Question about Cameras
My sd card got erased how can if fix it - Cameras
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Cameras Master
  • 102,366 Answers
I assume by "fix" you mean to recover the data you erased.
If you haven't done anything to the card since you erased it, you may be able to recover much of the data. Do a Google search for "data recovery software" and select a program appropriate for your computer and operating system. Put the card into a card reader attached to your computer and run the program.
Posted on Dec 04, 2012
My device is not a cellphone. Its an android but i followed some of your directions.
unmounting allows for safe removal of the sd card from device,meaning when you unmount the device doesn't read the sd card anymore until you remove it and insert again...erase basically formats the sd card
Nov 26, 2015 | Android Cell Phones
I cant mount my sd card in my Kyocera hydro icon. It doesn't recognize that I put one in
CHECK THAT THE SD CARD WORKS WITH A CARD READER AND COMPUTER SD CARDS ARE SO TEMPREMENTAL THEY FAIL ANYTIME .HOPE THIS HELPS :*)
Sep 26, 2014 | Kyocera Hydro Icon - Prepaid Phone Boost...
I cant take pictures because shows the card is full, how can i erase the sd card
You can erase in the camera, or format the SD card. Or open Start Menu, Computer, Click on the SD card, open, select ALL, delete, OR, right click on the SD card, format.
Jan 16, 2013 | Sylvania G-Netbook
How to recover erased images from sd card
It is quite possible to recover the photos no matter deleted, formatted, lost or inaccessible from your sd card. All you need to do first is by trying SD card data recovery software tools.
Note: before those files are recovered, never should you attempt to save more data to the card. better stop using it for a moment. Regards.
Jun 18, 2010 | Vivitar DVR-550 DV Camcorder
SD CARD ERASED
Is it possible to use some data recovery software such as Photo Rescue Pro to recover the files from your memory card?
Apr 26, 2009 | GPS
Card Error
please check the following: Always choose reliable quality SD Cards. Toshiba Digital Cameras are tested for maximum performance with Toshiba SD Cards, Delkin SD Cards and Panasonic SD Cards. These are leading brands in the development of standard SD technology. Performance by other brands of SD cards may vary. Check the LOCK switch on the SD Card. The camera can not save images to an SD Card when it is in the lock protected position. If the SD Card is NEW, it may be necessary to FORMAT the card. This only applies to NEW SD Cards. If you format a card with images, all images will be erased. You can FORMAT your card periodically to maximize capacity and erase 'unseen' files, please be sure to download all images before choosing FORMAT as all images will be erased. Your Toshiba Digital Camera is designed for use with SD Cards. MultiMedia Cards are similar in size and shape to SD Cards, although with close inspection you will find that SD Cards have a different 'PIN" connection configuration, are slightly thicker in size, and have a manual slide LOCK switch on the side. Toshiba Digital Cameras are not designed or guaranteed to accept MultiMedia Cards. Please be sure to look for SD Cards from Toshiba, Panasonic and Delkin, the leaders in SD Card Technology.
Sep 11, 2005 | Toshiba Sora PDR-T20 Digital Camera
Card Error message
1. Always choose reliable quality SD Cards. Toshiba Digital Cameras are tested for maximum performance with Toshiba SD Cards, Delkin SD Cards and Panasonic SD Cards. These are leading brands in the development of standard SD technology. Performance by other brands of SD cards may vary. 2. Check the LOCK switch on the SD Card. The camera can not save images to an SD Card when it is in the lock protected position. 3. If the SD Card is NEW, it may be necessary to FORMAT the card. This only applies to NEW SD Cards. If you format a card with images, all images will be erased. You can FORMAT your card periodically to maximize capacity and erase 'unseen' files, please be sure to download all images before choosing FORMAT as all images will be erased. 4. Your Toshiba Digital Camera is designed for use with SD Cards. MultiMedia Cards are similar in size and shape to SD Cards, although with close inspection you will find that SD Cards have a different 'PIN" connection configuration, are slightly thicker in size, and have a manual slide LOCK switch on the side. Toshiba Digital Cameras are not designed or guaranteed to accept MultiMedia Cards. Please be sure to look for SD Cards from Toshiba, Panasonic and Delkin, the leaders in SD Card Technology.
Sep 11, 2005 | Toshiba PDR-3300 Digital Camera
Card Error Message
1. Always choose reliable quality SD Cards. Toshiba Digital Cameras are tested for maximum performance with Toshiba SD Cards, Delkin SD Cards and Panasonic SD Cards. These are leading brands in the development of standard SD technology. Performance by other brands of SD cards may vary. 2. Check the LOCK switch on the SD Card. The camera can not save images to an SD Card when it is in the lock protected position. 3. If the SD Card is NEW, it may be necessary to FORMAT the card. This only applies to NEW SD Cards. If you format a card with images, all images will be erased. You can FORMAT your card periodically to maximize capacity and erase 'unseen' files, please be sure to download all images before choosing FORMAT as all images will be erased. 4. The Toshiba PDR-3310 is designed for use with SD Cards. MultiMedia Cards are similar in size and shape to SD Cards, although with close inspection you will find that SD Cards have a different 'PIN" connection configuration, are slightly thicker in size, and have a manual slide LOCK switch on the side. The PDR-3310 may work with some MultiMedia Cards, but is not designed or guaranteed to accept MultiMedia Cards. Please be sure to look for SD Cards from Toshiba, Panasonic and Delkin, the leaders in SD Card Technology.
Sep 11, 2005 | Toshiba PDR-3310 Digital Camera
Card Error Message
Sep 11, 2005 | Toshiba PDR-3320 Digital Camera
Card Error
If you should see the warning message "CARD ERROR" in the LCD Display, please check the following: Always choose reliable quality SD Cards. Toshiba Digital Cameras are tested for maximum performance with Toshiba SD Cards, Delkin SD Cards and Panasonic SD Cards. These are leading brands in the development of standard SD technology. Performance by other brands of SD cards may vary. Check the LOCK switch on the SD Card. The camera can not save images to an SD Card when it is in the lock protected position. If the SD Card is NEW, it may be necessary to FORMAT the card. This only applies to NEW SD Cards. If you format a card with images, all images will be erased. You can FORMAT your card periodically to maximize capacity and erase 'unseen' files, please be sure to download all images before choosing FORMAT as all images will be erased. Your Toshiba Digital Camera is designed for use with SD Cards. MultiMedia Cards are similar in size and shape to SD Cards, although with close inspection you will find that SD Cards have a different 'PIN" connection configuration, are slightly thicker in size, and have a manual slide LOCK switch on the side. Toshiba Digital Cameras are not designed or guaranteed to accept MultiMedia Cards. Please be sure to look for SD Cards from Toshiba, Panasonic and Delkin, the leaders in SD Card Technology.
Sep 11, 2005 | Toshiba PDR-2 Digital Camera
Cameras Logo
Top Cameras Experts
Steve
Are you a Camera Expert? Answer questions, earn points and help others
