Question about Haier Black and Decker 2.7 Cu. Ft. Refurbished Refrigerator
Is it possible to repair a small puncture in the freon line inside a small fridge
Accidentally put a small puncture hole on the underneath side of the freezer cube
  • Anonymous Mar 23, 2014
    See above
  • Haier Master
  • 4,655 Answers
The hole can most likely be fixed with epoxy and a filter drier added to the refrigerator by an experienced refrigerator technician but the problem involved will be the cost to have the repair done. It would be less expensive to replace the refrigerator, Thanks Sea Breeze
Posted on Dec 04, 2012
4 Suggested Answers
meBNme
  • 334 Answers
SOURCE: I've punctured a hole in the lining of the freezer
It sounds like you have punctured the evaporator coil and it is leaking refridgerant.
That would certainly cause the unit to be low on refridgerant which would cause it to start warming up, and becoming louder. It would also explain the smell.
If the unit is fairly new it *may be worth repairing, You will likely need a new coil.
Expect costs in the 300 to 500 range.
I reccomend getting a secondary place to store the food, and unplugging the unit emediatly if you want to have it repaired.
The reason for that is because the compressor is likely undamaged at this point. but if it runs on empty it will soon fail and then you can double the repair price or more.
Posted on Aug 26, 2009
Bat1956
  • 585 Answers
SOURCE: Punctured a hole in the freezer compartment
That type of damage is usually fatal to the unit. It is difficult if not impossible to repair in most cases depending on the metal used to make the evaporator, and what kind if equipment the repairman has. You can't fix this yourself, consult a local repairman, explain what happened, and the model of the unit, and ask if repairable what it might cost. Or just buy a new one. And NEVER use sharp objects in an effort to remove frost buildup. Turn it off, put your stuff in a cooler, and use a heat source such as a bucket of hot water in the unit with the door closed
Posted on Jul 18, 2009
lojacksdad
  • 121 Answers
SOURCE: I punctured the freon line in the freezer, will the refridgerator still work.
no sorry to tell you this type of problem is not worth repairing
Posted on Apr 17, 2009
Refrigerant leaking from a puncture in the copper tubing.
Put in a new piece of tubeing.First cut out hole, swag !a new piece of tubeing on both ends to fit over existing tube after claning and fluxing both ends of all four connecting pieces. Then silver solder all. Refill unit with the correct freon. Ifyournot familuarwith HVAC unitsI would suggest gtting profesonial helpl .
Sep 30, 2012 | Soleus SG-WAC-08ESE-C 8000 BTU Window Air...
Ice built up in my small kenmore fridges freezer and i was chippin it and made a hole and cold stuff came out will my fridge still work
You most likely punctured one of your tubes, letting the freon escape. If that is the case, the system must be repaired and recharged for it to operate and cool. Running your compressor without refrigerant will cause damage. Pull the plug, move the food, and have a repair person look at it. All hope is not lost; the tube may be repairable and the system recharged. It would pay to have the repairs estimated. Small fridges will be close in cost to repair or replace.
Best luck to you,
--W/D--
Jan 16, 2011 | Kenmore Refrigerators
Chipping away ice in magic chef freezer section i punctured freon line in freezer panel can refridge still get cold
No, the fridge will not get cold any more. The coolant goes to the coils in the freezer. The fridge takes a small amount of cold air from the freezer to lower its temperature.
I am sorry to say that unless you can find a way to repair the puncture and refill the system with freon, you are going to have to buy another refrigerator.
Feb 05, 2010 | Magic Chef CTB1922 Top Freezer...
Need freon recharge. punctures freezer coil in
You punctured the aluminum evaporator . In the many years I've been in refrigeration , I have yet to find any way to patch a hole in the evaporator . I've used epoxy , solder , and all different advertised ways to try to patch aluminum . Nothing worked ( for long anyway ) . My suggestion would be to buy another refrig . You will be wasting time and money trying to " fix " this problem . To repair it yourself , you have to have a license to buy R12 , maybe you can buy R134A without a license , you have to look on the " modell , serial number tak to see which it uses and how much to use . Also , the system has to evacuated ( all air removed from the lines ) . Do you have a vacuum pump ? You have to buy a solder on connector ( or saddle valve which WILL leak eventually unless you get a solder on valve ) which will connect to the larger tubing on the compressor or use the access line already on the compressor but is pinched off . Do you have guages for the refrigerant type you need to use ? Once you have these things , reply back and myself or someone else will help you procede .
Aug 19, 2009 | Refrigerators
Punctured a hole in air condtioner..HELP
The only sure way to repair the unit is to replace the condensor coil. Pressures are too great for a patch job.
Jun 28, 2009 | Heating & Cooling
Punctured gas line/ uses R-12
not very easily. Most freezers have the evaporator and condenser inside the wall of the cabinet and you cannot access them. If the puncture is in the condenser you can put in an exterior condenser however the parts break down for your model does not offer this option (:
Apr 08, 2009 | Whirlpool 19.6 cu. ft. / 555 liter Upright...
Hole
you have punctured one or more of the refrigerant lines. Your chances of fixing this are slim, but if you can find the hole, you can solder it shut, then pressurize the unit with new refrigerant. The former you might be able to do yourself. The latter will require you to get a repairman who has the necessary refrigerent and valves to re-load the unit. I would guess the cost of repair is probably more than the unit is worth.
Feb 08, 2009 | Magic Chef MCBR170 Compact Refrigerator
HELP - I punctured the Evaporator coil - is it junk now?
i will give u an experience
if u can see that tiny puncture then u can fix it.
how? well take a 100 grit sand paper and slowly rough the punctured hole on the side of the hole approx 1 inch around it.clean it with a clean cloth. next take some petroleum ether soak a tissue in ththat and with the ether moist towel wipe the area and the hole nicely .now buy fro the market aluminium epoxy tubes. mix a little bit of the epoxy in a i:1 rratio and apply a coating of this stuff on and around the just cleaned hole.After about 12 hours the puncture is repaired now dont touch it.
Take the fridge to a professional refrigerant filling person who has experience in filling gas. he will vacuum the system and remove any ingress of moisture and then begin filling gas. your fridge will be good as new after this job
Jan 11, 2009 | GE Refrigerators
Haier Black and Decker 2.7 Cu. Ft. Refurbished Refrigerator Logo
494 people viewed this question
Top Haier Refrigerators Experts
John Tripp
John Tripp
geob91
doggzzz
Level 1 Expert
Are you a Haier Refrigerator Expert? Answer questions, earn points and help others
