous
Contributor
Level 1:
Answers
60
Questions
Helped
23537
Points
82
Try the harddrive in an external case. If that dosent work the board on the drive is fried, and youll have to find an exact harddrive and transfer the board.
1helpful
Proton Gen 2 petrol pump. Not working, no fault codes. What's wrong?
Remove the pump and test it outside the car. Your half second 12v sounds right. When you turn on the ignition switch the voltage to the fuel pump will only be on for about half second but when you crank the engine the voltage going to the fuel pump goes steady
2answers
How to test the electrical system of the generator for free
Ez test to determine if stator wiring is ok. This test works on generators that have two sets of 115v plugs and 220v plug. Use a 12v, 1amp ac power supply ( smaller ac power supply should work ok ). With generator not running, apply 12v to one of the 115v outlet plugs. Now verify 12v output voltage with meter at another 115v outlet on generator. Also verify that there is about twice the voltage at the 220 v outlet plug (should be about 20v - 24v) . If the adjoining 115 v outlet plug has no output or very little voltage or if the 220 volt plug has no output, most likely stator is damaged or breaker is off. If the stator is shorted voltage reading will be very low and power supply will heat up. If stator is open, there will be no voltage at second 115v plug or 220 v plug. If voltage is ok at the other outlet plugs as per test above then most likely problem is with voltage regulator, or brushes not making contact or armature winding open or just needs to be energized. Unplug the 12v power supply after test to prevent it from overheating. Most generators have two 115v windings that together power the 220v plug. When you energize one of the windings with the 12v power supply, the second 115v winding will be energized also and give you a voltage reading about equal to 12v. You will not damage the generator with this small voltage being input thru the plug. Good luck
Back left indicator wont work
Check the ground connection. Then check the supply with a 12v test meter. If there's no supply work back along the harness until you find it. You'll need a wiring diagram, try google images.
85 mustang fuel pump not primeing
See if the oil pressure switch has 3 prongs. If so and it's leaking oil, that may be the problem. I can't recall what year they stopped doing that switch but my '89 had it. Aside from that, check the fuel pump relay. It can click and still not supply power to the pump.
1999 jeep wrangler wiper relay
washer pump dead.
never checked for 12v at pump turned on? (2 man)???????
if 12v there, the fuses are and all is working, easy 5min test.
i can see you didnt test the pump, for power.
pump tests (try with no hydraulic load first)
you removed the pump clean it , connect only the wires,
turn it on , does it spin? buzzzzzzzzz, (simple , no ?) it buzzes.
put it back and no hose connected. does it pump water>?
at its output port (open to the world) no hydraulic load)?/?
yes, then it's good. easy huh? and new pump now, so is.... and was....
conclusion here is the head, or load, is packed up.
not free flowing. # 1 cause, of all bad washers. is this...
for mixing wrong cleaners or other bad things in the tank.
solution:
then clean the hoses and nozzles, and some have an inline
check valve, that clogs.
packed or pinched lines
packed check valves.
packed nozzels
Had leak,had water pump replaced,still leaking Alot from above somewhere..Tightened timing cover didnt work-where is the watercoolant coming from?
timing cover has nothing to do with water, it does not travel thru there. you may need to check upper radiator hose, make sure there is not a crack in the thermostat cover. if that is not the case then there is a crack in the engine block or intake.
1helpful
1987 GMC sierra , no fuel pump power.
The inline fuel pump fuse on the passenger side firewall is good? Are you jumping it with 12 volts at the test lead or the fuse?
Computer dosent turn on..screen is blank with blinking LED
have u tryed
unplug all of your plugs at the back like blow on them like i do to get lil partcals of dust out then plug all back in and mite work or maybee ur power cord is screwed a bit and u mite have to get a new one whats happednd to ur comp happend exactly the same with mine and i screwed with myn for ages and it finaly worked so maybee just try all that n then if that dosent work as drliativ hes a good guy and will help
hes helped me out a few times hes a great guy
Codegen 450w model :200x
Run a jumper wire between your Green wire on your 20/24 port plug that would hook to the mainboard and one of the black wires in the same plug. I would put a pushbutton or switch in between the Green and a Black on that plug. You may need to put a load on the power supply like an old hard drive or a CDROM. Plug your power supply in and you will notice the fan turning. Use your multimeter to test for different voltages on the connectors. You should get +/- 12, 5, 3 Volts.
I just went into my basement and tested this out and it works great.
Enjoy
John
Top Cybertron Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Are you a Cybertron Computer and Internet Expert? Answer questions, earn points and help others
