My Sony 55' inch ergs won't power up. It starts to then shuts down. I've already replaced the bulb. Please help.
    Genius:
  • Televison & ... Master
  • 2,432 Answers
If you replaced the lamp you must need to reset the lamp hours. then if already done but still shut down you must check if no bad or burnt parts at the lamp ballast board. then make sure the fan is working.
Posted on Dec 04, 2012
4 Suggested Answers
SD Tech
  • 14553 Answers
SOURCE: My Sony 55' DLP had a bulb out. I replaced it but now it starts to power up then quits. The light on the front flashes 3 times then repeats. Help
depending on model number most of these it means lamp door not closed---but several the door is warped from heat--a class action suit was settled and ended early this year.
with door off hold it edgewise to see it is not warped---note the plastic peg on the back of the door--it engages a lever when door is in place---what I do is with a Q-tip or something not metal engage the lever and hold it forward---if set now comes on you need to replace the door.
Some models got so hot they melt the door badly.
Posted on Nov 05, 2012
SOURCE: SONY - PFM-500A2WE 16:9 42-inch Plasma fault 22-12
errro codes 12/22 is power suply issue
if you are electronicly handy you can repair for your self if not
that no sense spend any $$$$ on that
sony.com dont stock power suply for thatr old tv
any other cost you more than by new
Posted on Mar 18, 2009
lovejoy91
  • 691 Answers
SOURCE: Sony 55'' lamp indicator flashing
Double check lamp, make sure it's made for your set and not just a replacement. Also look for blown fuses that goes with the lamp.
Posted on Mar 15, 2011
I have a 2006 Sony KDF-55-E2000, just replaced the lamp and housing and now I have a green stripe at the top and a red stripe at the bottom. Is it worth having this set repaired if I do not have an ex
We had the same problem. Let it be and now the tv won't turn on. If I understand correctly from what I've read it's the optical block and they seem to be just as much as a new tv.
Jun 23, 2012 | Sony Grand WEGA KDF55E2000 55" Projection...
55 inch sony wega rainbow issue
Your convegence has gone out. You can get complete kits with instructions from sites such as www.TvRepairKits.com or just the parts from www.ConvergenceChips.com . If you have never done this before i would suggest going the kit route since it includes step by step photo instructions and support.
Mar 05, 2012 | Sony Grand WEGA KF50WE610 50" Rear...
I have had a Kenwood VR-407 reciever for almost 9 years now but it has just started cutting off. The small power/standby light above the power button goes off when I power it up but then it shortly...
If you've already disconnected the speakers then I suspect the fault is internal on the amplifier and the unit is shutting down to protect iteself.
The fault with most amplfiers can normally be traced to blown or leading capacitors (bulge on the top or liquid around base) which can be replaced for little cost if you've got the technical ability and equipment to desolder and resolder components on a PCB.
First thing to do would be to remove the cover and check the capacitors as detailed above.
Jul 23, 2011 | Kenwood VR-407 Receiver
I have a Sony VPL-ES1. After I had moved my beamer from the first to the second floor it won't power on. It's connected to the power well. I've had this problem before but I would like to know...
ensure that the projector goes through the cool down cycle, for example the fans stop running, before you unplug it. Unplugging it will cause it to into power failure mode which will not allow the lamp to turn on until the bulb reaches ambient temperature. it will also extend the life of that very expensive bulb. take the extra time to let it shut down before you unplug it.
Jul 02, 2011 | Sony VPL-ES1 Multimedia Projector
I have a Sony Wega 55 inch for about 6 years. I have replaced the bulb twice before. I just got another bulb in the unit. It now works for awhile. It occasionally is shutting down with the 5 blink code. I...
5 blinks, pause, 5 blinks, etc. means "Lamp driver error" and the probable cause listed is "Lamp driver defect".This is the starting point for a qualified service technician.Even so, the actual problem may be the lamp. Did you install a genuine Sony lamp assembly? These sets are bad for the lamp driver and optical block, which Sony has extended a warranty on these sets due to the mass problems that they have had with them. If you haven't contacted them yet please do so and talk to them about a warranty on your set. Sony tells me that while they extended the warranty through 3/2011, so please hurry on this.
The parts you need run between $225.00 and $315.00 depending on what boards you need. IF Sony won't honor the warranty or at least work with you, you may consider a new set, these will only get more costly to keep repairing. I Believe in Sony, its not all their fault, there were a lot of bad electrical supplies sold to the electronics industry a few years ago and they simply don't last.
Mar 12, 2011 | Sony Grand WEGA KDF-42WE655 42" Rear...
When my sony grand waga 55 inch shuts off on its own what shoild i look at first
If this tv about is 1 1 1/2 years and used about 4 or 5 a day and the projection bulb had not been change,than the projection bulb life is over.First is to change the bulb.
Jun 21, 2010 | Sony Grand WEGA KDF-55WF655 36" Rear...
I have on Sony KDF55E2000. 55 inch projection. Power wont stay on
It is clear symptom that lamp is near to end of its wroking life and tv needs lamp replacement.
Please replace lamp in tv to get it back in business. Lamp replacement procedure would be written in user manual and its easy.
Please buy Sony original lamp for good picture.
Let me know if you have additional question.
Thanks.
Apr 17, 2010 | Sony Grand WEGA KF50WE610 50" Rear...
Bulb keeps going on and off . does that mean the bulb is going bad
If TV shuts off and turns On itself again then yes, bulb in TV is weak and need to be replaced.
Please buy Sony oirignal bulb/ lamp for your TV safety.
Lamp/ bulb replacement procedure would be written in user manual.
Thanks.
Jan 01, 2010 | Sony KDF-E55A20 55 in. LCD Television
Sony Grand Wega kdfe60a20
My 55 inch Grand Wega has developed a blue stripe on the right side approximately 1 inch wide going up about 1/3 of the way up.. Please help..
Nov 13, 2007 | Sony Televison & Video
Open Questions:
Televison & Video Logo
Top Televison & Video Experts
Electro Med Services...
