Question about Maytag Washing Machines
I have reset code of f 71 an a maytag 5000 series washer. how do i reset it?
I disconnected the hoses h and c and cleared out anay debris and also the filters reconnected the hoses, but the washer would not turn back on and after a little while the code came back.
    Top Expert:
  • Maytag Master
  • 9,472 Answers
What is the complete model number of your unit?
Posted on Dec 04, 2012
  • 1294 Answers
SOURCE: Whirlpool washer f30 code
This error relates to the motor drive. Plug off the wall, open up behind, look for broken belt. If the belt is good its the motor brushes. Secure connections to the motor, look for loose wires.....
Posted on Jan 11, 2008
textonor
  • 130 Answers
SOURCE: bosch frontload washer will not drain
Hello Mamma5, It sounds like the drain pump is either seized or jammed. The drain pump has an anti jam device in it. Since you have figured out how to get into the drain pump, try turning the inpeller in the back. It will be a little hard to turn as the magnets in the motor will fight you on this. Look close in case there is anykind of thread wrapped around the inpeller. If so, then you can free the pump. If you cannot free it to run, advise the repairman what you found so he can bring a drain pump with him.
Hope this helps.
Posted on Jan 23, 2008
Hi there.
We just bought a brand new washer and had the same thing just happen to us. Found out after taking the lid off that the top had pinched down on the mechanism that turns and allows the water to flow in. We were stacking out laundry baskets on top of the washer which did this. After taking the top lid off and touch it it began to move and is working properly now.
Have you tried this?
Hope it helps someone out there in the future if not you now.
Posted on Feb 18, 2008
co7196
  • 3433 Answers
SOURCE: Maytag Legacy Series Washer. Lint settles on
Lint is in majority flushed out in drain cycle. make aire the tissue and match books aren't in any pockets. the lint is then deied and separated in the drier , Well so I was told . good luck
Posted on Jun 15, 2009
richroth
  • 9472 Answers
SOURCE: Frigidaire front load washer GLTF2940FS barely
Yes, there is a filter on your machine. If you look in from the back, on the bottom of the tub is a hose coming off. Remove the hose from the tub section and inside of it you will find the filter.
Have a great New Year!
Posted on Jan 03, 2011
I have a maytag 5000 series washer. We are getting an f21 error code. I unscrewed the white drain filter and cleared it. There was little in it. I keep getting the f21 error though. Can you help?
Search Results
    whirpool f21 error code - YouTube
    ? 3:04
    https://www.youtube.com/watch?v=b24PVv-ORqg
    Jul 1, 2012 - Uploaded by davidmontabon
    whirpool f21 error code. ... Maytag , Whirlpool Washer Repair - Drain pump error, no drain - F9E1- MHWE201YW00 - Duration: 4:29.
    My maytag 5000 series steam washer stopped and said Sud ...
    www.fixya.com/support/t8682656-maytag_5000_series_steam
    Mar 17, 2011 - my maytag 5000 series steam washer stopped and said Sud and now says ... Clicking this will make more experts see the question and we will .... I bought aMaytag 3000 seris in 2008 and I am getting these messages: F21 ... Maytag 5000 Series washer F21 error code was flashing and door will not open.
    Whirlpool/Kenmore/Maytag & more-F02/F21 & Sd error codes
    fixedappliance.blogspot.com/.../whirlpoolkenmoremaytag-more-f02f21-...
Feb 09, 2016 | Maytag Washing Machines
What does an F21 error message mean in a Maytag 5000 series front load washer>
Hi
F21 error means that the drain time has exceeded 8 minutes; this will turn off the water valves. Press PAUSE/CANCEL two times to clear the display. If errors still remains then please check the drain hose and make sure it is not plugged or kinked. Disassemble the washer by removing the back from the washer and check the electrical connections at the pump and make sure the pump is draining. Also inspect the pump filter for foreign objects. Before disassembling remember to turn off the power and disconnect the washer. If it still doesn't help then there is an issue with the pump and you'll need to replace it. Hope this helps... Please post back if you need more information.
Daniel
Aug 15, 2011 | Maytag Washing Machines
Does not seem to drain completely - ran very long today and the last code I saw was "nd" - not draining? or not done?
nd code indicates a problem with draining. The problem could be:
1. Clog in the drain hose - 2. Drain pump in the washer needs replacement 3. Clog in your sewage
Some simple things to try out
a. Run a wet/dry shop vac at the end of the drain hose to clear out any crud/cloth debris. b. Replace the drain hose altogether (will require a bit of work). Remove the back panel (small) that holds the drain hose in place and disconnect the clamp that connects to the drain hose to thepump outlet. The whole drain hose can be purchased for under $20 at your local hardware store...
