Mindscapes sound therapy alarm clock manual - Audio Players & Recorders
How to raise and lower the volume on the alarm on a model 4248 alarm clock
BRIAN, DID YOU GET A MANUEL WITH YOUR CLOCK-RADIO LOOK IN IT OR CALL MANUFACTURE CUSTOMER SUPPORT
Jan 21, 2016 | Audio Players & Recorders
I can't find how to change the time for the alarm system for a Alphaline 150i digital radio alarm clock
PDF]Instruction Booklet - Sound Therapy and Relaxation Clock ...
www.conair.com/instruction.../07ps111_su7_ib.pdf
Conair CorporationThe LCD display will show the current time of ALARM 1, reset time. ... The Conair Sound Therapy & Relaxation Clock Radio System can be used with a cord ... 1) 10 high quality digital recordings .... 150 Milford Road, East Windsor, NJ 08520.
Muse - Alarm clock radio
www.muse-europe.com/en/products/alarm-clock-radio
Catalogue Products, Cat?gorie Alarm clock radio. ... M-125 CRB. Clock radio CD player with MP3 ... M-150 CR. Clock radio ... Automatic time-set clock radio PLL ...
[PDF]FM/AM Clock Radio - Sony
Jan 10, 2016 | Watches
How can I find my alarm clock on my HTC inspire phone
Hi
On the Home screen,tap HTC Clock widget.
Tap on Alarms.
Select checkbox of an alarm and then that alarm.
On the set Alarm screen,use your finger to drag up or down to roll the time scroll wheels and set the alarm.
Scroll through the set Alarms screen for available options.
Choose alarm sound and also days to sound the alarm.
Select vibrate if you so wishes.
Tap on done to save the settings.
Here's a manual for your HTC smartphone.
member.america.htc.com/download/Web_materials/Manual/HTC_Inspire/110302_Ace_ATT_WWE_UM.pdf
Hope it helps.Thanks!
Feb 26, 2012 | HTC Cell Phones
I was given a CONAIR model SU5T SOUND THERAPY TRAVEL SYSTEM, but without an operating manual. I am hearing impaired & can not find a travel alarm clock loud enough to wake me up. I wish to try this...
There are at least three different Sound Therapy systems and two of them have manuals available on-line:
SU1W:
http://www.conair.com/instruction_booklets/07PS078_su1w_IB.mech.pdf
SU7:
http://www.conair.com/instruction_booklets/07ps111_su7_ib.pdf
Aug 03, 2011 | Cameras
How do you turn the alarms off and on for the Conair model SU7?
Link to set up for SU7 alarm sound therapy clock: http://www.conair.com/instruction_booklets/07ps111_su7_ib.pdf
Nov 07, 2010 | Conair SU7 Sound Therapy and Relaxation...
Timex Indiglo, model T560B natural sounds alarm clock radio
Press alarm set button, time display will blink. Then press off/reset button to toggle hourly beep on/off.
Aug 08, 2009 | Timex Auto-Set Dual Alarm Digital Clock...
Instructions; TIMEX Alarm Clock Radio w/CD Player & Nature Sounds
Go to timexaudio.com, select SUPPORT, then select PRODUCT MANUALS.
Jan 25, 2009 | Audio Players & Recorders
Lost manual for a timex t307s
Setting the Alarm 1 for AM/FM Radio
1. Press and hold the 2 Radio Alarm 1 Button. The display will flash and the Radio Alarm Indicator will appear. If
you do not begin setting the time within ten seconds of pressing the button, the display will stop flashing and you will
need to press the 2 Radio Alarm 1 Button again.
2. While the display flashes, press the 1 Reverse and 6 Forward Buttons to set the wake time. Hold a button for a few
seconds to set the time rapidly. Be sure to set the correct AM/PM time, as shown by the PM Indicator.
3. After setting the radio alarm time, while the display is still flashing you will need to select the station. First, press the
L Mode/DST Button to select a radio frequency. Next, select a station using the M Memory Set 1-6 Buttons. For
more information on programming radio stations into memory, see the Programming Radio Station Settings section of
this manual. Rotate the O Volume Thumbwheel to set the wake sound volume.
4. After setting the radio alarm wake time and sound, you will need to select the 7-5-2 setting. The 7-5-2 setting lets you
set the alarm for a full week, weekdays only, or the weekend. Before setting the alarm, be sure that the correct date
is set, as shown in the “Auto-Set” and Manual Time and Date Settings section of the manual. While the display is still
flashing, press the 9 Date/7-5-2 Button until the desired setting is shown.
5. After you have set the radio alarm wake time, sound, and 7-5-2 setting, press the 4 Enter Button. The Radio Alarm
Indicator
will appear on the display, showing that the radio alarm has been set.
Setting Alarm 2 for Nature Sounds/Buzzer
1. Press and hold the 7 Nature Sounds/Buzzer Alarm 2 Button until the Alarm 2 settings and Sounds Alarm
Indicator appear on the display.
2. Press the 1 Reverse or 6 Forward Button to set the Alarm 2 time.
3. Use the L Mode/DST Button to select a nature sound or the buzzer to wake to. There is a choice of five sounds:
Sound #1: Ocean Surf
Sound #2: Birds
Sound #3: Brook
Sound #4: Wind Chimes
buz: Buzzer
4. See Note #4 in the Setting Alarm 1 section for instructions on setting the 7-5-2 alarm setting for Alarm 2.
5. After you have programmed the Alarm 2 settings, press the 4 Enter Button or wait ten seconds to return to the clock
display. The Sounds Alarm Indicator will appear on the display, showing that the alarm is set.
Nov 18, 2008 | Timex (T307S) Clock Radio
Set Clock
This clock has 2 alarms to set Alarm 1, switch alarm 1 to the "set" position and make sure alarm 2 is pushed to the "off" "radio" or "cathedral" position, press and hold the "alarm" button on top while pressing the "f.fwd" or "rev" button to set the alarm....to set Alarm 2, do the opposite of the set buttons and repeat...to set the time just hold the time button down while pressing "f.fwd" or "rev"...hope that wasn't too confusing.
Jan 01, 2008 | Timex Nature Sounds LED Clock Radio
I can't find my manual
After having looked around the conair website for a downloadable manuable i was unable to find one, however, i did find this, quote... "# Please email customer service dept for insturction manuals." So, please follow the link below then scroll down the page and click "Contact us by Email". Im quite sure the email is free but it might take a while for them to get back to you. good luck http://www.conair.com/customer-service-cn-18.html
Aug 20, 2007 | Conair Sound Therapy Travel Clock Radio
178 people viewed this question
 Grubhead
Grubhead
