Question about Bosch Axxis+ WFR 2460 Front Load Washer
Bosch wfr2460 part number question
I need to know the part number of the rubber bellows that has a ball inside it. It connects the drum to the pump and drain hose. It might be characterized as a drainage part or a hose. (Mine has a hole it in and leaks)
Thanks!
Try repairclinic.com  We were able to find parts for our Bosch WFK2401 washing machine and our Asko dishwasher...they list the part descriptions and show pictures.  It might take a few minutes to sift thru the things but i bet you can find your part.  FYI, shipping has been great...just a day or two to arrive after ordering.
Posted on Jan 24, 2009
F2 error...filter was hardly dirty....pulled pump as it was making a clicking sound...pump looked clean...ran pump by itself and still mad clicking noise like something was stuck in it but I cant get the...
Welcome to FixYa.
I think this is what you're after...
**An "F21" error indicates a blocked drain, faulty pump as you obviously know, but can also be caused by the back-flow ball inside the bellows which connects the tub to the pump.**
**Turn off the breaker at the service panel or unplug the washer from the wall socket...safety first**
There is a large clamp which secures it to the tub, but if you remove it to clean out all the dirt built up inside, make sure you get it good and secure when putting it back.
You'll want to look in this bellows for debris or clothing items such as small socks, undergarments etc. which can obstruct the function of the back flow check ball.
Keep me posted and let me know how it goes and if you require further assistance.
Thanks for choosing FixYa. Please take a moment to rate the solution provided for you here today.
Good luck.
Regards,
Macmarkus :)
Mar 31, 2011 | Whirlpool Duet GHW9150P Front Load Washer
Leaking drain pump
Yes its very semple takes about 20min.
Jul 05, 2010 | Bosch Axxis+ WFR 2460 Front Load Washer
I wouold like to know where the filter is on the Hotpoint Aquariaus WF100
Power off the mains. The filter is located behind the silver plate at the back of the machine at the bottom. Four screws hold it on. Drain out all the water. The filter is inside the big black rubber hose attached between the pump and the main drum. Remove the plastic clip holding it to the pump unit and then the metal cir clip holding it to the main drum. Inside is a white molded cone and a big white ball which floats. You will find a lot of junk here, clean out thoroughly. To refit put white cone back inside just as you found it, at the bottom, fit ball back into the cone. Attach to the bottom to the drum and re-fasten the cir clip. Finally reconnect the gator to the pump unit and tighten the plastic clip. Check out the pump too before reconnecting.
And rate me nice pl for the free help!
Mar 13, 2010 | Hotpoint Aquarius WF000 Front Load Washer
Really bad smell from drum?
Power off the mains. The filter is located behind the silver plate at the back of the machine at the bottom. Four screws hold it on. Drain out all the water. The filter is inside the big black rubber hose attached between the pump and the main drum. Remove the plastic clip holding it to the pump unit and then the metal cir clip holding it to the main drum. Inside is a white molded cone and a big white ball which floats. You will find a lot of junk here, clean out thoroughly. To refit put white cone back inside just as you found it, at the bottom, fit ball back into the cone. Attach to the bottom to the drum and re-fasten the cir clip. Finally reconnect the hose to the pump unit and tighten the plastic clip. Check out the pump too before reconnecting. Being the first time you shd note what you doing, what goes where. You certainly don't need techs for this; and techs who come are useless anyway.
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Pl give me a ‘very helpful’ rating for the free help, thanks!
Mar 08, 2010 | Hotpoint WMA64 Front Load Washer
Bosch wfr2460
The 03 error code is the drain. Disconnect the drain hoses and check for blockages. If no blockage "time" the drain interval. If it's more than 6 minutes it's the pump. Also make sure you're using the correct type of soap so the ball check valve on the bottom of the outer drum isn't getting fouled with excessive suds. Also disconnect the drain hose from your house plumbing and let it free flow on it's own. This will tell you if the block is in your plumbing, and not in the machine. Assuming that your filter is clean.
Pl rate me ‘very helpful’ for the free help!
Dec 01, 2009 | Bosch Axxis+ WFR 2460 Front Load Washer
Drum will not drain
There is a rubber boot from the wash tub to the pump. At the tub end of the rubber boot is a plastic ball slightly larger then a ping pong ball. The space around the ball was plugged with paper towel. The paper towel pieces were removed and the unit reassembled. Access to the rubber boot required removing both the front and back panels.
Apr 28, 2009 | Bosch WFMC2100UC Nexxt Essence Washer
Bosch wfr2460
after ensuring the sump hose and transfer hoses are clear clean out the pressure system to ensure the water wash level is not more than usual, secondly check whether the waste hose is not back filling from a sink u bend and also check the sink u bend for blockages (usually fat).
if all ok start to check the wiring connections from pump to pcb board, if these are ok then there may be a fault on the board. (pumping problems are usually easily solved with the above proceedure, the pcbs are rarely at fault for bosch but you may be the unlucky one !). tony
Aug 22, 2008 | Bosch Axxis+ WFR 2460 Front Load Washer
Will not spin
Check your exit hose spigot, it may be clogged. This is if your filter is all clean. There should be air for passage in the standpipe behind. Your hose should not fit airtight into the standpipe and neither too deep into it. Snaking out your standpipe would be good too.
Rate me pl.....if helped. Click on 'thanks for trying' if not helped, your prob will be back for someone else to solve.
Feb 16, 2008 | Bosch 3.81 cu ft WFMC530 1UC Nexxt 500...
Bosch WFR2460 Leaks
are you sure it only happens in the spin cycle? and is the leak comming from the bottom front of the washer? most front laoders will leak due to a tear in the belows. that is the rubber boot that seals the washer tub to the front panel. if there was a hole or a tear in the bellows it should have a leak inthe wash cycle also. but there are also other possibilitys too.but its strange to only leak in a spin cycle due to the washer is extracting the water and not adding it. so check and see if it leaks in the wash cycle to and get back to me and we can go from there. looking through my training manual i dont see what could cause a leak in just the spin cycle
Aug 04, 2007 | Bosch Axxis+ WFR 2460 Front Load Washer
Bosch Axxis+ WFR 2460 Front Load Washer Logo
78 people viewed this question
Top Bosch Washing Machines Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
