Question about Panasonic Heating & Cooling
CS-F50 DTE 5 - Fault finding 05 & 06 errors & gas re-fill
Please send me guidance what to do with the above - it's a R410 a gas unit 380 V
SOURCE: Eror code 3-380 System Fault problem
Whenever switchon my Dc12 The mahinc ready within 5 minutes and final stage it shows the eror like "System Fault" error code 3 -380 Switch of your printer and on. How can I solve it.
Posted on Oct 18, 2008
  • 36 Answers
SOURCE: DATE DIFERANCE BETWEEN SELECTED COLOUMN
Are you trying to figure the difference in days between these dates and one single date (Dec. 31, 2008 for example)?
Whatever you're trying to do, here is the formula, assuming you're starting in A1:
Put the first date in the format Day-Month-Year in numbers (Sept. 3 is 03-09-2008)
Then put your other date in B1, in Day-Mo-Yr format (31-12-2008 for Dec. 31, 2008)
In C1 put B1-A1 and that will give you the number of days between those two dates.
Posted on Dec 30, 2008
WRMtech
  • 70 Answers
SOURCE: whirlpool cabrio model wtw6200swz, desplays fault code f50
make sure the basket is "free" floating. F50 is a stalled motor read. This really neds to be serviced by a technician.
Posted on Feb 24, 2009
KudesNIK
  • 22 Answers
SOURCE: Oki error 380
Open the righthandside cover and check for remaining paper there!
Posted on Jul 24, 2009
  • 6 Answers
SOURCE: Programming LX18H for TRUE FILL AND DRAIN
The LX18 series was a compromise machine, the lack of a sump heater causes numerous rinse temperature problems due to it's increased water use (over the sump-heater equipped, fresh water rinse LX30 series).
The LX18H can be reprogrammed for true fill and dump operation. If you still need to do this, please let me know via e-mail or post a reply, otherwise a won't post the long answer!
(I worked for Hobart as a service tech. from 1994 until 1999, and have been independent since then)
Posted on Sep 12, 2009
CO appears on fuel gauge
On your dash the letters CO or CS show in the Distance to Empty (DTE) information center. there is a problem with the fuel level indicating system. Most likely the Fuel level sensor has failed, or is not completely as accurate as it needs to be for the DTE function to work. The fuel level sensor would most likely need replacing. Replacing the sending unit requires removing the fuel tank. If you choose to repair this issue i recommend replacing the fuel pump and strainer while you are there.
Aug 05, 2014 | 1999 Ford Crown Victoria
Problem with whirlpool w/m adp4737
Whirlpool Duet & Duet HT & Kenmore w/110 model prefix Frontload Washer Error Codes-OLDER
  • F/H--No water detected entering machine or Pressure switch trip not detected
  • F/02--Long Drain
  • F/05--Water Temperature Sensor Error
  • F/06--Drive Motor Tachometer Error
  • F/07--Motor Control Unit Error
  • F/09--Overflow Condition
  • F/10--Motor Control Unit (MCU) Heat Sink Thermal Trip
  • F/11--Serial Communication Error
  • F/13--Dispenser Circuit Error
  • F/14--EEPROM Error
  • F/15--Motor Control Unit (MCU) Error
  • Sud--SUDS LOCK (Overdose of Detergent detected during the Wash Cycle)
  • F/dL--Door Lock Error
  • F/dU--Door Unlock Error
Jan 01, 2012 | Washing Machines
De'Longhi DE500P quit working after a couple of seasons. The unit is like new. All lights work, everything seems to be running, but no water is extracted. De'Longhi wants me to send it to Ohio,...
Paul, There are 5 basic, yet solvable reasons for what you described. Please pay particular attention to numbers 1 & 2..
1. The humidity extraction level is set to HIGH. Lower it to 32-35%.
2. Air intake filter is dirty or clogged. Turn unit OFF, & Unplug the
Unit, before removing to inspect & clean it, if necessary. If washed,
allow filter to completely dry before reinstalling. DO NOT operate
the unit without the filter.
3. Obstructed air flow. Maintain a minimum of 12 to 18" of clear air
space around the entire unit.
4. Cooling coils are dirty and need to be cleaned. Use warm water & dish washing liquid to
clean the coils. Rinse and wipe dry. Apply a light coating of WD40 to the coils.
5. Ambient air temperature at floor level is between 40 - 60 degrees.
dehumidifiers do not work well between those temperatures
(Unless, you have a Low Temp Unit). This applies mainly to
where the air temperature at floor level is colder than at shoulder level
in basement applications . Raising the unit up off the floor,
onto a sturdy table, counter top, etc, that can handle the weight
of the unit, plus a full tank of water, will usually resolve this
problem.
If none of the above solves the problem, it may be a case of the compressor needs to be recharged with refrigerant gas or that the humidity condenser sensor has failed. These things usually occur in units that are 5 years old or older. It's rare in a unit younger than that. But, it can happen. Parts are available, but recharging the compressor should be left to the pros.
If you decide to dispose of it. The land fill is not an option. The compressor has refrigerant gas in it and must be disposed of properly. Most cities and counties have drop off sites for this type of appliance.
I hope I was able to help you and thanks for choosing FixYa.
