Please help. I have a VR 804 Kenwood. The standby light comes on but no display. I have troubleshooted by pressing the power button with the standby button to reset the microchip but this does not
No display at all. No sound Only on and off works on remote.
    New Friend:
Ahem, the standby light tells you the power supply is fine.
This is the same problem the other poster talked about, and it is affected by heat, but his is not the solution. Over time, as things heat and cool, they expand and contract. Everything does. It is part of physics. Think of the metallic parts in your stereo like you do a paper clip. Bend it back and forth a few times, it work hardens, and breaks.
The soldering points have developed a crack that expands with heat and may re-contact when you first turn on your receiver and the points are closer (colder).
Unplug the receiver, pull the top over, pull the front panel, pull the 3 knobs and remove the front circuit board but do not unhook any wires, Download a service manual for free and start with pin w19 and work your way across the backside of the display with a magnifying glass, or better yet, an opti-visor.
You will see a soldered pin that has a dark outline about midway through the solder. This is a crack. Get a decent soldering iron and re-heat it, or even better, some lead free rosin core electronics solder and add a tiny bit to the post.
Re-assemble and plug it back in. If it doesn't work, then you may have more than one. If all of this doesn't work, then take it apart and use the parts as an art project.
Posted on Mar 16, 2013
2 Suggested Answers
SOURCE: Reciever wont stay powered on
I fear that there's no easy fix. Sounds like the power supply or the board which controls it is bad. If you're not an electronics repair person, it'll need to go to a repair shop.
Posted on May 04, 2009
How to reset the Kenwood vr-716
Unplug power cord from the wall outlet, then plug it back IN WHILE HOLDING DOWN THE POWER KEY = only for U.s.a and Canada
For other Countries With the power cord plugged in, turn the POWER key
OFF. Then, while holding down the ON/STANDBY
key, press POWER.
Memory back up function
Please note that the following items will be deleted from the unit's
memory if the power cord is disconnected from the AC outlet for
approximately 3 days.
• Power mode. • Distance setting.
• Input selector settings. • Input mode setting.
• Picture output. • Midnight mode setting.
• Speaker ON/OFF. • PRO LOGIC II mode setting.
• Volume level. • Broadcast band.
• BASS, TREBLE, INPUT level. • Frequency setting.
• Dimmer level. • Preset stations.
• MD/TAPE settings. • Tuning mode.
• Listen mode setting. • CINEMA EQ ON/OFF.
• Speaker settings. • LOUDNESS ON/OFF.
• SW RE-MIX ON/OFF.
Cautions
MODEL PARTS # REMOTE CONTROL # DESTINATION
VR-705-SA A70-1612-05 RC-R0626 K1P1
VR-707A A70-1617-05 RC-R0824 K2P2
VR-716A A70-1617-05 RC-R0824 K4P4
REMOTE CONTROL vs MODEL
DIFFERENT POINT
ACCESSORIES / CAUTIONS
Model Service Manual Surround Display Sub
VR-705 B51-5840-00 X09-6740-10 -
VR-705-SA - X09-6740-11 X25-6600-10
VR-707 B51-5840-00 X09-6750-12 X25-6520-12
VR-707A - X09-6750-14 X25-6610-10
VR-716 B51-5840-00 X09-6750-11 -
VR-716A - X09-6750-13 X25-6600-10
Note:
A different information will be available from this service manual. Pls refer to original service manual(B51-5840-00), too
Nov 13, 2016 | Kenwood Audio Players & Recorders
Kenwood vr 207 push power button goes into standby with flashing power lite
Same thing just happened to me the other day....I'm thinking it an internal fuse/surge!?
Aug 28, 2010 | Kenwood VR-207 Receiver
What universal code to use with the VR-615 on dish network remote
We would be happy to help with that. Here is a list of someof the codes that we have for your Kenwood Receiver: 774, 795, 668, 691, 728, and 745.
Press and hold the AUX mode button until all mode buttons at the top of theremote come on, then release. Enter the number 2 then one of the codes for your Kenwood Receiver provided above. Press the pound (#) button, the mode light should flashthree times. Check that the code works by trying several different functions onthe remote to make sure it will properly operate your Kenwood Receiver. Keep in mindthat some codes may not be compatible with your equipment. If this is the case,please try the other codes listed for that device until you find one that iscompatible with your equipment.
We hope this helps you, and thank you for being a valued DISH Network Customer!
Phillip Chang
DISH Network Customer Service Representative
May 13, 2010 | Kenwood VR615 Receiver
Kenwood A-85 amp has standby light on but doesn't come on
is your Kenwood A-85 still there? if it's already broken, pls sell it to me as scrap, i will pay you via wire transfer... please reach me at roger12082002@yahoo.com. thank you.
Jun 23, 2009 | Onkyo TX-SV535 Receiver
May 02, 2009 | Audio Players & Recorders
Audio Receiver shutting off
check your speaker connections you have a short or wires touching eachother
Mar 14, 2009 | Kenwood VR-406 Receiver
Receiver standby light,no power
WOOHOO!! I fixed this issue... same problem as everyone else has mentioned... to reset the Kenwood VR-606 receiver, unplug the unit. Hold the power button down and while holding the power button plug the unit in.
Say a prayer...
Then press the power button.
My display isn't working, but my speakers are working, and that's really all I care about right now... good luck to others!
Jan 18, 2008 | Kenwood VR-606 Receiver
Kenwood VR 208
It works sometimes, mostly the volume bottem
Nov 26, 2007 | Kenwood VR-506 Receiver
81 people viewed this question
 Grubhead
Grubhead
