Question about Panasonic TH-42PX600U 42 in. Plasma HDTV
Does model th-c42hd18 require only a panasocin wall mount bracket. Seems others do not work
I am not familar with your exact model but my Panasonic TH-42PX600U 42 in. Plasma uses a generic brand wall mount. The first mount I bought would not fit so I returned it and bought a different brand which worked well. Start shopping your local stores (even walmart has a couple of different types to choose from), carefully open the packaging in case you need to return it and see if it will fit the mounting holes on the back of your TV. If it fits on the back of the TV then you should be good to go.
Posted on Jan 16, 2009
I have a used microwave that mounts under a cabinet, Kenmore model 721. It has only two screws to mount through cabinet does it require additional hardware? Seems alot of weight for just two screws.
Kurt,
There is usually a mounting bracket that mounts to the wall and the microwave hooks into that and is held up by the two screws you referred to in your question. Unfortunately, you have not provided enough of the model number for us to look up any info to help you find a new bracket to mount to the wall. Hope this helps!
Feb 22, 2016 | Kenmore Microwave Ovens
WHERE CAN I GET A TILT BRACKET FOR MY PANASONIC PLASMA TV MODEL TH-50PX50U?
Well, the best and cheapest I have found was Walmart. However, most electronic stores like Radio Shack or Best Buy also carry these items.
Jul 13, 2014 | Panasonic Silver Tilt/Tilting Wall Mount...
Panasonic TH-C42HD18 42 In. Plasma TV inputs not working
yes. you find the main board for you panasonic plasma tv from shopjimmy.com.. good luck!
Sep 03, 2012 | Panasonic TH-C42HD18 42 in. Plasma TV
TH-C4HD18
the four holes on rear are for wall mounted bracket, the stand that goes in bottom generally requires the removing of a cover plate which will be about size of the upper part of stand and will be approx four screws, remove cover and stand will slot in and fix with scres/bolts accordingly.
May 05, 2012 | Panasonic TH-C42HD18 42 in. Plasma TV
I have a Panasonic TH-42PZ80U 42" plasma tv I would now like to mount on a wall. I have gotten conflicting information as to whether it is VESA or not. Can you tell me anything about wall mounts for...
Just purchase a mount for 42" and above They come in different styles for your likening and make sure the wall bracket gets mounted into the wall studs and your all set. No major job. I get $150 all day long for those installs.
Nov 26, 2010 | Panasonic Viera TH-42PZ80U Plasma TV
The studs in my wall are 20 inches apart and the wall mount requires them to be 16 inches apart. what do I do?
If I were in that situation I would fabricate a way to mount it using L brackets.
Using at least 2 and up to 4 L brackets of 2" in length I would drill one hole into the stud and the other end can be put in with a drywall anchor or other bolt-anchor type for your wall material.
I believe there are also wall mount types requiring use of only one stud...but don't quote me on it.
Jan 10, 2010 | Televison & Video
Broken glass - 42 panasonic th c42hd18
usually not very cost effective to replace the front screen. id say around 70% of what you paid for the tv.
Jun 03, 2009 | Panasonic Viera TH-42PX80U Plasma TV
How do I remove a plasma panasonic mounted on a wall.
if it is a swing bracket 4 screws on back bracket holding it in need to be removed, if it is flat wall bracket lift strait up the wall to remove.
hope this helps
daniel
Jan 11, 2009 | Panasonic TH-50PX75U Plasma HDTV
Open Questions:
See all Panasonic TH-42PX600U 42 in. Plasma HDTV Questions
Panasonic TH-42PX600U 42 in. Plasma HDTV Logo
225 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
