Question about Naxa Electronics NX-517 Television
SET WON T STAY ON STARTING TURNING OFF ON IT S OWN NOW WON T PL
WON T STAY ON AT ALL
    Problem Solver:
  • 7 Answers
Check the power supply. This kind of sets usually has switching PS. Check the capacitors, common fail of special low ESR caps. It is easy to see if there is some electrolitic content outside the cap. In case caps are damaged replace them with higher voltage, never use normal caps in this PS.
Hope to help you.
Posted on Jan 12, 2009
It will crank but won't stay running
installed new fuel pump and filter in 97 cavalier 2.2 the car will run for a couple seconds and shut off if you spary it with starting fluid it will stay running
Apr 13, 2012 | 2003 Dodge Durango
I have a 2005 hydaia accent that crank up but won't stay run but when I put it in drive it kills
Car not starting or turning over indicates towards multiple possibilities. It can be issue with battery or weak battery. But if battery checks out ok, then it can be starter issue or faulty alternator or problem with low fuel pressure or no spark at spark plugs due to dirty spark plugs or faulty ignition coil or injectors getting cracked or dirty and needs to be cleaned.
To confirm the problem, the basic troubleshooting is required.
Click this link below and follow the troubleshooting:------
http://technoanswers.blogspot.in/2012/02/car-starting-issues.html
This will help.
Thanks.
Feb 26, 2012 | 2005 Hyundai Accent
Starts then dies & won't restart
check fuel pressure, should be 40 psi.
try 2 things
spray starting fluid in air intake to see if it will stay running. It's fue then.
Try turning key to on nd wait 5 seconds for system to build pressure and pump to shut off. Turn key off, wait for relay clcik noise or 10 seconds. then turn key to ON again and wait 5 seconds to build pressure again. Then start engine. If it starts better, you have a bad check valve in the fuel pump or a bad pressure regulator on the fuel rail (unlikely).
report back
Aug 22, 2011 | 2005 Ford Expedition
50 inch dlp, keeps turning off, been happening since set was a year old, but now it won;t stay on at all some people say scrap it instead of repair what should I do
You probably have a bad lamp. They usually last 8,000 hours. If its not the lamp, it is probably a bad power supply or lamp ballast which is about a 200-300 dollar fix.
Jun 07, 2011 | Akai PT50DL24 50" DLP TV
Not starting up just turning over
I don't have a solution, but I have the same problem. My 2000 jaguar set for about 2 weeks and when I tried to start it, the engine turns over but won't fire or start.
gmisselho@yahoo.com
Apr 06, 2011 | 2001 Jaguar XJ8
Start but won,t stay runing only at fast iling
Possible problem with the fuel settings as the idling is faulty. So you will need to set the engine after a full check up on the fuel settings starting from the tank, the fuel filter , pump .
The idling setting must match the fuel settings.
Feb 22, 2011 | 1985 Nissan Pickup
Replaced ctm unit and truck won`t stay running.
there are 2 sensor on the carb . you may need to replace both to find out whiche one it is . try this also give it gas while starting and when it starts you will have to keep your foot on the gas a little to keep it running if it runs that way its one of the 2 senors .
Jan 20, 2009 | 1997 Dodge Dakota
Naxa Electronics NX-517 Television Logo
154 people viewed this question
Top Naxa Electronics Televison & Video Experts
Joseph Gallucci
Chris
Are you a Naxa Electronics Televison and Video Expert? Answer questions, earn points and help others
