Question about Neovo F-417 17" LCD Monitor
Does neovo f 417 monitor have a power problem
I plug the monitor into the computer then plug the power to the monitor, it will come on for a couple seconds. Then when I turn it off by the power button and back on it will only flash on then go off. If i unplug the power from the back and plug back in it will then come on
SOURCE: Menu screen appears all the time, flashes through different categories
I tried cleaning the plate as suggested but had the same problem. So I decided to see what would happen if I disconnected the button board all together. I haven't had a problem since. I don't know if this is a good idea or not but it worked for me. You need to make sure the monitor is in the on position before you do so. Since obviously you can't turn it on or make adjustments to the monitor afterwards but I never made any adjustments to it anyway.
Posted on Feb 01, 2008
  • 4 Answers
SOURCE: Neovo F-417 failure
When troubleshooting another problem with this monitor i had it open and noticed that all thought this monitor has a "fixed video cord" once the unit is opened up it actually plugs in just like any normal video cable for a monitor. If the monitor video cable is the problem(bent pins, twisted to much, left kinked) then replacing it is an option. Simply open the monitor carefully(so as not to break any clips) and remove the EMI Shield. Once you do this you will be able to see where the video cable plugs into the monitor and replace it.
Posted on Feb 17, 2008
ginko
  • 19396 Answers
SOURCE: F-17 neovo monitor stopped working. power light is flashing yellow
The flashing light indicates a diagnostic state called protection.
When the Monitor goes on protection there are only two possible causes.
1 The internal circuits are jammed because of electrostatic charges accumulating on capacitors, or because of a wrong voltage read by the main chip on your monitor controller board. this started the protection circuit.
2 The protection circuit detected a wrong voltage or a broken contact, identified an internal fault and kicked in , starting the flashing light.
If you are in situation one, then the monitor will reset just unplugging power cord for one or two hours, sometimes even minutes.
If you are in situation 2 , then there is an internal fault.
Common faults that can occurr suddenly are a blown capacitor on power board, the inverter board powering up backlight lamp has blown, or a fault on main lcd controller board.
check also the video cable, if the cable is shorting, or the connector is bad, you can get same flashing state because of the video cable.
Check connectors, try moving the video cable, and if the cable is not built in, then also try a replacement cable.
Regards
Posted on Mar 06, 2009
mavreix
  • 63 Answers
SOURCE: My Neovo f-417 LCD Monitor is switching off after
This means there is a hardware failure in the monitor that could be either blown CAPs or a shorted out inverter. It is difficult and dangerous to replace both of those(involving soldering and desoldering) if you don't know how as LCD's are made of a hazardous material. I would try new cables and on a different computer as a last resort and if that doesnt work then your monitor is trashed. If it works on another computer then the issue is not with your monitor. Good luck!
Posted on Sep 23, 2009
SOURCE: I HAVE A NEOVO E-19A MONITOR. ON BOOT UP SCREEN
http://www.devicemanuals.com/guide/LCD/AG%20Neovo/AG-Neovo-S-19A-LCD-Display-English-Owner's-Manual-T1RjMU9Uaz.html
dlc.sun.com/pdf/820-0119-10/820-0119-10.pdf
http://www.scribd.com/doc/3082274/AOC-LCD-Monitor-786LS-Service-Manual
Use these training manuals, to troubleshoot and sort your issue out.
Above is a user manual, and a service manual, in the service manual, are the troubleshooting steps to perform to isolate the problem, and hopefully repair.
Posted on May 25, 2010
My Neovo F-417 started to get lines across the screen then the images fragmented - 10 minutes & it lost power totally.
Chris,
Try unplugging the monitor from any video cables. Only have the power cable plugged into and then turn it on. You should see a message that indicates there is no video source. If you do not see this message then the monitor has failed, and you'll need to call it in on it's warranty. (If it is still under warranty.) To call neovo - the number is 866-333-3686.
If it is out of warranty - it's going to be cheaper to buy a new monitor.
If the video message that there is no signal does display, then try plugging the monitor in with a different video cable and see if that has any results. If not, try plugging the monitor into a different computer. If it works on a different computer, you may have a bad video port on the computer you are plugging the monitor into.
Hope that information helps!
Nov 21, 2011 | Neovo F-417 17" LCD Monitor
F-417 Neovo monitor only works in safe mode. Can this be fixed?
Can you please clarify the problem? It works if you start the computer in safe mode but not in normal mode? Do you get the message like 'out off range", "format not supported"?
Mar 18, 2011 | Neovo F-417 17" LCD Monitor
Driver for neovo F417 lcd screen windows 7
No drivers are necessary. If Monitor is seen as "Plug and Play monitor" is ok.
Mar 07, 2011 | Neovo F-417 17" LCD Monitor
Neovo F-417 monitor keeps switching off and takes several minutes to be able to switch it back on again
The power supply of your monitor have problem.Leak capacitor at ur power supply need for replacement
Oct 04, 2010 | Neovo F-417 17" LCD Monitor
Please ? i need shematic diagram for monitor NEOVO F - 417
jais un probleme avec mon monitor lcd nuevo s17 ,il s'allume et l'écran ne s'affiche pas c'est quoi la solution a se probléme
May 29, 2010 | Neovo F-417 17" LCD Monitor
Circuit board for a neovo monitor
Which circuit board are you after
Jan 08, 2010 | Neovo F-417 17" LCD Monitor
Neovo F-417 failure
Jan 29, 2007 | Neovo F-417 17" LCD Monitor
Neovo F-417 17" LCD Monitor Logo
48 people viewed this question
Top Neovo Computers & Internet Experts
Questman
Questman
Level 1 Expert
Dimitar Todorov
Are you a Neovo Computer and Internet Expert? Answer questions, earn points and help others
