Question about Sylvania sdvd9020 - 9 Portable Swivel Dvd Player-5hr Batter
Movies in usb notplaying in sylvania sdvd9020 portable dvd player
4 Suggested Answers
  • 4 Answers
SOURCE: sylvania dvd player tv has
in your owners manual it should list the codecs that are compatible ( eg. avi mp4 ect ) try to make sure those are the ones that you play . also check there website to see if they offer any updates for the system itself . Sometimes they do , and it's just a matter of downloading them onto your usb drive and installing them into the unit . They will give you instruction on there website if this is an option . Oh and make sure you know the model number of the unit before you go to the site to make things easier for yourself
Posted on Sep 12, 2011
KingDWS
  • 1606 Answers
SOURCE: I have the Sylvania SDVD1030,
A codec works like a video compressor as well as a video interpreter. It takes the file and un-compresses it to what the player needs as well as how to generate the picture. Unfortunately there are literally hundreds of them. So normally you get a problem where a video was generated or saved using a different codec. The other part to this which is your problem is that you can use different codecs to create the same file and then you can change options on each of these. So you can find two seemingly identical videos and one will play while the other won't. On a computer you just load a codec software suite which installs hundreds of codecs. Unfortunately on a player like this you can;t load the, You are stuck with what it came with.
Having said or typed all that I ran across quite a few complaints about this player not being able to play mp4 or mpegs unless they are on a dvd disk. It will not read them from the usb. I would guess that the usb interface is not capable of the larger data rate a mp4 requires. So you may find if you burned the mp4 to a disk they would play but you won't be able to play them off of the usb.
I'd suggest either burning them to a dvd or trying a different file type like a AVI You can find most movies in avi format or you could use a commercial dvd versions which should play fine. So basically I don;t think you will get those movies or any mp4's to play off of the usb stick. You either need dvd versions or you will have to leave it behind. I'd try to find some dvds as that flight is a real killer as far as boredom goes. wish I a fix or work around for you but there isn't one.
Posted on Sep 24, 2011
SD Tech
  • 14553 Answers
SOURCE: I need a owners manual for a sylvania sdvd9000 portable dvd player
Best way here is to (I have done this) use a free translation service like Babel Fish to translate words in the menu until you find the one you need to click on with the remote to change language.
Posted on May 24, 2012
I can't figure how to get the closed captions to work. I am nearly deaf.
Press SETUP
Get to LANGUAGE SETUP PAGE
You can select OSD language, and select audio/subtitle/menu
language of DVD discs if available. Also you can select font type for mpeg4 subtitle
Remember you get SUB-TITLE only if your DVD supports it meaning contains it at the first place.
Sylvania SDVD9020 User Manual Setup Menu Setting
Feb 19, 2016 | Sylvania SDVD9000 Portable DVD Player
My dvd player starts the movie over every time I turn the car on. Previous reviews said it would start back where it stopped. the manuel gives no information on this. Help!
Hi Arlene,
I checked Amazon for this player and looked at the questions and reviews. As luck would have it, I found this:
Q: dvd player: Does the Sylvania SDVD8791 dvd player remember where the movie stopped?
A: No, It's starts the movie over everytime the player is turned off.
So it appears that at least one other person is having the same experience as you are having. At first, I thought if you had it wired wrong it would "forget" but since it is portable and lacks batteries - that wouldn't be the case. For these same reasons, I can't imagine how a player can remember the location on a disk if power is removed from it. In any case, I doubt there is anything wrong with the player, it simply doesn't function as you were erroneously told or as hoped. When in the car, you should probably tell those watching to note the location on the disk before shutting off the car.
The Amazon link I used for my reply can be found here: http://www.amazon.com/Sylvania-SDVD8791-7-Inch-Mobile-Portable/dp/B004QGXWS6
Apr 07, 2014 | Sylvania 7" Dual Screen Portable DVD...
My usb stick wont work with my portable dvd player?
check first in the user manual what kind of file format available in the dvd player that you bought. so you will know what kind of format that you can download to make compatible in the player using the usb stick.
Jun 25, 2012 | Bush Televison & Video
Sylvania SDVD6660 usb won't read portable hard drive
your hard drive must be formatted for FAT32 and NOT NTFS.
May 08, 2012 | Televison & Video
Can't play mp4s from usb on sylvania portable dvd player sdvd1048
You may also try this method to solve can't play MP4 on DVD player from http://www.idealshare.net/video-converter/solution-on-mp4-wont-play-on-dvd-player.html
Jan 05, 2012 | Sylvania Televison & Video
Sylvania sdvd9020 - 9 Portable Swivel Dvd Player-5hr Batter Logo
85 people viewed this question
Top Sylvania Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a Sylvania Televison and Video Expert? Answer questions, earn points and help others
