Question about Philips 42PFL3603D/27 42 in. LCD TV
Phillips 42PFL3603D/27 wont turn on
As soon as I plug tv in, the bottom white led temporarily shows, goes away, then the screen flashes really quick, then a zapping sound from the screen as it flash disappears. when i took the back cover of tv off, it looks like every board's led is working for that short moment, but once that one flash occurs when the tv is freshly plugged in, that's all the picture I get. Had ordered a new a/v board & put it in, but tv is still doing the same thing. Need help.
    Top Expert:
  • Philips Master
  • 74,383 Answers
Check the site linked below, and see whether it can help you. Click this link. View it in "Timeslide" or "Flipcard" option, which can be selected from the drop down box menu by the [Sidebar] tag, at the top left corner of the display window. You can also click the [Home] tab to see the latest updates. It will make search easy. There are more than 1350 posts to different brand TVs now. Pull up older posts there or make a search by typing in the brand name of the device in the "Search Box", at the top right of the display window
Posted on Dec 04, 2012
  • 138 Answers
SOURCE: Philips 42PF9630A/37 PLASMA TV
Replace that board the part number is 996500032643. go to www.vancebaldwin.com for the price of the board.
Posted on Aug 20, 2008
SOURCE: magnavox 32mf23id/37 wont tun on
Had the same issue, I replaced two 1200uf caps on the power supply board and now it works fine again. Remember to replace the caps with caps rated for at least 35wvdc.
Posted on Mar 27, 2009
  • 100 Answers
SOURCE: Phillips TV clicking sound, then cuts off
The problem of that is a loose solder on the board..
Posted on Aug 07, 2009
  • 5 Answers
SOURCE: Phillips Flat TV Model 20pf4121\105 (Flashing green led)
I had exactly the same problem When the TV was switched on all I could see was a flashing green light. After cheching the TV internals and not seeing a problem including the power supply unit which looked and checked normal. Here is what I did to get M TV working again.
Disconnect it from the power supply. Hold down all the buttons simultaneously i.e. the on/off, the volume, the programme, menu buttons, all of them simultaneously and Plug it into the power supply again.
Lo and behold My TV jumped back into life after an absence of about 4 weeks.
Try it yourself exactly as above.
Best of luck.
Irishfreethinker
Posted on Sep 22, 2009
  • 5 Answers
SOURCE: Philips 20PF4121 LCD tv no picture but flashing error codes
Best of luck.
Irishfreethinker
Posted on Sep 23, 2009
I cannot find the place to connect power cord into the flat screen. I searched the book on line to go with the model number Philips 42pfl3603d/27 and it wasn't specific. The place where it showed is not...
I've never had this TV but from what I can find on the internet the power connector is either at mid bottom or mid top of the backside. As for the cable it should be shaped like an 8 with one half more box shape. My TV's power connecter is on the very bottom. Wish I could help you more, but without seeing this model this is all I am able to say. Good Luck.
Mar 20, 2014 | Philips 19PFL3403D/27 19 in. LCD TV
Phillips HDTV 42PFL3603D/F7 screen is grey (after phillips power-up logo shows) when plugged in, will not power off, remote led blinks when used, but no change.
These blinks (flashes) are fault indication. By the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit stage inside the TV. Count the blinks occur at one time switch ON, carefully. Do it once again, and make sure about the number of blinks. If the flashes are continious, non-stop, the main system control IC should be suspected. If you wish to get more details, check the site linked here. It has blinking codes detail to many brand TVs. Pull up older posts. http://electronicshelponline.blogspot.com/ Check the site in 'Mosaic' view. It will make search easy.
Jan 07, 2014 | Philips 42PFL3603D/27 42 in. LCD TV
Error message on my LCD
download proper firmware for your model from philips website and complete firmware upgrade. That should solve your problem.
Dec 03, 2009 | Philips 42PFL3603D/27 42 in. LCD TV
Philips 42PFL3603 tv sound but no picture.
Hold a flash light to the screen after it goes off and see if you can see a faint picture. Sounds like your backlight might be cutting off. Repair can be expensive but some of the newer units don't require the entire LCD to be replaced.
Sep 27, 2009 | Philips 42PFL3603D/27 42 in. LCD TV
Screen goes black tv stays on. Turn off and on and TV's fine.
I had this problem on my 42" Philips. Just got it yesterday and worked fine on the tv stand. As soon as I mounted the TV to the wall via wall mount system, I had the exact same issue you did. Figured it out today.
The wall mount was putting pressure against the center of the back of the tv (tv set had a slightly rounded back plate, and the mount was a flat plate). As soon as I put spacers (part of the wall mount hardware set) between the wall mount braket and the tv so there was no contact except at the mounting holes, the tv worked fine.
My theory is the pressure pushed the tv back plate against some board components which caused them to overheat (no air flow); or put pressure on internal connectors. I dont know.
Hope this helps, may not apply to your situation.
Mar 20, 2009 | Philips 42PFL3603D/27 42 in. LCD TV
42PFL3603D/27 TV was dropped or hit and broke the tv screen upper righ corner. Tv works, has spiderweb look on screen
can't be fixed becase the entire panel is broken. it is cheaper to replace, because wit labor, parts, ect it would be to expensive
Jan 22, 2009 | Philips 42PFL3603D/27 42 in. LCD TV
Philips 42PFL3603D/27 42 in. LCD TV Logo
209 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
