Question about Nikon COOLPIX L18 Digital Camera
Transfer pictures I loaded software. I lost USB. How do I transfer pictures from memory card to computer? I know i can put the memory card in my printer. The pix appear to be loaded or transfered, but I can't see them enough so I can drag and drop them to another folder. What do I clik to get this to work? Help Please, Thanks, Phyllis
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Nikon Master
  • 102,366 Answers
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program, such as Nikon Transfer and Picasa.
Posted on Feb 07, 2012
2 Suggested Answers
leepania
  • 1099 Answers
SOURCE: pix transfer from internal to card
Question :
How do I transfer pictures from the internal memory of my KODAK Digital Camera to a memory card? Answer :
Follow these steps:
  1. On the camera, press Review and then Menu.
  2. Select Image Storage.
  3. Change to Internal Memory.
  4. In the menu listing, scroll down to Copy, and select OK.
  5. Select a single picture, or select All.
  6. When you have finished copying pictures, reset the Image Storage location to your original setting.
Posted on Jan 12, 2010
How to recover files once the protect button is lost
If the camera has a usb cord to connect your computer you might be able to locate the files see if that helps.
Apr 28, 2015 | Kodak EasyShare C143 Digital Camera
I have a HP M525 camera, Seerial No. CNGBUQ30Z4. Recently, when trying to transfer some up-loaded picturs (from the camera to the computer)the screen went blank. When I tried to restart the process by...
The possible solution's are
1 . First uninstall the photosmart software from the system and reinstall the software once again . Install in C: drive and then connect usb and transfer photos this will work . If this doesn't work then try in another usb port of the computer and transfer photo's .
2. Photo's will be in memory card ,better get memory card reader and take out the memory card from the camera and insert it into the card reader . Now connect card reader to computer and transfer photo's .
Hope this helps .
Mar 23, 2010 | Cameras
I have polaroid t737 i lost the cd drivers and
Greetings,
I would take out the SD memory card and use it with a card reader like this one: http://bit.ly/5fruhB . You simply take out the SD memory card and put it in the card reader. Then put the usb end of the card reader into your computer and download the pictures that way.I also recommend that you download Picasa, a free photo organizer/editor for your pictures: http://bit.ly/5f6HEt This way you bypass the lousy Polaroid software altogether. Hope that was helpful,
Take Care,
-WN
Dec 17, 2009 | Polaroid i737 Digital Camera
Nikon coolpix L18. Can't put pix on comp. format card
I suggest you to remove the card from the camera and use a memory card reader to transfer the pictures to the computer. Note that the memory card should be formatted in the camera. Once the pictures are transferred you can reinsert the memory card to the camera and then format it in the camera.
Jan 15, 2009 | Nikon COOLPIX L18 Digital Camera
LG PHONE PICTURES INTO COMPUTER
If you bought the SD card from Verizon then you should have another card where you insert the card into the regular sized and it works that way. Good luck!!
Jan 03, 2009 | LG VOYAGER VX10000 Cellular Phone
CD software and USB Cable
If you have a Card reader where you can put the memory card of your camera on it that will do the trick in transferring pictures from the camera to the computer and vice versa, but the best way that you can do is to buy a USB cable for your camera there are generic type of USB cable that are use for camera and its pretty cheap and for the software you can download it from Fuji's web site..
Hope that helps..........
Aug 11, 2008 | Fuji FinePix A345 Digital Camera
How to download my pictures off my motorola V3 phone to my Vista Computer
If all you did was have your provider activate a new phone then the pictures on your old phone should still be there. If, on the other hand, you had the provider activate the old phone to a different number they may be gone.
I'm a bit confused from your post. Are you saying your old phone was a Razr and the new phone is a Razr too?
Does the old phone allow you to use a memory card? The easiest thing to do, assuming you cannot locate the software, would be to buy an inexpensive memory card that fits into your old phone then transfer the images to the memory card. There are adapters you can purchase for a few $$ that will allow you to plug this little memory card into a USB port on your PC.
Let me know if you need more help.
Dec 19, 2007 | Motorola Mobility RAZR V3m Cellular Phone
Transferring pictures
You might try putting the pix on a rewritable cd, and then copying them from that drive onto the smartcard drive with your card inserted. Or just try copying directly from your computer file to the smartcard drive with your card inserted, essentially using the computer's hardware to do the job instead of the camera's software.
Nov 03, 2007 | Cameras
Transfering Pictures
if you have a card reader on your computer you can copy the pics from your memory card on your phone via the card reader. this is about the easiest way that i know. I have not seen good sync programs for this phone.
Jun 16, 2007 | LG CHOCOLATE VX8500 Cellular Phone
Transfer images from a razor phone
Hello as far as I know there is a lot of chance that you have to use a software and also the software made by the phone company ...unless you are using an ipod or iphone which uses itunes to transfer multimedia content
Jan 14, 2007 | Motorola Mobility RAZR V3
Nikon COOLPIX L18 Digital Camera Logo
64 people viewed this question
Top Nikon Cameras Experts
Steve
Are you a Nikon Camera Expert? Answer questions, earn points and help others