Good Luck!
Jun 11, 2011 | Maytag Neptune MAH5500B Front Load Washer
I get a "SUD" and
Hello & Welcome to FixYa
F35 error means that there is some sort of issue with the steamer electronic board and analog pressure sensor has gone bad. Check that the hose is firmly attached with the washer and is not blocked. You can also check the water level pressure switch operation. Please get back to me if you have any other questions.
Kevin
May 12, 2011 | Washing Machines
Maytag neptune front load washing machine will not fully discharge water after the rinse cycle...HELP???
Check the drain hose and clear it from any debris that might be blocking the water from draining out completely. If the drain hose is clear of debris, check and clean the pump. Disconnect the machine from the power outlet before servicing for safety purposes.
Remove the rear access panel to access the pump and disconnect the wiring harness from the terminals of the drain pump and the pressure switch.
Loosen the clamps holding the drain hose and the tub hose to the pump assembly. It is a good idea to spread a towel under the pump before loosening the clamps.
Remove the hoses and rotate the pump assembly counterclockwise to release the pump assembly support legs from the keyed slot in the base of the washer. Remove the pump assembly from the washer.
Clear the pump impeller from any debris that might be causing it to work improperly. Clean the tub and the drain hose.
Reassemble the pump, the hoses, and reconnect the wires to the terminals of the pressure switch and the drain pump. Reinstall the rear access panel and run the machine.
Replace the pump (part #25001052) if water still do not drain out completely.
Remove the plastic bag covering the pressure switch. Press in the locking tabs on the back of the pressure switch and pivot the pressure switch off the pump bracket.
Grasp the pressure switch and lift the nipple of the pressure switch from the pump cap.
Install the pressure switch into the new pump assembly in reverse of the steps above.
Feb 24, 2010 | Maytag Neptune MAH6500A Front Load Washer
Washer display flashing error code f-21
The F21 code on the Maytag EPIC is telling you there is a pump problem.
The pump impellers should be checked. There should be four of them.
Sometimes the impeller blades can be broken by coins, etc.
Make sure that the pump is clear of debris, to do this:
Remove the discharge hose, and blow through it.
If after clearing of water, the hose doesn't blow free and clear, you have something stuck in there.
You will need to clear the pump of the item that is stuck inside.
Good Luck,
I hope this helps,
Please rate me,
Thank you
Dec 02, 2009 | Maytag EPIC MFW9700S Front Load Washer
F 21 error code? Maytag epic z washer
The F21 code on the Maytag EPIC is indicative of a pump problem. The pump impellers should be checked, there should be four of them. Sometimes the impeller blades can be broken by coins, or other items. Make sure that the pump is clear of debris, then remove the discharge hose, and blow through it.
If after clearing the initial slug of water, the hose doesn't blow free and clear, you have something stuck in there.
Nov 28, 2009 | Maytag EPICz Electric Dryer
F@ error code,
F02 - Long Drain (Drain Exceeds 8 Minutes) - Select 'cancel' twice to clear error code. Note: You may see a "SUD" error code appear first during this failure. This should change to the F02 error code after a few minutes. Proceed by checking the drain hoses for proper connection and kinks. Unplug unit and disconnect power. Check the electrical connections at the pump and make sure it is operational with no debris or blockage. Reconnect power and plug unit in. If problem has not been corrected, replace the pump.
Oct 10, 2009 | Maytag Neptune MAH5500B Front Load Washer
Bathmat disintegrated in front loading maytag 5000 series washer - is there a filter on this machine and where is it?
Unplug the machine,bail out as much standing water as you can,remove the bottom panel 3-4 screws 1/4 inch driver.the pump sits right in front turn the handle to the left have plenty of towels,make sure you keep the Motor control board on the left dry,you will find a filter there that catches most debris but check the out going hose on the other side of the pump as well.
Oct 03, 2009 | Maytag EPIC MFW9700S Front Load Washer
We got an f21 error code. What causes it and how can we fix it?
The F21 code on the Maytag EPIC is indicative of a pump problem. The pump impellers should be checked. There should be four of them. Sometimes the impeller blades can be broken by coins, etc. Make sure that the pump is clear of debris. Finally, remove the discharge hose, pucker up, and blow through it. If after clearing the initial slug of water, the hose doesn't blow free and clear, you have something stuck in there. Hope this helps you and best wishes.
Jul 23, 2009 | Maytag EPIC MFW9700S Front Load Washer
Washing Machines Logo
190 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
