Question about Fellowes DM15C Shredder
Broken.... opened up my PS026 Movitech 6 sheet paper shredded to find one of the plastic gear assemblies totally stripped. I'd love to fix it if you can point me how to get a part for it?
  • hfeldman340 Jan 13, 2009
    I have tried cleaning it many times, It only goes backwards, but sometimes it will go forward for a short time.
    Can I get the phone # of the mfr so that I can call them?
  • 58 Answers
This is how a got my hard to fine gear!
Contact Michael Business Machines for your local dealer 1-800-223-2508
Good luck, Tom
Posted on Mar 27, 2009
Omnitech wont shred papers.
Sounds like its jammed? Have a really close look for staples, paperclips etc stuck in the drive gears or blades
May 19, 2015 | Office Equipment & Supplies
Clear a paper jam on HP 6830
Small plastic gear assembly on the left side of printer acti g as clutch may be damage.The common problem in this model. The assembly body is broken! U can fix it.it's hav 5-6 gears..open from top side.
Feb 13, 2015 | HP Officejet Pro 6830 Wireless...
I have a privay Guard model PS-029/MB and I have a brocken plastic gear, can I find this part online?
I have the same problem. The gear that the motor drive shaft touches has been shredded to pieces. when contacting the second gear. The secondary gear is plastic and absolutely WILL shred itself to pieces over a short lifespan (<5yrs) because metal vs plastic is a losing combination.
Feb 02, 2011 | Techko Identity Guard 6-Sheet Strip Cut...
Should the shredder ever be oiled? if so...where
The frequency of shredder oil applications is determined by a number of factors. First of all cross cut shredders must be oiled more often than strip cut shredders do. A cross cut paper shredder will require regular applications of shredder oil while a strip cut can go for a longer period of time without decreased performance. Secondly, paper shredders that are used more will need more lubrication. A paper shredder under heavy usage will need oil about once every four hours, while one under normal use will only require oil once or twice a month. Most manufacturers recommend oiling the cutters once every 30 minutes of accumulative shredding, but an easy way to remember is just to oil your paper shredder every time you change the bag. The type of material as well as amounts fed at once can also effect performance and lead to the need for oil.
Directions
You should only use specifically designed shredder oil to oil your paper shredder. This oil is designed to lubricate precision heat treated shredder cylinders, and any other lubricant or oil will void the manufacturers warranty. So don't use WD-40 or the like to oil your paper shredder.
Shredder oil can come in both liquid and aerosol varieties. However, the most common is liquid shredder oil.
The first way to oil your shredder is to spray or squirt lubricant into the opening and onto the cutting heads. The oil is packaged in a squeeze bottle and is applied directly onto the cutting head in a fine stream. This is done through the paper entry throat. Take 1-2 seconds to oil from one side of the opening to the other. Turn the machine in reverse for about 10-15 seconds to allow the oil to transfer to all parts of the cutting head. The final step is to shred a few sheets of paper to remove any excess oil.
The other, and perhaps most common, way to oil your paper shredder is illustrated in the image above. Simply spread a small amount of shredder oil onto a piece of paper in a zig-zag type motion. Make sure that you spread the oil over the entire sheet. (NOTE: you don't need to soak the paper in oil, just ensure total and even coverage.) Feed this sheet through the shredder and then operate the machine in the reverse mode for a few seconds. This will make sure the oil is dispersed throughout the shredders cutting cylinders. The final step is to shred a few sheets of paper to remove any excess oil. You may want to repeat this procedure depending on the results, and is recommended for up to three applications to be assured of thorough oiling.
You should oil your cross cut shredder on a regular basis. If you are shredding a small quantity such as only 50 sheets a week or if you are using a small shredder, then you should oil your shredder every other day. If you are shredding a large quantity such as hundreds of sheets, then oil after 30 minutes of usage or after you empty the bag.
Start oiling your paper shredder now. The shredder will run smoother, faster, and put less strain on the overall motor, gears, and bearings.
Dec 16, 2010 | Office Equipment & Supplies
I have a Royal RL170MX shredder. It has started
Try putting some oil on a sheet of paper and then shredding the paper with oil on it.
If that dosn't fix it....take cover off....(with the unit unplugged.) and check plastic gears in drive train.
May 20, 2010 | Royal RL170MX Shredder
When I put paper to shred ,all I get is motor noise but no shredding
Take top cover off and check...normally plastic gears will be stripped ,cracked or broken.
Mar 24, 2010 | Office Equipment & Supplies
Shredder motor runs but won't shred paper. No
If the motor is running do the cutting shafts turn??? if not then unplug and open up the top to see if any gears are broken/stripped; give Royal a call at 1-800-524-0799 for parts and prices once you've located the problem.
Oct 23, 2009 | Royal VF1000MX Shredder
The shredder is making a thumping noise like something is out of whack. Tried lubricant and running back and forth. It still thumps.
Common problems.
Jammed paper.
When sherdding paper that has any type of adheasive or glue, such as junk mail advertisments, the glue gets stuck on the blades.
FIX:
1 - UNPLUG
2 - remove top cover
3 - using a small screwdriver or other pointed small object, carefully clean out
the blade paths of jammed paper. Typically there is a cylinder of blades on the underside that does the shredding.
4 - be careful not to damage or PRY the blades, just enough pressure to get the paper out.
5 - dont use oil or lubricants, they can GUM up the blades.
6 - assemble
Give it a try.
Oct 10, 2009 | Fellowes PS60C-2 Shredder
Paper stuck in the Fellows Paper Shredder
  1. Remove Shredder from paper catcher bin
  2. Remove shredder cover from shredding mechanism assemble (approx. 6 screws on bottom of cover)
  3. Separate shredding mechanism from bottom cover (may have disconnect circuit board from assembly and other wiring from switches , sensors, etc,)
  4. Remove motor gear cover (approx. 4 screws)
  5. Separate shedder main drive gear from motor step up gear by pulling gear out
  6. Turn shredder mechanism up side down to access the cutting blades
  7. Use an adjustable wrench to turn the main drive gear to see stuck paper
  8. Use a needle noise pliers to remove paper shreds
  9. Repeat step 7 and 8 until all shreds are remove and cutting mechanism move smoothly
  10. Reassembly before testing shredder
  11. If you remove only some of the shreds, the motor may seize up and strip the plastic gears from step up gear.
Feb 09, 2009 | Fellowes DM8C Cross-Cut Shredder
My shredder stop shredding. has paper caught in itposted
You must have a stripped gear. Should be a number in op manual. Take the top cover off and look for the broken gear. Call them an order gear.
Aug 30, 2007 | Quartet gbc 6120S Shredder
Fellowes DM15C Shredder Logo
136 people viewed this question
Top Fellowes Office Equipment & Supplies Experts
quennie732
Charles T Nevin
Charles T Nevin
Adorjani Laszlo
Are you a Fellowes Office Equipment and Supply Expert? Answer questions, earn points and help others
