Question about Crosley Refrigerators
Crosley side by side freezer and fridge have ice in bottom
Ice build up in freezer
  • Official Brand Answer
  • 4,342 Answers
Hello - A dirty, cracked, worn or poorly fitted door gasket can allow warm air to enter the unit causing it to have to run longer to remove the warm air. Leaks in the door seal will cause freezer to run longer in order to maintain desired temperature. Cleaned the gasket, if it is too damage then it will need to be replace. You can check and see if the door seal is bad by, placing a dollar between the gasket and cabinet. Check to see if the door is being blocked by anything stopping it from closing properly. If nothing is stopping the door then replace gasket. Another possibility is an air leak and the cool air is causing the frost buildup. I suggest contacting a professional to move forward accurately and have them check the coolant system.
Posted on Dec 07, 2012
SOURCE:
aborcass
  • 2651 Answers
SOURCE: Excessive Frost and Ice Build up in Freezer
sounds like you have a clogged defrost drain tube. removing back panel of freezer will give you acess to drain trough, melt away the ice with a hair dryer, youll find a drain hole under there somwhere,pouring boiling water down the drain will clear it pretty quickly( i use a steam machine purchased from the infomercials works awesome, after you clear it and all water drain down tube wrap a piece of solid copper wirearound the heater( black calrod heater right above the drain trough) and stick it in the whole maybe an inch or so. now everythime the heater comes on to defrost it will prevent the hole from freezing over
Posted on Mar 20, 2008
philiptory
SOURCE: FFA 90 ICE BUILD UNDERNEATH THE BOTTOM TRAY
Symptoms:
Ice forms at the bottom of the Hotpoint FFA90 Freezer compartment, below the bottom drawer.
Cause:
The drain hole at the back of the freezer compartment is blocked with ice and sludge.
Solution:
This take about 20 minutes to complete.
1. Tools required:
- 7mm socket spinner.
- Phillips screwdriver.
- Clean damp cloth.
- Electric fan heater (optional, but it makes the job much quicker).
- A length of plastic tubing approx 3 ft (1 metre) long with 5mm bore (optional).
- A few inches of fairly stiff but flexible, insulated wire. I used a piece of yellow/green earth wire.
- A torch or inspection lamp.
2. Switch off the fridge and pull out the mains plug.
3. Remove all the freezer drawers. If there is food in them, wrap them in a duvet or something cosy to reduce thawing.
4. Place a shallow tray under the front of the freezer compartment to catch dripping water.
5. Switch the fan heater on to low heat, and let it blow into the freezer compartment from a distance. DO NOT get it too close - a gentle heat is all you need.
6. After a few minutes, use a blunt knife to prise the sheet of ice away from the bottom of the freezer compartment. I managed to lift mine out in one piece! - but it will probably crack into smaller pieces. Mop up as you go.
7. Using the 7mm spinner, remove the 8 self-tapping, hexagonal head screws that fix the back panel inside the freezer compartment. With all the screws removed, ease the panel out gently, pulling from the bottom first. It may stick a bit where ice has stuck to foam rubber inside, so don't pull to fast.
8. Put the panel on your draining board and allow it to thaw out. There will probably be lots of ice stuck to the foam rubber backing. Don't pull the ice off by hand - you may damage the foam.
9. At the back of the freezer compartment, below the chiller tubes, there is a drain hole about 15mm diameter, and this will probably be blocked with ice. Allow the fan heater to continue to thaw the ice in here, mopping up from time to time. Gently ease off any bits of ice with the blunt knife. As the ice thaws, the drain hole will gradually clear.
10. Insert one end of the plastic tube into the drain hole, and blow long and steady through the other. The warmth of your breath will help to thaw the ice in the drainage tube. Keep going until you have cleared about 5cm down.
11. Now use the piece of wire to poke down the hole and clear any further blockage. This should go down about 8-10 cm or so.
OK, that's cleared the drain hole and the drain pipe. Now you have to clear a messy brown sludge from the evaporation tray underneath, at the back.
12. Switch off the fan heater, and pull the fridge freezer away from the wall, so that you have clear access to the back.
13. Vacuum the dust and cobwebs out of the way - you need to see what you're doing!
14. Above the motor is the evaporation tray. Remove the two Phillips screws that fix it to the back of the fridge.
15. You'll need the torch for the next bit. Look between the top of the evaporation tray and the underneath of the freezer compartment. You will see a black, soft plastic tube about 18mm diameter that links the drainage hole with the tray. Use the screwdriver to prise the tube gently upwards and out of the tray. This could be messy with brown sludge.
16. Taking care not to damage or bend the metal pipes, gently remove the evaporation tray. This will probably have a messy brown sludge in parts.
17. Wash the tray clean; it will need a jet of water and a small washing up brush to get this clean.
18. Wipe the black plastic tube clean.
19. Replace the tray. The fiddly bit is getting the black tube back into the corresponding tubular hole in the tray. I had to remove the screw from the bottom left corner of the coolant pipework in order to get my hand in. Bend the black tube double so that the fold is towards you, and ease the end into the tubular hole in the tray; then push the tube down into place.
20. Re-fix the tray and fixing screw for the coolant pipes; then move the fridge freezer back into place.
21. The inner panel should have thawed somewhat. Gently remove any remaining ice and mop it dry. Press the aluminium foil and foam back into place. Wipe both sides clean.
22. Inside the freezer compartment, mop the coolant tubing gently. Mop the circular foam seal around the fan, and press it back into place.
