Question about Lofra Kitchen Ranges
I have a lofra electric fan forced oven an d does not work I would asume that the light has blown and because of this the oven will not work. Would this be the case,and where do I buy a new globe from
Model number loo6001
SOURCE: broken globe on Hampton Bay Ceiling Fan (Vercelli model HD278017)
My fan just stopped working - no lights no fan :( and I just can't seem to find any type of switch - only the remote, which lights up just fine. Can anyone help???
Posted on Jun 08, 2008
  • 1462 Answers
SOURCE: Grill element stopped working in
there is no fuse actually in the oven
take rear panel off oven and use a multimeter to check continuity across the grill element. can also be the grill regulator if fitted
Posted on Jun 29, 2008
SOURCE: I would like to know
were can i get spare part from for lofra cooker
Posted on Aug 31, 2008
SOURCE: Remove light globe from simpson harmony nova oven
The glass cover is a screw in. You will need to remove this by turning anti-clockwise to get to the globe.
Posted on Oct 19, 2008
barkencoa
  • 3463 Answers
SOURCE: smeg oven
Sounds like you need a new oven element fitting.
Posted on Dec 08, 2008
Our Lofra gas stove tops ignition isnt working on all jets. Electric oven is working. What could be the issue ?
personally I would call a repair service . gas being dangerous I do not recommend DIY fixes
Sep 12, 2016 | Lofra Kitchen Ranges
Lofra oven doesent stay alight
I had the same problem with my Lofra, I removed the cover on the bottom of the inside of the oven and then unscrewed the metal bit under that. Then I tested it again so I could see why it wasn't lighting up. Turns out the heat sensor was in between two flames and wasn't detecting that the gas was on. I wiggled things around a bit until it stared working, then put the cover back on. Now it works wonderfully. Now I just have to fix the timer.. It doesn't ring when it reaches the end. Hope this solution works for you guys.
Dec 18, 2012 | Lofra MXD96MFEPI Dual Fuel (Electric and...
Lofra LEF9EGP electric oven stopped working - fuse?
You probably had the heating element burn out. Disconnect it and test for continuity. If open, replace it.
murf427
Aug 01, 2012 | Kitchen Ranges
Nothing on my lofra oven works small oven fine top fine oven died no lights or fan
Hi You need to check out the fuses and the power supply. Dont forget to check the power point as well.There seems to be no power supply to the unit.
Regards.
PLZ. dont forget to rate my suggestion.
Jul 19, 2011 | Lofra MXGC96AMF/CV Dual Fuel (Electric and...
We have a Lofra dual fuel cooker 5 years old which needs a new rubber door seal on the gas oven but cannot find anywhere to obtain this part. Can you help? Pip Bedford
Hi I also had difficulty in obtaining a Lofra oven door seal but after searching and searching the internet I obtained an email address and now the problem has been solved. I received my oven door seal from the Italian Lofra company direct this morning. I dealt with a lady named Donatella and I found her very helpful. She can be contacted on donatella.talpo@lofra.it just give her the make of your cooker and she will let you know if she has one mine cost around £14. Good luck Suzie :)
May 03, 2011 | Lofra MXGC96AMF/CV Dual Fuel (Electric and...
Hi I have a Lofra Maxima Model no: MXD96AMFEP and need the Oven Selector Switch and Oven Door Hinges - can anyone help please am deperate!
Hi Gemma, this is Carlos from Lofra of Brazil. I would recommend you to contact our headquarters in Italy to help you locate the needed part for your range.
Please write to consumerservice@lofra.it or call +39 049 9904811.
Kind regards,
Carlos Fleischfresser
Lofra Sud America
Jan 18, 2011 | Lofra MXGC96AMF/CV Dual Fuel (Electric and...
Can't find parts for Lofra range cooker
do you have a clue where i can grip some knobs for lofra gas cooker.
MXUD66GGI. i have tried every where can you help me.thanxs.
Jul 15, 2009 | Lofra MXGC96AMF/CV Dual Fuel (Electric and...
LOFRA oven won't ignite/what are these symbols?
Figured out the triangles mean fan. I blows the hot air down. Still no clue about the other one. Found the sparky thing and scrubbed it with a wire brush (making sure the gas was off). After many more attenpts I turned on the top burner and tried again and it lit finnnnnaly.
May 28, 2009 | Lofra PXUD66GGI/C Gas Kitchen Range
The main oven has stopped working. The fan works and the Small oven also works.
There could be a few different things wrong. The element may have died. Is the fan you mention the forced air fan? No heat usually means blown fuse or faulty heating element, and since the small oven works I would suspect the the element has blown. You would benefit from getting an appliance serviceman to make a house call to replace the element. Unless you're handy and have a soldering iron, some heat resistant sleeving, and can access the back of the oven comfortably.
Hope this helps. Let me know.
John
May 08, 2009 | Belling DB90 Electric Kitchen Range
Cooker lofra
fuse in plug new one job done + wife turnd oven off ?
Aug 18, 2008 | Lofra MXGC96AMF/CV Dual Fuel (Electric and...
Kitchen Ranges Logo
27 people viewed this question
Top Lofra Kitchen Ranges Experts
Paul Carew
Oloyede Monsuru
ray gallant
Are you a Lofra Kitchen Range Expert? Answer questions, earn points and help others
