Question about Microsoft Windows XP Professional for PC
"C00d11ba" sound card and sound device not working.
    Guru:
  • 571 Answers
Try checking the driver.
Right Click on "My Computer" > Manage > Device Manager ..
Look for the sound card driver and see if it has an X or a ? mark on it. If it has an X, then you need to reinstall the driver or if it has ? you need to do the same. You can actually search online for the latest driver of your computer.
Posted on Dec 05, 2012
No sound
on board audio... remove all traces of software (uninstall sound card software) remove device (uninstall sound device in device manager)
restart computer, if it finds sound device, install software.... if it doesn't, turn off sound card in CMOS and install daugter card sound board dependant on available expansion slots
Apr 16, 2012 | EliteGroup ECS 945GCT-M/1333 Motherboard -...
Dear Sir or Madam When I want to play a music on my computer , I get this error: "Windows Media Player cannot play the file because there is a problem with your sound device. There might not be a sound...
Yes there is something wrong! The sound card driver is corrupted!
YOu need to check on device manager again. Look for your drivers there.
If you do not see the EXACT NAME of your sound card, then the driver that is installed is a DEFAULT driver made by the os.
Ex: This is a sound card driver name listed in Device manager:
IDT HIGH DEFINISION AUDIO
This is an example of a default sound card driver that will not work well on certain sounds or will not work at all:
LEGACY SOUND DEVICE
Even thought you many not see a yellow question mark (which you should be checking for too just in case)on any of the listings for your hardware, chances are you are still using a default sound card driver due to a corruption to its original sound card driver.
So recheck your device manager and find out the exact name of your original sound card. If there is no match to your exact name of your sound card, then you need to REINSTALL your sound card driver again and you will immediatly see your sound card working again :)
If this does not work, you may have to change your sound card.
Hope this helps :)
Mar 16, 2010 | Intel Motherboard
My sound will not work on dell d360 with XP. I
Open the Control panel
Open the "Sounds and Audio Devices" icon.
Verify the "Place volume icon in the taskbar" checkbox is checked. If this option is not available or is grayed out, skip to the next section of this document.
If you were able to check this box, click ok and close out of this window and the Control Panel.
Double-click the sound icon in the Systray and verify that all the sound volumes are mid-way or higher.
Verify the installed driver settings
Open the Windows Device Manager
Verify there are no conflicts or errors listed anywhere in Device Manager. If conflicts exist skip down to conflicts section.
Verify no other devices are listed. If other devices are listed skip down to other devices section.
Verify that your "Sound, video and game controllers" category is listed, if not skip down to the missing sound card section.
If no conflicts or other devices are listed and your sound card is listed with no conflicts, skip to the next section.
If you are unable to locate additional information about your issue or are unable to resolve the issue, follow the below steps.
Under Sound, Video and game controllers highlight each device and press the delete key to remove the device.
Reboot the computer.
As the computer is booting the system will detect the sound card and any of it's devices and re-install those devices. If prompted for a location of drivers, try pointing it to your sound card CD and/or your Windows CD. If this does not work or is unable to locate the proper files, you will need to get the latest sound drivers from your sound card manufacturer
If you are missing the "Sound, video and game controllers" category in Device Manager, it is likely that the sound card drivers are not installed properly, sound card has been disabled, sound card is bad, or no sound card is available in the computer. First, verify no conflicts or other devices are present in the Device Manager; if these are present it is likely they are the sound card and/or devices causing the sound card not to be detected. Second, verify that the computer has a sound card and/or that the sound card is enabled on the computer.
Feb 24, 2010 | Dell Latitude D600 Notebook
No sound at all. device manager shows device
have you got the right software? have you used device manager to find the problem?
Jul 10, 2009 | Compaq Creative Sound Blaster PCI 128...
Sounds and audio devices not working
Sound and audio device is not working because of the following problems
1.Problem related with sound driver
Solution: Re install the sound driver from u r motherboard CD.If u use PCI sound card install the driver software from the CD given by the vendor
2.Inorder to check u r sound driver related problem.....go to...Device manager....> audio devices.....> if there any Yellow coloured question mark on the sound device problem related with driver software.
3.May u r sound hardware is not working.....if it is on board card then add any PCI sound card and intall the software from the CD u will get the sound
Feb 21, 2009 | Microsoft Windows Vista Ultimate Edition
Sound driver
Missing or lost sound in Windows 95 / 98 / ME / 2K / XP.
