Question about Altec Lansing Audio Players & Recorders
Fix Altec-Lansing mt800 - Power connector broken, need to open case to soldier.
  • 4 Answers
SOURCE: how to repair atp3 altec lansing
Best bet would be to just strip the wire with a wire stripper or utility knife and twist the bare ends together to fix the connection. A little electrical tape around those wires and you should be almost good as new. Of course you might notice some difference in quality but I'm pretty sure the only way round that would be replacing the cable.
Try it out and let me know how it works out for you. If you know how to solder it might be a good idea to solder the connection as well.
Posted on Jan 05, 2008
SOURCE: Finding replacement Power Supply for Altec Lansing
I did the same! Thanks for suggesting a call to Customer Support (800)258+3288. The guy didn't seem overly pleased to help, but he did promise to send me a new power supply. Also, he said that they don't make the iM7 anymore, but I had already found out that the iM9 uses the same power supply. I, too, will wait and see.
Posted on Jul 07, 2008
SOURCE: Altec Lansing ada745
I work for a charity that had one of these donated today and as I was looking for a new sub for my cinema system I purchased it. I have no other speakers with it and no way of switching or varying the volume. I opened up the back of the sub and slid the board partly out exposing the PCB.
[IMG]http://i134.photobucket.com/albums/q116/mm0dxc/PICT3734.jpg[/IMG]
You'll see 3 solder connections behind the scre in an "L" configuration. One of them is common, one volume and one power on. As I don't need volume, I'm happy with it being on full as my cinema system will vary the input, I joined all 3 together giving power on and full volume. It is working great now.
[IMG]http://i134.photobucket.com/albums/q116/mm0dxc/PICT3737.jpg[/IMG]
For you guys with volume controls, I would suggest shorting out the two rightmost pins in the "L" and I recon this will power it up and try varying your volume control. I recon it'll work just great.
Good luck
Posted on Jan 22, 2009
SOURCE: need wiring and 9pin connector diagram
Dell (Altec Lansing) A425 Subwoofer Pinouts
This is a standard female DB-9 serial port.
Here are the pinouts.
Pin 1 = Left Speaker Out +
Pin 2 = Left Speaker Out - (Common Ground)
Pin 3 = Left Line In +
Pin 4 = Right Line In +
Pin 5 = Left/Right line In - (Common Ground)
Pin 6 = Right Speaker Out +
Pin 7 = Right Speaker Out - (Common Ground)
Pin 8 = Power A
Pin 9 = Power B
Jumper (short) Power A to B to turn on.
If you want a volume control you need to put one on the inputs. You will buy buy a stereo volume control or potentiometer.
Here is some info on how to do this.
http://g4tv.com/screensavers/features/43665/Pump-Up-The-Volume.html
Cheers!
Posted on Mar 24, 2009
  • 10 Answers
SOURCE: Altec Lansing ATP3 volume control/power know gone bad
just sone it, i had to break a whole in the bottom part , work my way around it with a screwdriver , it will snap every 2-3 cm and come off in the end.
after its off start at the (now exposed) bottom of the front bit and work your way up and aroud `till it comes off. mind the wires . as for the volume button fix , as soon as i played with it and tried it again , everything was good. even though replacing it doesn`t seem like a big deal
put it back together and will superglue it in the future( while typing this i doubt if it will ever happen), and it lookes good( except from the bottom ,where its broken !).
now the button is solid and the sound as well.
SWEET
SWEET
Posted on Nov 05, 2009
How can my laptop charger fit to computer speaker?
Please do not modify your laptop charger to power your speakers. The laptop charger probably has too high a voltage and amperage output. (USB chargers don't provide a large enough output.) The Altec Lansing ACS40 speakers need a 15V 900 mA power transformer; the coaxial power connector has the positive voltage on the center pin. The model number on the transformer is 4815090R3CT . This is available through Amazon.com and other vendors. One vendor is http://www.emtcompany.com/altec-lansing-4815090r3cac-power-supply-charger-adapter/1010666.html .
I hope this helps.
Jun 03, 2014 | Altec Lansing Audio Players & Recorders
Disassemble Altec Lansing T612
The front of the Alec Lansing t612 got smudged with glue. How doiremovetkhespeakercover so I can clean the cover
Dec 06, 2011 | Altec Lansing T612 Remote Control Speaker...
I plugged my 110 volts Altec Lansing speakers into 220 volts :( How can I fix it? Please help me. Thank You.
Check fuse, but if there wasn't a fuse , your Altec need repaired to fix broken components in power circuits, could be the resistors, diodes or even transformer.
Jul 03, 2010 | Altec Lansing BX1020 Computer Speakers
Hi i have a altec lansing T612 which my two yr old son damaged by pulling at my ipod whilst docked and has damaged the connector, my ipod works fine in my car but the dock doesnt work, can i buy a...
Ok if the dock connector has broken itself then you wont get much use from it. Im sorry but i can't help you on this today. But i will look for some answer's and stay in touch.
Thank's
Mar 16, 2010 | Altec Lansing T612 - High End Speaker...
ACS295 speaker cable to subwoofer, one of the pins of the connector is broken, how can I fix it or get a new connector?
if connector is broken, you need to buy a new connector, but it takes a little handwork and some tools a screw driver some electric iron and solder.
u need to open subwoofer case and check for the connector is soldered in a board is 2 jack 3,5mm female connector and one red mini-DIN connector. replace the connector take a attention on soldering the connector, dont damage the board wires and pins, if the iron above 300ºC.
take a special attention on electrostatic discharge, normaly burns sensitive boards.
Jan 30, 2010 | Altec Lansing ACS 295 Computer Speakers
I need to replace the Ion Battery for the Altec Lansing IM600
2 screws at the back removed with a cross head screwdriver. Remove the casing, then the battery plugs in to a white connector.
Jan 23, 2010 | Altec Lansing Inmotion-IM600...
I have a pair speaker altec lansing model acs300.1 i need the power supply transformer
Buy some broken ones off eBay, throw them in the bin and just use the power supply :D
Dec 15, 2009 | Altec Lansing Multimedia Computer Speakers
Need wiring and 9pin connector diagram
Pin 8 = Power A
Pin 9 = Power B
Cheers!
Mar 27, 2008 | Altec Lansing ADA425 3-piece 30-watt...
Altec lansing
I had the same problem. After numerous calls to Altec Lansing they sent me out a new one. The new one doesn't have the same connector on it. I called tech support only to hear that they discontinued the 621 and don't make parts for it. Sorry, you are probably out of luck.
Oct 26, 2007 | Altec Lansing 621 Computer Speakers
128 people viewed this question
Top Altec Lansing Audio Players & Recorders Experts
Carlos L. Burgos
Carlos L. Burgos
Are you an Altec Lansing Audio Player and Recorder Expert? Answer questions, earn points and help others
