Question about Yamaha RX-V496 Receiver
Bad left channel on home cinema system
Sound is breaking up on the left channel. have swapped speakers and it's not the speaker. have tried pulling all the connections and replacing. Think maybe it's on the amp?
    Sergeant:
  • 256 Answers
The output transistor is probally shot,
Posted on Dec 04, 2012
SOURCE: Center and surround speakers work, but front right and front left speakers do not put out any sound
I had the same problem. Set the reciever on 6 channel stereo. On this setting, you should be getting the same sound out of each speaker. Isolate which speakers aren't getting sound. Now, on your speaker switch (the A/B button), select A. If that doesn't fix it, select B. If that doesn't fix it, try A and B (if you can on your reciever).
Now, when you switch back to pro-logic, make sure your a/b channel switch is in the position that worked in 6 channel stereo. Yamaha recievers have a memory, and when you switch various modes, it makes auto adjustments based on what you had set in the past.
Hope this helps
Posted on Apr 19, 2009
SOURCE: Speaker imbalance in Yamaha HTR-5630
how do i hook up a yamaha natural sound av receiver htr 5630
Posted on Aug 05, 2009
jse2005
  • 103 Answers
SOURCE: Bass speaker not working
make sure speaker voice coil are still good...continuity checks will confirm this....as far as 6 channel hook up, you need to know what the lowest impedance allowed is from your system and then wire up your speakers in series /parallel to come up with a final impedance that will very closely match the systems minimum output impedance
Posted on Aug 15, 2009
SOURCE: Yamaha RX-550 receiver. Presently, no sound on
This solution helps! I got this unit from a friend and there was no sound from the left channel, and after playing with the input knob, there was sound.
I sprayed alot of electronic cleaner and it worked like magic.
the unit is now in full working mode.
Posted on Mar 22, 2010
SOURCE: Yamaha rx-v2200 sound problem
Hi Zanthena - my Yamaha rx v 2200 is doing exactly the same thing - did you manage to track the problem down? I have had my unit in for repair and the fault occurred again 6 hours after I re-installed it.
Any help would really be appreciated!
Jason.
Posted on Apr 03, 2010
No rear sound in philips home cinema
Sometimes the rear sound or other speakers can accidentally get switched off, when changing sound modes. Check that this has not happened. Most amps have test modes that send out beeps or some other form of noise to the speakers. Try that and see if they are working.
If you can't find anything that has switched them off and there are no beeps on the channel. It could be that the amp that controls the rear channels has failed.
May 16, 2016 | Philips Audio Players & Recorders
When i play dvd i hear background music really clearly and voices are hardly audible - this happens on channel 5.1. if i swap to channel 2. i hear the filmmaker commentary! dvd was working fine until...
sounds like the speakers are out of order and/or maybe 1 or 2 not connected. use a AA battery and "pop" each speaker wire. it's low voltage and amperage so it won't damage your speakers. but the pop will allow you to know exactly what speaker you have and if it's connected. now make sure to put it in the correct spot. i would start with the center channel. sounds like this one's not connected.
please rate if this was helpful!
Apr 12, 2011 | Televison & Video
I have a problem with my samsung ht-up30 home theather system. When i turn it on it only shows "PROTECTION" and turns itself off right after that. How to fix it? Regards!!!
The amplifier has a bad channel, or is bad itself. It is trying to either output too much current or is not putting out enough. If you have multiple speakers wired to one channel, you will either have to change the wiring to series(unit positive to first speaker red, first red to second BLACK, second red to unit negative) or remove on speaker. (If this is the case, then you might want to look at this. It is a tip/rick to place and properly/successfully run three subwoofers, but the main concept can be used on all channels.) If all channels are wired to he correct speaker, then the amp is in fact at fault.
Jun 22, 2010 | Samsung HT-X20 Home Cinema 600W Theater...
No sound from front left channel
Try swapping the connectors for front-left and front-right (just swap right at the back of the amp)
After the swap, does the front-left speaker work, and now the front-right is dead? If so, then it's a problem in the amp.
If not, then the problem is in the wiring and/or the front-left speaker itself.
Post back here with your findings, and we'll troubleshoot whichever part of the system is broken.
Apr 08, 2010 | Onkyo TX-SR605 Receiver
I have an RCA surround sound system for my Big screen. Lately we have horrible static in the main speaker, is the speaker bad? If I unhook it, the rest of the speakers are fine.
Could be bad, swap it with another channel. if the problem is still in the same speaker the speaker is bad. if it still crackels in the other speaker the problem is in the amp.
Dec 30, 2009 | RCA RT2250 System
Sony DAV-SC8. I'm suddenly getting distortion
It sounds like the speakers themselves are the problem rather than the amp.
Although, it would be rare to have overdriven/blown the surrounds.
My suggestion would be to isolate which speakers or channels (on Amp) are at fault.
Swap left and right to see if the problem transfers across.
Sep 13, 2009 | Sony DAV-SC8 System
Left Speaker not working
if you swap the speakers and the dead one moves,than it is the amp that is missing a channel,in your case,it is the speaker.
if you try the good speaker in both speaker outputs,it should work on both to confirm the dead speaker theory.
there may be a broken wire in the speaker from shipping.
Sep 04, 2009 | Bose 3·2·1 II System
No left channel sound
check wiring. if ok, swap speaker channels if ok, swap rca plugs, if ok. Bad channel on amp.
Jun 29, 2009 | Technics SA-DA10N 5.1 Channels Receiver
Speaker Problem
Try swapping the speakers to the opposite channels (left and right) and see if the problem is on the same side. If it is, then you may have a bad channel in your amplifier/receiver.
Jan 11, 2008 | Philips FWP900 System
No sound
Why would the sockets be bad??Is it that you move around the wires and the sound comes and goes?? Most likly it would be the rear channel amp. IC and this is a non consumer serviceable part. Check out the speakers on the front channel by switching the wires. If they come on then you know you have a problem with the rear Amp circuit. Contact a local repair shop and see if they can handle this repair . If not contact 800-211-PANA. Good Luck
Jun 24, 2006 | Panasonic SC-HT900 System
Yamaha RX-V496 Receiver Logo
64 people viewed this question
Top Yamaha Audio Players & Recorders Experts
 Grubhead
Grubhead
Electro Med Services...
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
