Question about Maytag Neptune MDG5500AW Gas Dryer
My dryer only work for about five minutes and then the flame stop
Hi, I have a maytag gas dryer it only works for about five minutes and then the flame stop working. I checked the voltage to the gas regulator solenoides and I have voltage, but the resistence for onen of them (the 2 contact one )whent up to open loop, and after 10 to 20 minutes it start to work again, this thing drives me crazy because I changed the high limit thermostat two times, and both solenoides and I relocate the vent pipe and still have the same result, any ideas? PLease help me. Thanks William.
  • rickriddle Nov 29, 2007
    i have a mdg5500aww, it is gas, and 6 years old, it has started to heat up the first time, and not again, unless it is off for some time. A&E, should be B&E, came out and said circuit board, $365. part only. Found one on the internet, with shipping $90.00, and it worked for about a week, then same symptoms, lights the first time, then not again. Watching it, the glow plug works the first time, but never trys a second. Any help?
  • 883 Answers
Look for a flame detector device that is turning off the oven due to its malfunction. it should be near the flame and it may have wires or tubing.
Posted on Jun 09, 2007
SOURCE:
I have a Maytag Neptune model number MDG9700A gas dryer...When I first turn the dryer on the dryer will get hot for about minute then the gas turns off and will not heat up again...It glows fine after...
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101
Aug 01, 2011 | Maytag Neptune MDG9700A Gas Dryer
My dryer does not have heat.
If the heating element has a flame starter, turn off the gas for five minutes and re-light the flame. If it's a piazo starter, you need a new one.
Jim Hart
Jun 14, 2010 | Maytag Neptune MDG9700A Gas Dryer
Dryer producues heat for only first five minutes
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
May 20, 2010 | Maytag MDG2706A Gas Dryer
Hi i have a whirpool gas dryer that all works fine but after about five minutes the heat will stop and it will just blow cool air. I can stop it and restart and everything starts and works fine and after...
The gas valve coils are closing the valve or the flame sensor is defective. The coils are the most common problem.
There are 2 on top of the gas valve. Turn off the gas and power. Remove the front panel by opening the top lid and then remove the screws from inside the front panel in the top right and left corners.
Nov 09, 2009 | Whirlpool Dryers
Mdg 4000aww turns on and heats when started. runs for 5 five minutes then flame goes out. ignitor glows but no flame. one minute later dryer still running ignitor glows, no flame. this repaets until turned...
Either the venting needs cleaned or the coils on the gas valve are bad. Unhook the venting from the back of the unit and run. If works ok then clean venting. If you still have the problem, replace the two coils on top of the gas valve.
Sep 29, 2009 | Maytag Neptune MDG5500AW Gas Dryer
Maytag MDG5500AWW gas dryer with inconsistent flame
the booster coil gets hot and stops working just replace all three and give me thumbs up...i get$60 for a house call
Aug 08, 2009 | Maytag Neptune MDG5500AW Gas Dryer
I HAVE A MAYTAG ATLANTIS GAS DRYER STOPS HEATING ABOUT 5 MINUTES IN
the flame going out is normal. the heat cycles on and off as called for by the thermostat. If the heat doesn't come back on i would start by changing the gas coils.
Oct 08, 2008 | Maytag Atlantis MDG7400AW Gas Dryer
Maytag dryer does not maintain heat and clothes smell
Check coils on burner assembly. Often when a dryer heats initially and then stops heating a coils has gone bad.
Nov 09, 2007 | Maytag MDG7600AW Gas Dryer
Maytag Neptune MDG5500AW Gas Dryer Logo
165 people viewed this question
Top Maytag Dryers Experts
Marvin
Marvin
Sal De
Archie Ferrarini
Archie Ferrarini
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
