Question about Samsung RB2155 Bottom Freezer Refrigerator
How to install a water line to a Samsung Refrigerator?
I have attempted to hook water line to a Samsung Refrigerator, model RB195ABBP. There are two lines in the back of this model. A blue tubbing and a white tubbing. The direction say use the white tubbing, but when I hook the water line to the white tubbing, water drips out of the blue tubbing. When I hook the water line to the blue tubbing, nothing happen.
  • Anonymous Mar 14, 2014
    How to hook up a icemaker the main water line under the refrigerator
  • Anonymous Mar 21, 2014
    samsung refrigerator rb195abbp remove back panel in fig
I have a slightly different refrigerator but the same problem. It says white line, but the white line is attached to the fridge on both ends and the blue line is not. Also the instructions do not actually look like the refrigerator so that is no help. No probelm installing a filter or the waterline to my water, but now I can't get it into the fridge.
Posted on Jul 10, 2010
    New Friend:
The blue line is for the water line,the white is coming out the bottom where the blue on goes.Theres a cover about 18 inches up on the refrigerator,theres a connection there,thats where the white on goes.If its not hooked up it probably was knocked off during transport.
Posted on Apr 10, 2013
Water dispenser not working GE model GSH25JSX13
Do you hear a slight buzzing when you try to get water?? If yes, you may have a frozen water line inside the freezer door. GE had some problems with those models. They offer a heater kit that has to be installed in the dispenser area of the freezer door. Once installed, in about a day the water line should be defrosted enough to dispense water again. If you don't hear that buzzing sound when trying to get water, you could have a bad inlet valve which is at the lower back of the refrigerator where your house water line hook to the refrigerator.
Mar 04, 2015 | GE Refrigerators
GE GSL25IGXB LS refrigerator. No water from front dispenser.Ice making works. Filter is good. Any suggestions?
Samsung Refrigerator water dispenser does not work? Ice maker works
The electrically operated valve that opens when you attempt to get water is probably bad. This unit may have one unit with two valves. One each for the ice maker and water dispenser. This valve unit will be in the back of the refrigerator and have a copper or plastic supply line from your house. This line will be "live" so be sure and find and close the valve attached to your house's water supply.
Mar 02, 2015 | Samsung Refrigerators
How to install water line to a samung refrigerator
One line hooks to the water supply, the other line hooks to the ice maker. How old is refig?
May 08, 2012 | Samsung RB195ACWP Bottom Freezer...
Replaced DA29-00003B water filter in Samsung Refrigerator (RS2530BBP), with DA29-00003G filter. Water comes out extremely slowly....any suggestions? Tried holding ice type button for 3 seconds and...
Recheck you steps and see the warnings:
1) Turn on the main water supply & shut-off valve of the water
supply line.
2) Run water through the dispenser until the water runs clear
(6~7 minutes). This will clean the water supply system and
clear air from the lines.
3) Additional flushing may be required in some households.
4) Open the refrigerator door and check if water leaks around
the water filter.
Remove any residual matter inside the water supply line after installing filter.
NOTE :A newly-installed water filter cartridge may cause water to briefly
spurt from the dispenser.
Jun 04, 2011 | Samsung AquaPure DA2900003A Refrigerator...
Should water dispenser work as soon as refrigerator is installed?
Only if it was properly hooked up to the water lines that should be where refrigerator is hooked up.
May 03, 2011 | Samsung RFG297AARS (285 cu ft) Bottom...
My top mount refrigerator is freezing food in the vegetable bins and on the door
This is normally the result of poor air flow movement in the refrigerator but it could also be a control board or sensor problem. There are a couple of things you can try first before replacing any parts. There is a small supply air vent for the bottom meat bin in the bottom of the refrigerator, close this vent off. You can also adjust the controls, set the refrigerator control to a warmer setting usually almost to the warmest and the freezer control to a slightly colder setting. This will keep the unit running longer allowing more air movement. This will usually help solve this problem.
Feb 11, 2011 | Samsung RB195ABBP (187 cu ft) Bottom...
Freezer fan quit working after ice took over (kids kept leaving freezer door open) we defrosted and the temp will not drop below 40 degrees is there a reset to restart the fan?
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
No,
Probably wrecked the fan motor...
Check out these tips...they can help you figure out whats going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
heatman101
Aug 31, 2010 | Samsung RB195ABBP (187 cu ft) Bottom...
Noises and over freezing - Samsung RB195ABBP refrigerator
unless the doors fit perfectly you will have a real problem.so, youve tried the cowboys,now try the indians.....seriously, only pay for a service that has been carried out to your satisfaction,or get someone who can do the job YOU are paying for.
all my collegues do the job, then get paid.
Jul 10, 2010 | Samsung RB195ABBP (187 cu ft) Bottom...
Ice maker hooked up for the first time doesn't work.
Usually it is prudent to unplug the fridge. Yes there may have been water in the line, You could allow the freezer to warm slowly for a few hours, however a warm (not hot) hair dryer will do the job well. PS I do have all 4 refrigeration licenses. Also is the water filter connected and clean, are the solenoids clicking when requested?
Apr 21, 2008 | Samsung RB215LASH
Samsung RB2155 Bottom Freezer Refrigerator Logo
3,674 people viewed this question
Top Samsung Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
