Question about Denon AVR-1708 Receiver
What will factory reset avr 1709 fix
I am getting snapping popping sounds out of my avr 1709, will resetting the receiver repair this issue
  • dar1 Dec 04, 2012
    when hooked up with rca's pops are gone, still there w fiber optic hookup
    Sergeant:
  • 256 Answers
It will not fix any problems with it, It just sets it back to the way it was before you set it up.
Posted on Dec 05, 2012
    Renaissance:
    An user who is expert in 3 categories / brands.
  • Denon Master
  • 924 Answers
Is this popping noise in one or more channels? As was previously said, a reset will not correct this issue. If you would to discuss a repair, please contact me through my website, audioserviceclinic.com. Thank you.
Posted on Jul 08, 2014
2 Suggested Answers
  • 137 Answers
SOURCE: denon avr -1709 how
SWITCH OFF THE UNIT..PUSH AND HOLD DOWN BOTH SPEAKER A AND SPEAKER B BUTTON WHILE HOLDING DOWN BUTTONS TURN ON MAIN POWER THE DISPLAY WILL FLASH WAIT FOR 3 FLASHES THEN RELEASE. THIS WILL RETURN EVERYTHING BACK TO RFACTORY DEFAULT
Posted on Apr 19, 2010
Denon AVR-3801 lights up,makes rapid clicking noises when amp tries to turn on. Clicking stops but unit doesn't play & sometimes the unit turns off. Occurred after lightning storm. What to do to fix?
Probably damaged by power surge. If you do not have experience diagnosing and repairing electronic circuits as well as having access to schematic diagrams then this is not a repair for you. Failure to replace all damaged components may result in damaging new parts.
Aug 16, 2016 | Denon Avr-3801 7.1 Home Theater Surround 7...
How do I reset my Denon AVR 1709?
with power off - press and hold the "INPUT MODE" & "SPEAKERS" buttons and press power. All display segments should blink. Let go of buttons and reset is complete.
Apr 07, 2015 | Denon Audio Players & Recorders
AVR 3700 no sound
do headphones work with or without speakers attached? does unit light up? Check fuses. If breaker pops, or replacement fuse blows, it needs repair.
Nov 27, 2013 | Harman Kardon AVR 500 Receiver
Denon Receiver keeps switching between H/P input and speakers
The problem may be dust in the headphone jack
http://blog.adamnash.com/2010/10/01/solution-denon-av-receiver-avr-1410790-with-no-sound/
Jun 17, 2012 | Denon AVR-1709 Receiver
I lost the sound on my denen avr-1508 receiver
You may reset your unit to factory default settings. Check user manual.
Oct 20, 2011 | Denon AVR-1508 Receiver
DENON 1709: The sound is OK when STEREO is setting. Using 5.1 STEREO or MUSIC or CINEMA setting all the speakers are working, except Front Right. I check the volume for each speaker and set it up to the...
The Stereo setting does not use any digital processing and likely avoids the decoding board completely. From your description, either the signal is not being decoded properly or the right channel signal path is being interrupted somewhere. Without taking measurements inside the unit, I cannot tell for sure where the problem lies. Careful examination of the processing board is required here. Take the unit to a repair shop for a detailed estimate. Armed with that info, we should be able to guide you through the actual repair.
Dan
May 29, 2011 | Denon AVR-1709 Receiver
I have a Denon AVR-391.Now it is starting to stop functioning. The set will work then after a while I can not operate any of the commands via remote or manually. The set will not turn off nor am I able to...
If you have had this unit for a while I would try vacuuming or blowing it out because it sounds like the issue you are having is due to heat building up in the unit. Also make sure you have adequate airflow around the unit in other words make sure you have at least 2-3 inches of clearance on all sides and nothing sitting on top of the unit.
Apr 11, 2011 | Denon AVR-1709 Receiver
My Denon AVR-1709 was professionally installed. It lasted less than 2 years, then the speakers started popping, then a few days later there is no signal to any of the 5 speakers or subwoofer. same for all...
This is a case where the audio output ic's have failed, you describe a popping sound which is a classic sign of total audio collapse. Since this was a professional installation, I recommend a top of the line audio technician with an estimate in mind.
Jan 07, 2011 | Denon AVR-1709 Receiver
Denon avr -1709 how do i get it reset to factory specs
Mar 21, 2010 | Denon AVR-1708 Receiver
Denon AVR 1804
You need to get the manual and do some reading first. I couldn't find the AVR-1804 but the AVR-1803 is avaiable. It should be close enough to get you through connection and setup.
Register with retrevo.com and download it for free.
Feb 23, 2010 | Denon AVR-1804 Receiver
Denon AVR-1708 Receiver Logo
318 people viewed this question
Top Denon Audio Players & Recorders Experts
 Grubhead
Grubhead
Electro Med Services...
Are you a Denon Audio Player and Recorder Expert? Answer questions, earn points and help others
