Question about Bosch NET9652UC 36 in. Electric Cooktop
I have a Bosch cooktop model net9652uc that all burners work but only one at a time. I have an error code 42. Can you tell me what that means
  • 338 Answers
SOURCE: Broken glass for 5 burners electric Bosch cooktop
If you can give me the model number I can give you 3 places and there prices. The model number should be located on the bottom of the unit.
Posted on Dec 04, 2008
  • 494 Answers
SOURCE: i have a bosch cooktop 5 burner and one burner
Is this cooktop new? Was it converted to propane or do you use natural gas? If it was converted, I was just thinking they put in the wrong size orifice. If it has been working fine and is just now giving you problems, then check the burner holes and see if they are partially plugged from food spills.
Posted on May 19, 2010
oldTech2332
  • 2341 Answers
SOURCE: Purchased the cooktop from Sears over a year
Is what broken and lools ugly the glass for the cooktop? if that is the case you should know the cost just for the glass is $470.00 plus the service call and labor it's going to be at least $600 to replace the glass
Gene
Posted on Aug 05, 2011
SOURCE: net7552uc bosch cooktop error codes 26 and 42
This may be malfunction of the main electronic board.http://www.ifixit.com/Wiki/Edit/Bosch_NET7452UC_cooktop
Posted on Oct 07, 2012
SOURCE: NET7452UC Electric Cooktop shows errors 26 and 42. What do they mean?
Problem: Error codes 26 or 42 after turning on too many heating elements.
Potential issue: Damaged main electronic board
Specific case: Error code 42 after turning on more than 3 elements, then already after 2, 1 until none of the cooking element could be turned on, over a period of a few weeks.
Root cause: Dying/blown electrolytic capacitor on the main electronics board.
Solution:
1) Turn off power (circuit breaker) - caution high voltage inside the cooktop
2) Lift the cooktop out of the hole in the countertop and slide it on a flat surface
3) Remove all screws around the metal housing using a torx screwdriver
4) Carefully tilt the glass top out of the housing on the front, noting that there are electrical connections in the rear, and place the rear end of the glass on a stable surface. You may need someone's assistance here.
5) After double-checking that there is no power, record the color coding of the four wires connected to the glass assembly (green for ground, white, black, red from left to right)
6) Next open the black plastic cover by removing four Torx screws.
7) Carefully remove from the connector on the left the the plastic strip connecting to the display board.
8) Carefully remove the circuit board with relays and capacitors that is held in place by plastic tabs.
9) If one of the capacitors is bulging out or showing sings of damage on top, replacing it may fix the appliance. De-soldering a bad capacitor requires some tools and skill. Replace the capacitor with at least the same capacity, voltage and use high-temp. 105C version) Alternatively, instead of replacing a $2 component you will have to replace the entire board.
10) Reassemble and done.
Testimonial: "Absolutely correct solution of the problem!!!"
PIC645F17E (Bosch) electric cooktop show error code er22. What does it mean ? How to repair ? Please help me ! Thank you !
The error code you posted is not listed anywhere. There is the error code "Error" for the oven which means oven overheating. If that's true then the problem is a bad oven power relay board.
This part has been discontinued. Bosch probably replaced it with a different part but I was not able to find the correct part number. You can talk to APP CSR and they will help you to locate the correct part.
Sep 05, 2016 | Cooktops
Bosch Cooktop Model # NGM8654UC 5 Burner. The middle burner ignitor is getting power but not sparking
Change the igniter switch. You can buy from mfr and install yourself.
Oct 06, 2013 | Bosch Cooktops
Bosch NET9652UC STOVE TOP shows Er 42
Er42 constantly slashing on my stove top, sometimes lasted for hours. When that happened you can't use the stove top until it stops. What should I do to stop the slashing?
Feb 20, 2013 | Bosch 30 in. NET7452UC Electric Cooktop
Solution:
May 04, 2012 | Bosch 30 in. NET7452UC Electric Cooktop
We have a problem with two of the burners on our Bosch hob which refuse to stay lit, at certain times. The problem is confined the front burners (medium size), with the largest and smallest burners which...
Remove the brass burner heads.Remove the Butterfly nut ( in some models just a screw ) and remover the cast iron base.At the narrow end there is a nozzle with a small pin hole which couples with this pipe. Take a fine needle or pin and insert into the small hole and clean. Reassemble and Voila !!!! bobhifi.jpg
Mar 07, 2011 | Bosch NHT645SGB Gas Cooktop
I have a bosch cooktop 5 burner and one burner lites its very dim and then goes out
May 18, 2010 | Bosch 30 in. NGP 732 / 736 Gas Cooktop
Cooktop's electronic igniter started clicking all by itself
Check to make sure your burner caps are aligned. I had this problem, and it turned out one of my burner caps was slightly askew. Putting it level fixed the problem.
Jul 25, 2007 | Bosch 30 in. NGP 732 / 736 Gas Cooktop
Bosch NET9652UC 36 in. Electric Cooktop Logo
Top Bosch Cooktops Experts
paulcarew
Jay Finke
Jay Finke
steve morris
steve morris
Are you a Bosch Cooktop Expert? Answer questions, earn points and help others
