Question about Toys
Its not turning on,
My power cord was split. i tryed to rewire it ,y self, connected wires wrong now it wont power at all!
    Genius:
  • 2,432 Answers
If you can give a picture or a video so i can give much better solution.
Posted on Dec 04, 2012
Why my juki ddl-555-5, wheneve I turn on the power switch, just run split second then it automatically turns off?
Try swaping the wires that you cut you might have them backward.if that don't doit you might try changing the hole cord to a new one .
Apr 01, 2017 | Juki DDL-8700
How to rewire a GE 75423 electric fan
Four wires coming from base to motor. I need a diagram of which wires connect to the electrical components in the base.
Aug 26, 2012 | Dryers
I just removed the back cabinet of a Whirlpool Duet Dryer and found a dead mouse where the power cord connects to the cabinet. Machine powers up but doesn't turn. I noticed that the neutral spli
if the wire has a metal end on it and its connected to the white wire, or neutral line, then something is wrong and that should connect to something
Jun 05, 2012 | Whirlpool Dryers
My roper dryer won't turn on. i rewired the back to put a new cord on and now it wont start
Here is a tip that will help you with changing your dryer plug.Dryer Cord and Wiring Dryer 3 Wire or 4 Wire
heatman101
Aug 23, 2011 | Roper RES7648E Dryer
Need a power cord for a craig 720p CLC 501
hi there, if you can't purchase a ready to use power cord you can either do a rewiring it by yourself. First you gonna need a flat cord wire ( split it into two )at least 3 meters. 1.25 mm square wire size will do. a 15 ampere plug. Do soldering on each end from the TV AC terminal and to the plug. just make sure you wont short the wire. There you got your self an improvised power cord. Enjoy watching your TV. please rate and vote. good day.
Mar 21, 2011 | Televison & Video
Doesn't print black text. Will print in other colors. New regular black cartidge installed. Have actaully tried two new cartridges.
Perform a power reset Follow these steps to reset the product. Step one: Perform a power reset
  1. Press the Power button (c01602202.gif ) to turn on the product.
  2. With the product turned on, disconnect the power cord from back of the product.
  3. Disconnect the power cord from the wall outlet.
  4. Wait at least 15 seconds.
  5. Connect the power cord into wall outlet.
  6. Connect the power cord to the back of the product.
  7. If the product does not turn on by itself, press the Power button (c01602202.gif ) to turn it on.
  8. Try to print.
Step two: Print a self-test report Print a self-test report. Refer to the section on how to use these solutions at the beginning of this document.
  • If these steps resolved the issue , and the self-test report prints , there is no need to continue troubleshooting.
  • If the issue persists , continue with the next solution.
  • If the self-test report does not print , continue with the next solution. If the self-test prints, then your carriage jam issue is resolved. Connect the USB cable to continue the print job.
Step three: Search for more information If you detect another issue, go to the HP Product Support Home Page, and then search for another document that relates to the issue you are experiencing. Right-click this link, Product Support Home Page , and then click Open in New Window . NOTE: If the page displays in the wrong region or language, click the Region - Language link in the upper right corner of your browser. Then you can select the correct region and language.
Feb 17, 2011 | HP Photosmart D7560 InkJet Printer
Replaced dead power supply computer still dead
hi
most power supplys are protected against faults when they are connected to damaged equipment
so it possibly just protecting its self
disconnect everything from the PSU except your MB
try to turn on
if your pc boots ok
re connect everythng else one thing at a time attempting to boot each time
when it wont boot you have found your fault
Feb 07, 2009 | E-Machines D2046 PC Desktop
Shorted a speaker wire together
Check the fuse. If its not blown rewire the ground to bare metal.  make sure the power wire is the right gauge aand connected right
Jul 16, 2008 | Power Acoustik LT-980/2 Car Audio...
Unit will not turn on
This seems like you have accidently rewired part of your electrics. You may have wired the power wire into the wrong place, and also wired your electric door locks into your accessories. YOU NEED TO BACKTRACK. Find you doorlock wiring and get it back to a constant power supply. Best bet is to wire your power wire of unit to cigarette lighter by splicing the wires or jacking the outlet at the back. Here is a guide to install your stereo. Following those steps and see if you went wrong somewhere.
http://www.ehow.com/how_5829_wire-car-stereo.html
Mar 18, 2008 | JVC KD-G230 CD Player
Toys Logo
29 people viewed this question
Top Toys Experts
Andrew Taylor
Andrew Taylor
ray gallant
Are you a Toy Expert? Answer questions, earn points and help others
