Question about Averatec 3200 Notebook
Hook up Avertec 3200 to Sharp Aqueous TV
Is it possible to hook up my Avertec 3200 coputer to my Sharp Aqueous HD TV in order to play music downloaded onto my computer through my TV speakers? What kind of a connector do I need?
Also where can I download a manual for the computer?
Thank you
  • charlottegoo Jan 19, 2009
    Thank you for the manual. My Sharp Aqueous is model LC-20B8U.
    Went to circuit city to purchase the cable you suggested. They said it would not hook into my laptop-the outlet on my lpatop is not a plug in but rather a blue rectangle containing 3 rows of 5 little holes.( Sorry I don't know what this is called) They said I would need a converter box to convert the format of my laptop to that of my TV. Do you agree with this assessment?
    President:
  • 623 Answers
After I found the manual somewhere on the internet, I realized that it is already available here. (Lucky you!)
I could not find a specific manual for your Aquos TV (which model?). Look into your manual, and see if there is an option to connect via VGA of HDMI for video
If you want to use your TV speakers, it depends what audio input options you have on your TV. You might need a cable like this:
The red/white connectors into your TV, the 2.5mm plug into your computer.
Posted on Jan 11, 2009
  •  C. Dante
    C. Dante Jan 19, 2009
    Well, you asked for an audio connection, not a video connection.
    That's a different cable.
    And -no, I do not agree with that assessment.
    I found the manual for your TV here. Take a look at page 33 (page 34 in the pdf-file) and you can see the connector type. (It also shows the audio connection I mentioned in my earlier post!) This video connection is called "VGA" (or 15-pin D-sub). It is exactly the same connector you use to hook up a standard monitor to your computer. All you need is a standard VGA cable like this:
    Page 35 (36 in pdf) shows a list with all possible resolutions. With your XGA video onboard you should be able to get a resolution of 1,024x786. Try it out!
    In other words: just use a normal monitor cable you have lying around (or take the one of your best friend to see if it works...;-), before you buy one. On older TV's you needed a converter, because the signals were different. Nice sales trick though...!
    You might have to play with the settings a bit to get the picture the way you want it to be, but I looked at the instructions in the manual and the explanation sounds pretty straight forward.
    If you get stuck, come back here and leave a comment.
    Enjoy!
In my tv sharp aqueous I receive the message no signal.what can I do.
What is the TV input control menu set to? It may be set to another function like HDMI or Aux. It is a common mistake.
Sep 06, 2016 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
I have a proview model 3200 is it possible to hook up a set of good house speakers to it because the sound is terrible when listening to music? There are so many jacks on the back it seems do-able.
Hook up the audio output of unit to the stereo audio inputs of your receiver (U need amp to drive any speaker) using the appropriate cord and adapters.
Oct 28, 2015 | Audio Players & Recorders
Is it possible to hook my dell D630 to my sharp LCD/HD tv?
If your TV has a VGA port then yes, otherwise you will need to purchase a special adapter that tends to not work well and be expensive. -Alex
Aug 15, 2011 | Dell Latitude D600 Notebook
What type of cable for laptop to Tv?
In order to hook a laptop or any computer to a tv you have to have the right video card with the correct video connections like hdmi or s-video. If you don't have those connections then you can't hook a laptop to a tv.
May 05, 2009 | Sharp 19 in. LCD HDTV
Avertec 3200 won't reboot, white screen says NTDLR is missing
Ooops, if ntldr is missing, it means your operating system is dead. You should reinstall windows from cd. Must get into Bios to select first boot device as Cd and then press f10 and yes. When you start your lap it says you what key press to get to Bios or boot menager.
Mar 26, 2009 | Averatec 3200 Notebook
Xbox360 hd hookup problem---1080i
Your component cable is probably switched to the HD setting. You have to switch it back in order to get video when hooked up to a regular TV.
Jan 30, 2009 | Mitsubishi WS-55857 55" Rear Projection...
May sharp lc-52sb55u
Well, there is a way to have the clearest possable picture. Get HD cable TV box that is HDMI compatable and watch only HD channels. Or buy a blu-ray player, hook it up via HDMI and only watch blu-ray disc in 1080p!
Jan 06, 2009 | Sharp LC52SB55U LCD TV
Connecting my Humax Series 2 Tivo to a Motorola HD DCH3416 Cable Box
Yes, the Tivo will just record in standard definition, instead of high def.
You can still hook the two up together, though.
What I would suggest (and have done in the past) is this:
Split the cable coming out of the cable box.
Hook one up to your HD cable box, and the other up to the Tivo.
Hook the output of your HD cable box to one HD input on your TV
Hook the output of your Tivo up to a different (non-HD) input on your TV.
This will allow you to watch HD while recording standard definition, and vise versa.
Running the HD through the Tivo will work, but will limit you to not be able to watch HD through it.
Aug 10, 2008 | Humax DRT800 TiVo Video Recorder
Avertec 3200 notebook
remove the cmos battery from the board and replace it again!!
Jun 14, 2008 | Averatec 3200 Notebook
Averatec 3200 Notebook Logo
1,059 people viewed this question
Top Averatec Computers & Internet Experts
Rommel Balcita
Are you an Averatec Computer and Internet Expert? Answer questions, earn points and help others
