Question about AT&T 650530003417 Cordless Phone
AT&T 1487 Cordless phone: the mic is not working after I opened.
I followed the advice given for fixing the touch pad and numbers that did not respond. Now they all work well.
The NEW problem is that the mic has gone bad: when I call someone, I can hear them but they cannot hear me. Is there something wrong with the microphone? Can I fix it?
Thanks, in advance, for help!
  • snyder_peg Jan 13, 2009
    Excuse me, but "Solution #1" is my email about the NEW problem that has developed. That's not a solution.
  • Anonymous Feb 21, 2009
    what's the fix for the touch keypad.. it's great your pohone is working but what did you do?
    Not all buttons on a cordless keypad work
Your fix for the non-operating numbers on the touch pad WORKED! I have now developed another problem which I posted on Jan. 11, 2009.
Thank you for all the help!
Peggy
Posted on Jan 12, 2009
My touchscreen isn't working and now i'm unable to unlock my htc6800....i tried with ****+* but no respond...
the screen is lined with touch pad that makes it respond to touch,that pad is damaged and must be changed.go and buy the touch screen pad,remove the spoilt one to fix the new one.you will have to unscrew the phone
Mar 05, 2011 | HTC PPC-6800 Smartphone
Is it possible to repair the main mic on an enV touch?
Yes it is possible to change the main mic on a lg env touch phone. You will have to disassemble the phone to be able to do so. To do that, You will have to be very careful in order not to disorganize any component in the phone. You will also have to label the steps You took in disassembling the phone in order for You not to be confused in assembling the phone back. If You are not familiar with such activity, i will advice You seek assistance from a friend that is capable of doing such. To disassemble the phone, please follow the steps below:
  1. Turn off the phone,
  2. Remove the battery cover, the sim card and the SD memory card,
  3. Then You remove the four screws You can see around that area,
  4. Use a flat object like a credit card to pry open the phone from the sides, that will take off the back cover of the phone,
  5. Remove the antenna of the phone and unscrew the three (3) screws that are around the top panel area of the phone,
  6. Unhook every ribbon that are connected to the circuit board, they are connected like plug and socket, remove them,
  7. Lift off the green circuit board of the phone,
  8. Pry open the front cover of the phone using a credit card,
  9. There is a small piece of double sided tape on the back of the screen so, using a little force, slide your credit card all the way under the screen in order to release it.
  10. Lift off the screen and take out the plastic covering the main board of the phone,
  11. Then You solder out the mic of the phone, and replace it with a new one,
  12. Fix the board back on and reverse the process to reassemble the phone.
Hope this helped. Thank You for using FixYa!!!
Jan 20, 2011 | LG enV Touch VX11000 Cell Phone
Touch screen not working help me
the touch pad of your phone is faulty it needs to be replaced.
To replace the touch screen, you need to get a new touch pad.
When you purchase the new touch pad,you have to loose the phone to gain access to the faulty touch pad.You will needing a soldering iron to replace the touch pad.
If you do not have the technical know how of fixing the touch pad, i would advice that you give it to an expert so that you will not damage anything further.
Have a nice day.
Mar 15, 2010 | Sony Ericsson P900
Touch pad not responding
We regularly repair such control units for customers nationwide by mail for $39.95 postpaid in about a week or so with a one-year guarantee.
At our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
Feel free to contact me directly (and please remind me of your full model number from the tag on the unit) for more information & help.
William E. Miller, AS-EET
prototech@usa.net
http://www.microwavedisplay.com
Microwave Oven Control Panel Repair Nationwide
Nov 23, 2009 | Whirlpool GH6177XPS Microwave Oven
I installed adobe illustrator but i missed serial number kindly tell me if you know serial number of this tool
1. S/N: 1034-0119-3495-0951-4181-1487
2. S/N: 6546516981691898198496189841
You can use any of these two serial numbers....Hope this will help you...Thank you...
Nov 07, 2009 | Adobe Illustrator CS3 - Windows for PC...
Touch pad/multimedia console
I have the same problem. The onliest thing is that I can't adjust the leds with the volume control center either...
Oct 02, 2009 | Acer Aspire 6920 Notebook PC
No names on called ID
Problems like this generally do point in the Battery direction. I would try it, and see. I recommend BatterySpecialists. We at IdacomUSA buy batteries from them quite often, and I've never been burnt.
Here's a link to the battery you need from their site. For $10 dollars, you can't go wrong.
AT&T 1487 Cordless Phone Battery
Jun 22, 2009 | AT&T 650530003417 Cordless Phone
Touch screen wont work
Have you tried removing the battery and waiting for a minute and replacing it in the phone.
The phone will reboot and possibly your screen will work again.
May 28, 2009 | Samsung Instinct Cell Phone
Laptop's touchpad not working
Please remove the external mouse and press Fn+ESC simultaneously the issue should be resolved.
Thanks.
Mar 01, 2009 | Lenovo IdeaPad Y510 Notebook
AT&T 650530003417 Cordless Phone Logo
232 people viewed this question
Top AT&T Lands Phones Experts
Paul C.
Are you an AT&T Lands Phone Expert? Answer questions, earn points and help others
