SOURCE: i have problem my printer hp deskjet f4185,this
Hi Jeje,
The Printer has a fatal error. Please try the below steps, if it didn't work you have to service the printer.
Power Drain:
NVM Reset:
Regards,
Rizwan
SOURCE: HP Deskjet F4185 series says a paper jam error
did your orinter experience a paper jam before?
try to clean inside again maybe there are small paper left inside
i hope this can help
SOURCE: My HP deskjet 2050 all-in-one
Any error messages on the printer digital screen or the desktop? I take it the "The ink is fine" means that there is ink in the cartridges!
Try a test print via the Control Panel> Printers and Faxes> properties > Print test page.
SOURCE: Cannot scan with hp deskjet f4185 because....
Can you print files? If you can , the software is downloaded.Here's the solution if you have downloaded the software...
1st step : Turn on your *HP Deskjet F4185*.
2nd step : Click the Start menu.
3rd step : Click Devices and printers. A new window will appear.
4th step : Then, click the "Fax button ".The window Fax and Scan window will appear.
5th step : On the lower left corner , click "Scan" below the "Fax" button.Scanned documents (if there's any) will appear.
6th step : Click "New scan" button below the "File" button. And your printer will start! Glad to help..