23. Replace the inner panel. DO NOT over tighten the screws, as they are self-tapping into the plastic walls of the freezer compartment, and you might strip the thread.
24. Replace the freezer drawers, and switch on.
You should now be up and running.
I hope this is easy to understand! Good luck.
www.authorgraphic.co.uk
Posted on Nov 12, 2008
  • 111 Answers
SOURCE: ice building up in bottom of freezer of side by side MSD27 Maytag
Your defrost drain tube is clogged up. Remove the ice and look for the top of a drain tube about 3/8-1/2" in diameter. Once the ice is gone, use a meat baster (turkey baster) full off hot water stuck in the top of the drain tube and blast hot water through to clean it out. Do this several times with about 4 cups of hot water so you don't over flow the drain pan and flood the floor
Posted on Dec 20, 2008
appldoctom
  • 311 Answers
SOURCE: amana side-by-side fridge freezer only cold at the bottom
yes the evap fan in the frezer should be running when the compressor is running[it may not for a minute or so as it starts up.Amana's are good for the connectors at the evap fan motor comming apart.the connectors are white and will look like its together but when you pull it will come apart.i would always cut the connector out and use a wire nut so wont happen again.if any other questions please email thru FixYa and i will be glad to help. God bless ,tom
Posted on Jan 30, 2009
Sea Breeze
  • 4655 Answers
SOURCE: Freezer cold- Fridge not. Ice build up on freezer
I really believe your adaptive defrost located inside the fresh food compartment and inside the control panel is defective. It puts your refrigerator on a timely defrost and if defective this problem you listed in your post happens. Yes we may need to also check the defrost heater and defrost thermostat but with my experience with that type of Adaptive Defrost Control is famous for its failure.
ADAPTIVE DEFROST CONTROL Part Number 61005988 You can find it located on two of my websites. Some models like yours came with a Defrost Timer. We will need just look inside the control panel and see for sure. Here is a photo of the Adaptive defrost. If you should need to contact me please send an email or try to answer here. Problem is I don't get notifications when someone comments. [email protected]
Please rate and ask me as much as you like. Thank You, Sea Breeze
Part 61005988
http://appliancepartseast.blogspot.com/
http://servicepartstec.blogspot.com/
Posted on Aug 10, 2009
ICE BUILDS UP IN LIEBHERR FREEZER
Needs a new defrost timer. If ice builds up then you are not defrosting. If you are not defrosting then the t-stat will read the ice and think it is down to temp and shut off.
Mar 23, 2014 | Freezers
Excess water dripping into refrigerator from freezer. I am in the process of defrosting. Ice build up behind freezer back wall. Do I need a new heater or will clearing the ice from drains suffice?
Clearing the ice build up is a good start,the problem though is the drain pan under the coil in the freezer thats iced up is blocked so when the defrost heater comes on and melts the frost from that coil,it the water is collecting in the freezer and in many cases drips into the fresh food compartment,clearing the drain will resolve your leaking/ice build up issue.THE DEFROST HEATER IS GOOD melting the frost in the first place and hence forth that melted frost stays in the freezer and becomec ice.
Gene
Aug 09, 2011 | Roper RT16DKXK Top Freezer Refrigerator
Freezer model EV171NYMS04 we have ice build up on
There is a drain the back of the freezer that is frozen. Your trickle of water comes from the ice that melts off of the refrigeration coils during the defrost cycle. You need to turn off the freezer, then remove the rear cover from the back wall to expose the coils. With a hair dryer, melt all of the ice. You will find a drain under the coils. Melts all of the ice in this drain so water can get out of the freezer. When this drain is clear, you can put everything back together, and your freezer should work normally.
Mar 12, 2010 | Whirlpool 19.6 cu. ft. Upright Freezer...
Subzero freezer has frost/ice build up on the
Check the fan and readjust temperature control to higher. Thanks.
Oct 22, 2009 | Sub-Zero Bottom Freezer Refrigerator
Ice crystals forming on inside front freezer panel
Very possible the door seal is not properly sealed. Warm inflowing air onto a cold coil will cause ice build up at the lid.
Oct 08, 2009 | Kenmore 22.7 cu. ft. / 643 liter Chest...
Kenmore elite - top freezer
if there is ice build up at the back wall of the freezer section, then you have a problem with your defrost cycle. the freezer would not be very cold for the ice maker to work.
it's either your timer, defrost heater or your bi-metal.
tnx 4 using fixya,
drcool
Sep 30, 2008 | Kenmore Refrigerators
Ice build up on bottom of freezer
remove back panel inside freezer. you will see drain tray at bottom with a drain hole in the middle - this is blocked usually with ice. melt off with a hairdryer and follow up with hot water till water flows away freely
Sep 25, 2008 | Maytag MSD2732GR Side by Side Refrigerator
Ice in freezer compartment
Check to see if your drain tube is clear. Sometimes it freezes up at the base of the rear cover in these bottom freezers. Causing an ice dam.
Jun 30, 2008 | LG LFD22860 Stainless Steel Bottom Freezer...
Kenmore refrigerator model 46-66812 ice build up on the bottom shelf of freezer
Had the same problem. I noticed that the fan in the freezer never shut off so I suspected the thermostat. I ordered and installed a new thermostat (about $30 and 15 minutes to install), the fan now cycles correctly and the ice build up is gone.
Mar 21, 2008 | Refrigerators
Refrigerators Logo
171 people viewed this question
Top Crosley Refrigerators Experts
Colin Stickland
Colin Stickland
Marvin
Marvin
john h
Are you a Crosley Refrigerator Expert? Answer questions, earn points and help others
