Question about Samsung HL-T5076S 50 in. TV
HL-T5076s changes inputs by itself
Tv changes inputs on its on. Tv stuck on cable tv input and side buttons won't work at all.
    Top Expert:
  • Samsung Master
  • 75,178 Answers
The side buttons panel might not get proper voltage. Check it. Replace the side control panel card.
Posted on Dec 04, 2012
  • 155 Answers
SOURCE: can't get pc input to work
One thing you might want to try is altering the screen resolution on you laptop. If you are feeding the TV with a resolution higher than it can handle or in the wrong aspect ratio it is quite possible that it will not display a picture.
Let us know if this helps!
Matt
Posted on Mar 23, 2008
  • 15 Answers
SOURCE: when using component cables(red, green, blue )
The series of the cable should go green red blue into the back. if you put the green in the red and the red into the green it give the TV a red base to go off of for the picture so everything is red. The reason the green cable won't is because it transmits a black and white picture which allows it a nice base to add the green and red to.
Posted on Feb 24, 2010
  • 8457 Answers
SOURCE: HDMI input is not working.
That HDMI port hub,it shorted.It have intermittent problems,it will work sometimes,sometimes not,best just skip that HDMI port hub.I know i have a samsung LCD tv it have 6 HDMI ports hubs,3 AV RCA cables input functions,and a S-Video input cable port.That plenty,so don't care about that HDMI port hub.
Posted on May 01, 2010
dvdcdlaser
  • 1285 Answers
SOURCE: TV started cycling through cable TV input channels
go to menu settings and reset the tv back to factory default
note this will also reset any of your customize features such as clock color fave channels
Posted on Aug 20, 2010
Macklintok
  • 122 Answers
SOURCE: I have a SAMSUNG model HL-T5076S flat screen TV.
Acording to the user manual there is an indicator light that Blinks and turns off when the power is on and lights up
in stand-by mode.
This information can be found on Pages 6 & 7 of the Owner's Instructions wich can be found here:
Posted on Sep 16, 2010
Can't change channels stuck on 4 tried scanning it but it goes back to 4
There could be a few possibilities for this .:
  • Change the "Input" setting on the TV to "AV" or "VIDEO". There is probably an "INPUT" button on the remote.
  • Find the TV/VIDEO mode on your tv or check the back of the cable box where your cables screw into the unit. There is normally a switch to select an output for channel 3 or channel 4. Your's would be on 3. It's just a matter of switching to 4 to make it work on your tv. More info on this here:
  • https://www.google.com/search?q=tv+channel+stuck+on+4&ie=UTF-8&oe=UTF-8&hl=en-us&client=safari
Jan 28, 2016 | Televison & Video
Source changes by itself when watching tv.
Check your buttons on the TV . Sounds like input or source button ( which ever one they call it ) is pushed in & stuck . Only way to make sure would be to disconnect it & see if it still changes inputs .
Jan 12, 2015 | Samsung 46 UN46C7000 3D TV
I have comcast remote and granddaughter turned tv on side panel. Now screen is fuzzy and I can't find remote that came with tv. I get picture back?
Hello Mary and thank you for choosing FixYa today for your online technical support needs.
When you say the TV is FUZZY, do you mean that there is no picture there at all?
It is possible that your grandaughter may have changed the VIDEO INPUT MODE SELECTOR on the TV by accident when she tried to turn it on with the controls on the TV itself.
Most TVs have a button right on the front of the set itself labelled INPUT which allows you to switch between the various input modes. That button should be located right beside the POWER, CHANNEL, and VOLUME buttons on the TV's front panel.
You may simply need to press the INPUT button and select the proper INPUT SOURCE for your Comcast cable box.
The proper INPUT MODE for your particular setup will depend on how your Comcast cable box is connected to your TV. If your cable box is plugged into your TV with an HDMI cable, then make sure your TV INPUT MODE is set to HDMI.
I hope this helps out, and please feel free to comment back to this page with any additional questions or concerns and I will respond back.
If you do need additional help, please be sure to include the exact model number of your TV and of your Comcast cable box as well as how the two are connected.
Good luck and take care.
Joe.
Feb 14, 2012 | Initial DTV-201 20 in. LCD Television
Tv is stuck on Video 1 and the remote is missing.Won't respond to the cable remote except on and off. HELP
Try pressing tv first on your cable remote then the video/source/input button on the cable remote. If there is no button on the television itself to switch video inputs a temporary fix for now is to connect the cable box to the video 1 female parts on your television. Buy the cables to do that if you don't have a spare set lying around. You can purchase a remote for your television with the model number from http://www.replacementremotes.com or even a Sanyo remote from a thrift store should be able to allow you to switch inputs.
Aug 21, 2011 | Sanyo Televison & Video
Can't get "no signal" off
Hey cthaemar, it sounds like it may have been switched off the correct channel. If it is hooked up with a Coaxial cable it will be on channel 3 or 4, and if it is hooked up with an AV cable then it would be on one of the inputs.
If it's channel 3 or 4 try pressing the gray TV button on the remote and changing the channel. If that doesn't work you may need to use the TV's remote or the TV itself.
If it's on an input press the same gray TV button and then try pressing Input. With this you can also try the TV remote or the TV itself to change those if our remote doesn't change it.
Let me know if you have any other questions or concerns!
Tommy Faust
DISH Network
Jul 12, 2011 | DISH Network 322 DTV Receiver
Tv won't switch to "tv"
Your T.V. is programmed to store the last input you've selected. You have to manually switch it back to your T.V. channel input after each time you switch it to HDMI or any other input even when you turn it off. The "Source" or "Input" button on your original T.V. remote will change this.
Jun 24, 2011 | Vizio 42 in. LCD TV
I cant keep my tv turned on after i pushed the rgb button by mistake it keeps on displaying no signal and then it goes off
Turn on the TV again. You need to change the input from RGB back to cable or HDMI or Component or whatever input you have a source for. If you don't know which one, look at the back of the TV and the wires you've got plugged into it.
If it's 1 round coaxial cable, change the input to Cable.
If it's three wires (red, white, and yellow) change the input to A/V.
If it's 5 multicolored wires, change the input to Component.
If it's an HDMI cable, change input to HDMI.
If you cannot change the input before the TV turns itself off, try unplugging the TV from the wall socket for about 10 seconds, and then plugging it back in. If its still on RGB, you're going to have to either find a way to get faster at switching inputs, or find an RGB cable and something to connect it to your TV. This is a last resort however.
Jun 09, 2011 | Televison & Video
Have a Vizio VX37L that when it is turned the
HERE'S THE FIX: I just went through this with my Vizio VX37L. TV is stuck in RGB input. This is the fix.... TV is stuck in RGB input.
(option 1) Power on TV, and press the INPUT button repeatedly and rapidly until you can change to a different input, such as AV.
If that doesn't work, try:
(option 2) With the TV off, press and hold the INPUT button on the side of the TV for about 5 seconds. The TV should power on and the input list will appear. The TV will no longer be locked, and the INPUT button should function properly after that.
Option 2 worked for me!
Jan 24, 2010 | Vizio VX37L Television
No signal
mine did the same thing...it was on rgb...didn't have ability to plug in computer to tv as suggested previously and I kept trying to hit input button on side of tv after turning tv on..didn't work but when I pushed input button before turning on tv when i turned on tv input screen was up and was able to move input to hdmi...everything works now.
Jan 04, 2009 | Vizio L32 32 in. LCD HDTV
Samsung HL-T5076S 50 in. TV Logo
56 people viewed this question
Jerry Greenberg
Jerry Greenberg
