Asrock motherboard G41m-VS3 coms settings wrong , can't enter setup the keyboard is not-working please help. email me on mcezra1gmail.com
The pc is frozen but can turn the system of and on cant proceed to setup even when i press f2 because keyboard is not working i tried usb and ps nothing is working
  • 5 Answers
SOURCE: windows\system32\config\system
You may need to go into your BIOS and change the settings so the PC boots from the CD, not from the HDD. It should then start up and allow you to reinstall or repair.
Posted on Nov 10, 2007
micromaster
  • 3614 Answers
SOURCE: Intel 945 GCCNL
Clear the CMOS in case of an emergency.
Although the BIOS usually runs without errors, it can become corrupt in rare instances. If you're unable to enter your BIOS, or if you set a system password in the BIOS but forgot it, you might be able to fix the problem by clearing the CMOS memory. On some motherboards, this requires you to turn off and unplug your PC, disconnect the CMOS battery for a few hours, replace the battery, and turn on your PC again. Other motherboards have a CMOS clear jumper pin that you must move to a temporary position and then return it to its original position. Check your motherboard's manual to see which process you'll need to follow.
If a clear jumper pin isn't available and temporarily removing the battery doesn't work, check the motherboard manufacturer's Web site for instructions about resetting the BIOS.
Posted on Feb 14, 2008
SOURCE: Can't enter BIOS setup with F2
One thing that I could suggesg is get a new very nice mother board for about $59.00. You don't want to send a payload to the moon?, do you ?. Well get yourself a nice 2nd hand mother board.
Posted on May 09, 2008
jrod1125420
  • 161 Answers
SOURCE: Bios setting Utility for asrock Motherboard P4VM8
i would set the bios back to default to cure any problems.....to do this the easy way i would take out the battery on the motherboard.....it looks like a watch battery and the numbers on the battery are usually 3023 or 2032.....levae it out for 10 minutes minimum and then instal it again the same way you took it out....thatll clear the bios and reset the settings. try that and tell me what happens.
Posted on Oct 01, 2008
frcs68
  • 1605 Answers
SOURCE: BIOS UPGRADE
what make and model is the PC?
if you have the hard drive cd from the manufacture then you should be able to install it.
you need to hit F6 during bootup, when you install the Windows Xp from a CD watch it very carefully, during the first few seconds. the bootup will ask for additional hard drive driver. that is when you hit F6 and follow the instruction. don't do anything till it ask for it.
Posted on Nov 05, 2008
Beeping black screen
Do you have the manual that came with the motherboard? If you do, it should have a chart indicating what the 3 beeps mean. If not, try INTEL's website. Lots of tech info there. Don't rule out the video or RAM...the problem could be there or several other places.
Sep 01, 2014 | Intel Asrock G41m-vs3 R2.0 Motherboard...
G41M-VS3 USB NOT WORKING
go into bios and enable usb devices. go into device manager and install driver. enable usb ports
Apr 21, 2014 | Asrock Computers & Internet
No audio device installed
VIA high definition audio driver (VT1705 )
ASRock G41M VS3
Jan 10, 2014 | Asrock G41MVS3 Motherboard
Asrock g41m vs3
have you the latest gfx card drivers? have you check the audio out in windows sound options? usually is set to the audio on the motherboard. set it to hdmi audio as default
Oct 25, 2013 | Intel Core2Duo 2.13GHz 1066MHz 2MB S775...
What is the purpose of intel tv wizard in asrock G41M-VS3 motherboard
The Intel TV Wizard is there to assist you in connecting your PC to your TV. It comes with most units that has a Intel Video card or embed Intel video chipset. You may choose to skip this process entirely or follow the steps if you wish to connect your PC to your TV.
Dec 23, 2012 | Intel Asrock G41m-vs3 R2.0 Motherboard...
No VGA output
Hello the drivers site is here:
http://www.asrock.com/mb/overview.asp?cat=Download&Model=G41M-VS3
The manual:
http://www.asrock.com/mb/overview.asp?cat=Manual&Model=G41M-VS3
I think you should drop the onboard graphic and install a better graphic card in the 1 x PCI Express x16 slot on the mainboard.
Check the power supply for any fault.Is it new ???
You can not use the old Power supply because it might have a 20 pin connector this asrock has a 24 pin connector.
Check also you not have used the extenal graphic power connector in the 4 pin 12 + volt on the mainboard.
Check also all your power connections.
Reply me again if you can`t find the fault.
Good luck
Nov 28, 2012 | Asrock G41MVS3 Motherboard
SOUND DRIVER FOR my pc
if your computer came with a motherboard disc the sound drivers could be on it
click start control panel administrive tools computer management device manager scroll to sound
video and game controllers you might see a yellow question exclamation mark? ! or a red X Right click to reinstall drivers
if you dont have a disk with the drivers you will have to download them
http://download.cnet.com/driver-complete-rar/3000-2112_4-210081.html
http://download.cnet.com/1t2xw26-exe/3000-2122_4-120557.html
if these drivers are not right
http://download.cnet.com/2000-20_4.html
on the home page you should see a search tab just type in what you are looking for
IE: motherboard name sound drivers
be precise you might have to try a few times to get it right
hope this helps
Sep 01, 2012 | Intel Asrock G41m-vs3 R2.0 Motherboard...
Second DVI slot not working for Dual Screening
Have a look at the 'Extended Desktop' settings in the Display section of the control panel.
Jun 15, 2012 | Power Color PowerColor AX6850 1GBD5-DH...
Hi, I really need your help, please help me. I get this CMOS Settings Wrong CMOS Memory Size Wrong Press F1 to Run SETUP Press F2 to load default values and continue ... and my keyboard doesn't work ...
press delete during boot up process enter BIOS then f1 for general help then run chkdsk/r/f which will automatically fix any corrupt files on your hard drive
hope this helps good luck
Oct 04, 2010 | Asrock P4I45GV R5 Motherboard
Computers & Internet Logo
156 people viewed this question
David Payne
David Payne