Aug 27, 2011 | DeLonghi DE500P Dehumidifier
Apparently there is a problem with Beko refrigeration manufactured between 2000/2006. Please confirm model number in question.
From Beko:-
"The BEKO frost free fridge freezer models affected were manufactured between January 2000 and October 2006. These have a serial number that begins with either 00, 01, 02, 03, 04, 05 or 06. and this information can be found on a label inside the fridge. Beko is making a free of charge modification to all affected models, this modification takes approximately 30mins.
Other Beko branded models and all Beko frost free fridge freezers manufactured after this date are unaffected.
Affected model numbers:
    • CA 5411 FFS/FFW/FFX
    • CA 7014 FFX
    • CA 7015 FFW/FFS/FFX
    • CDA 539 FS/FW/FX
    • CDA 543 FS/FW/FX
    • CDA 645 FW
    • CDA 647 FS/FW
    • CDA 648 FS/FW
    • CDA 653 FS/FW/FX
    • CDA 659 FS
    • CDA 751 FS/FX
    • CDA 752 FS/FW/FX
    • CS 460 FF/FFS/FFW/FFSD
    • CS 461 FFW/FFS
    • CSA 4706 FFX
    • CSB 4606 FFSD/FFS/FFW"
If you find that your model is listed above and is in the correct model year range then you need to click here for further guidance. There is also a freephone number, but it's swamped by callers. Even if you get through you will receive exactly the same advice as you would from the website links.
If you want to know more about what the actual problem is, then click here.
Please take a moment to rate my answer.
Jul 06, 2011 | Washing Machines
What is the meaning of fault code. error 02. abnormal on my hitachi remote control for cooling unit rpc 5aq5-p
Indoor/outdoor safety device activated. If your unit stops within 5 seconds, indoor coil sensor defective or short of gas/leak. If your indoor works and but out door unit works for just 5minutes and stops means outdoor coil sensor defective or short of gas or leak. find by amps. If less amps than mentioned, is gas leak/short of gas.
Jan 27, 2011 | Heating & Cooling
I have an LG split system air conditioner model number LSZ244VN-4 it is coming up with a fault code of CS after it has been running for approx 5 minutes
There is no CS code. Please read as C5.
Fault Code 05 and 53 (CH05 is displayed at indoor unit, 53 is displayed at outdoor unit)
This fault code indicates a communication error between the indoor and outdoor units; this is usually caused
by wiring errors or condensate pumps connected to the inter-connecting cable.
The communication between the units is a fluctuating DC voltage commonly called a serial signal, it can be
easily lost if the wiring is not done correctly. If there is a communication error fault CH05 will appear within 5
mins of powering up the system.
Testing
• Check Outdoor and Indoor Power Supply Voltages ( 230V ±10% ) and correct as necessary.
• Check for any mis-wiring or loose connections and correct as required.
• Check the resistance between communication line and GND. (Normal: Over 2M).
• If one Indoor unit operates normally Outdoor PCB is generally normal.
Turn on the power and start the indoor unit in cooling, set the temperature to 18ºC; the serial communication
signal will only be present for the first 3 mins of operation.
Set your meter to DC Volts, Test between terminals 5 (Red probe) and 2 or Earth (Black probe) of the outdoor
unit, you should see a fluctuating 0-72 Vdc.
If the Voltage is not present disconnect the terminal 5 cable, test the Voltage between this wire (Red probe)
and 2 or Earth (Black probe), you should see a steady voltage in the range of -0.1 to -10.0 Vdc. If No Voltage
is present either the cable or Indoor PCB must be faulty. This can be determined by checking the voltage
output on the Comms terminal of the Indoor unit, with the Comms wire disconnected. If No Voltage is present
the Indoor PCB must be faulty, if present, cable must be at fault.
Jan 19, 2011 | Heating & Cooling
What supply house sells haier air handlers in Atlanta ga
any 4 tonnes air handler will fit if you respect de gas for the unit if r22 than than r 22 air handler if r410 than r410 air handler you can put r410 air handler if r 22 not avalable but be sure that expension valve is compatible.
Dec 13, 2010 | Haier HC48C1VAR Central Air Conditioner
Gauge will not go above empty
Many of these goes bad since these units are made very cheaply in Mexico for GM
Jan 14, 2010 | 2005 Chevrolet TrailBlazer
Whirlpool Cabrio W10112999
http://www.theworldofwashers.com/2007/06/cabriooasis-f51-error-codes.html
F then 50 flashes when the motor rotor position sensor (RPS)
senses no rotation.
➔ Does basket turn freely? If not, determine cause of friction.
➔ If basket turns freely, see TEST #3, Page 10.
the above link is for code 51, very similar. the quite above is from the PDF manual. I just solved this problem on my machine. turned out it was clothing between the 2 baskets. Others have had bad control boards, or bad sensors
Oct 23, 2008 | Whirlpool Cabrio WTW6600SBK
Fault code or engineers reset for beko washing machine wma 756s serial no 05-100 905-06
please can you send me fault code for beko wma 665 w serial no 05-103296-10 thankyou
Dec 21, 2007 | Washing Machines
Heating & Cooling Logo
Top Panasonic Heating & Cooling Experts
Bill Long
Fotis Papastamatiou
Dennis Boxerman
Are you a Panasonic Heating and Cooling Expert? Answer questions, earn points and help others