Cause:This issue could be caused by any of the below possibilities.
  1. Bad software settings.
  2. Corrupt or missing sound drivers.
  3. Compatibility issues with the operating system and/or other hardware.
  4. Speaker related issues.
  5. Bad or missing sound card.
Solution:Verify software volume control settings
First verify you see a small sound icon sound3.gif in the systray (generally at the bottom right hand corner of your screen). If this icon is missing follow the below section.
Windows XP
  1. Open the Control panel
  2. Open the "Sounds and Audio Devices" icon.
  3. Verify the "Place volume icon in the taskbar" checkbox is checked. If this option is not available or is grayed out, skip to the next section of this document.
  4. If you were able to check this box, click ok and close out of this window and the Control Panel.
  5. Double-click the sound icon in the systray and verify that all the sound volumes are mid-way or higher.
verify the installed driver settings
  1. Open the Windows Device Manager
  2. Verify there are no conflicts or errors listed anywhere in Device Manager. If conflicts exist skip down to conflicts section.
  3. Verify no other devices are listed. If other devices are listed skip down to other devices section.
  4. Verify that your "Sound, video and game controllers" category is listed, if not skip down to the missing sound card section.
  5. If no conflicts or other devices are listed and your sound card is listed with no conflicts, skip to the next section.
Conflicts section
If conflicts exists with your sound card and/or other devices installed in your computer it is likely that either the drivers are not properly installed for that device and/or the sound card and/or other devices are conflicting. If you open the properties of the device that is conflicting and view the properties, additional details about the conflict can be found. Additional information about error codes as well as help with Device Manager can be found on our Device Manager section.
  1. Under Sound, Video and game controllers highlight each device and press the delete key to remove the device.
  2. Reboot the computer.
  3. As the computer is booting the system will detect the sound card and any of it's devices and re-install those devices. If prompted for a location of drivers, try pointing it to your sound card CD and/or your Windows CD. If this does not work or is unable to locate the proper files, you will need to get the latest sound drivers from your sound card manufacturer.
Other devices section
If other devices are listed, it is possible that these other devices could be the sound card or other devices conflicting with the sound card. If any other devices are listed it is recommended you remove those devices, reboot the computer and let Windows redetect the devices.
If this does not work, attempt to determine which device is not being detected and resolve that issue first.
Missing sound card section.
If this is an on-board sound card you can verify that it is enabled in BIOS setup. Additional information on entering the BIOS setup can be found on document CH000192.
If you have no adapters and/or cannot click the down arrow to select the correct adapter, close out of this Window. In Control Panel double-click the System icon / click the Device Manager tab within Device Manager and ensure there are no yellow ! or red X.
If you have either of these on any of your sound devices, attempt to remove everything under Sound Video game controllers and reboot the computer. If after rebooting the computer you still have the same conflicts, double-click on the conflicting device and refer to our Device Manager error code section giving you additional information on the error code you are experiencing.
Verify speaker connections
Verify the speakers settings and speakers are not at fault by running through speaker troubleshooting steps in document CH000034.
Sound card drivers
If you have followed the above recommendations and you are still unable to get the sound card to work, download and install the latest sound card drivers from the computer or sound card manufacturer. A listing of sound card drivers can be found on our sound card driver page.
Dec 26, 2007 | Toshiba Satellite U205 Notebook
PROBLEM IN SOUND DEVICE
What hardware device drivers should be updated? A listing and recommendation of computer hardware device drivers that should be ... A listing of computer sound card drivers can be found on our sound card .
Issues relating to msgrv32 Resource conflict or issue; TSRs or other running programs; Sound driver or sound card issues; Onboard sound or video issue; MIDI device or codec issues
POST troubleshooting steps. Bad or failing hardware device. Connections not connected or connected properly. ... if you press the power button and nothing happens (no lights, no sound.
Good Luck, Please dont for get to Vote/Thank You.
Dec 22, 2007 | Acer TravelMate 2300 Notebook
Multimeadia audio device ? error-no sound
Try this:
Right click on your sound card.
Uninstall it.
Scan for hardware change.
Let windows find driver.
If it cant, put in cd and re-install.
Please let me know how this works for you.
Thanks
Dec 12, 2007 | Computers & Internet
Sound card not detected
The yello esclamation mark signifys you need up dated drivers then it will go again.
Sep 14, 2007 | Ensoniq (6000708) Sound Card
Microsoft Windows XP Professional for PC Logo
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
