Question about Sentry Safe Qe4531 Firesafe Waterresistant Safe
Factory code for century safe - Sentry Safe Qe4531 Firesafe Waterresistant Safe
    Scholar:
  • Sentry Expert
  • 170 Answers
All you have to do is find your owners manual the sentry safe combination was posted in. Unless you locked it the safe as happens all the time. After all that is the safest place for it right. Or you can just call a locksmith service tech with the serial number
Posted on Nov 23, 2013
Mother just past away,luckily safe was open at time,but dont know combo to keypad or we haven't found a key,how do i reset code to sentry10 gunsafe
To reset the combination on a Sentry safe, open the door of the safe, delete the existing codes, press the PROG or P key and enter the factory code. Finally, enter a new five-digit number as per individual preference, which is the new user combination.
It is always prudent to reset the combination on a Sentry safe when the door is open because it prevents the user from being locked out. To open the Sentry safe door, type the five-digit factory code given in the owner's manual. This factory code cannot be altered.
To delete the existing codes on newer models of the safe as of 2015, press the P button. Then, type the factory code and follow it up by inputting "00000" into the safe. On older models of the Sentry safe, press the PROG button and type the factory code two times.
After deleting the existing codes, press the PROG or P key and then enter the factory code once again. Within five seconds, type a new five-digit number, which is the new user code. To verify if the user code is working, retype it and then close the door of the safe. The user code is the primary code for opening the safe, and users can reset it as often as they want too
Mar 21, 2017 | We Home Security
How do I change the combination on SENPL048E sentry portable security safe
Open your Sentry safe by typing the five-digit factory code (found in your owner's manual) on the keypad. It's always a good idea to change your combination while the safe is open, so that you don't inadvertently lock yourself out.
  • Delete any existing codes by pressing the "P" key and entering the factory code, followed by "00000." On older safes, press the "PROG" key and entering your factory code twice to delete old codes.
  • Press the "PROG" or "P" key again on your Sentry safe's keypad.
  • Enter your safe's five-digit factory code.
  • Enter a five-digit code of your choosing within 5 seconds. This is your user code. While the factory code cannot be changed, your user code can be changed as often as you like, and that should be your primary code to open the safe. Only you should know your safe's factory code.
  • Mar 24, 2016 | Home Security
    I have lost the combination for my safe model V330 my model number V330 Sentry safe
    • Open your Sentry safe by typing the five-digit factory code (found in your owner's manual) on the keypad. It's always a good idea to change your combination while the safe is open, so that you don't inadvertently lock yourself out.
    • Retype the user code to verify it is working, and then close the safe.
    Mar 19, 2016 | Sentry FIRE-SAFE Combination Safe DS3431,...
    How can i drill a hole into my keepsafe wall safe to open it?
    Keep the drill motor in the toolbox, you'll likely just ruin the safe.
    Go here instead: https://www.sentrysafe.com/CustomerCare/Lost_Your_Combination
    There are 3 possible ways to unlock and access
    the safe:
    1. Factory code
    (Found on the first page of the factory guide) You can
    always open the safe by entering the pre-set 5-digit
    factory code. This code cannot be deleted.
    2. User code
    If you prefer to employ your own code, you can
    program the safe to open using a 5-digit user code
    of your choice.
    3. User pin
    If you wish to give someone else temporary access
    to the safe, you can program a 5-digit user pin that
    can later be erased.
    Programming the user code
    NOTE: One (1) user code is allowed.
    To add:
    1. Press the Prog key , then enter the 5-digit
    factory code.
    2. Enter the 5-digit user code of your choice.
    To delete:
    1. Press the Prog key.
    2. Enter the 5-digit factory code twice.
    Programming user pin
    NOTE: One (1) user pin is allowed.
    To add:
    1. Press the Prog key 2 times.
    2. Enter your 5-digit user code.
    3. Enter the 5-digit user pin of your choice.
    To delete:
    3. Enter 0, 0, 0, 0, 0.
    NOTE: If your safe does not appear to be working,
    please check batteries before calling Sentry
    Customer Care.
    Jul 26, 2014 | Sentry KeepSafe Combination Fire Safe 12...
    How do I open a sentry s3877 safe when the battery is dead and safe is closed
    The factory code combination to your electronic lock will remain in the memory of the unit - even if the batteries go dead. Any use programmed codes will be lost if the batteries lose power. The Sentry programmed factory code is always your default code.
    If you do not know your factory code, you can follow this link for your combination retrieval:
    http://www.sentrysafeshop.com/Lost-Combination-Sentry-Safe-Combination-p/lost%20combination.htm
    Sep 23, 2012 | Sentry Fireproof Safe
    I WANT TO CHANGE THE FIVE DIGIT FACTORY CODE MODEL S3817
    a1 locksmith Burlingame advised me you can not change the factory code as it is burnt into memory. but you can enter a new user code sentry safe instructions at the bottom of this page
    Sep 18, 2012 | Sentry Fireproof Safe
    Lost factory code for sentry safe model #d8W5840
    did you ever find the factory code? I lost mine also. if you have the factory code for this model please message me on facebook.com/vernhartjr
    Sep 09, 2012 | Sentry Safe Sentry Fire-Safe Combination...
    I have a sentry safe model s0310 i lost my combination but i have the key but it doesnt work how do i open it!
    Hi Juli, if you still have the manual, there is a factory code printed on the beginning page and that code can be used if you forgot your code. The factory code can never be deleted. If you dont have your manual anymore then the only other option is to call the company and they might be able to give you the factory code somehow.
    Sentry Safe Customer Service - 1-800-828-1438
    Feb 12, 2011 | Sentry Fireproof Safe
    Sentry Safe (DSW3607 Model) Won't Open
    I finally ignored the poorly-written instructions for programming a personal code and simply entered the factory code first and then pressed the prog/enter code button.  The safe opened.  The instructions tell you to push the prog/enter code first and then enter the factory code or personal code to open the safe.  Wrong!  Do it my way should this problem happen to you.
    Mar 22, 2009 | Sentry Fireproof Safe
    Sentry Safe Qe4531 Firesafe Waterresistant Safe Logo
    90 people viewed this question
    Top Sentry Home Security Experts
    Jim London
    Jim London
    Computer Repairing
    Computer Repairing
    Joseph Vernice
    Joseph Vernice
    Are you a Sentry Home Security Expert? Answer questions, earn points and help others
