We thought that it needed to be hooked up to the charging wire to charge it and also, at the same time be able to use it but NOTHING happens. It just seems to be dead.
SOURCE: my sony cybershot camera DSC-T70 won't work
hey guys,
would like to give a suggestion...
have you ever tried using another battery? you should always have a spare battery. most probable cause for this is the battery and we will only know if the cause is the battery when you try another battery.
SOURCE: Sony DSC-H7 won't work!!!!!!!!!!!!
If you cannot find a solution to your problem you may want to email [email protected]. He has good advice and good used parts at a fair price.
SOURCE: hI. My Sony Cybershot dsc-w130's
I just replied your question ...
DSC-W130 camera battery doesn't charge via USB.
It has individual battery charger which plugged in AC.
You can see battery charger in user manual.
Thank you.
SOURCE: dead playstation
This could be any of a number of problems try these solutions one of
which may work. If they all fail to work you can contact sony directly
at
http://www.uk.playstation.com/Support/PS3
Hope this helps.
SOURCE: it will not power on. I thought the battery was
Its true because the battery may get completely drained. Use the link below to troubleshoot this problem:
http://www.kb.sony.com/selfservice/microsites/search.do?cmd=displayKC&docType=kc&externalId=C302511
Have you found a solution? I have the same problem!
