Question about Kenmore Elite HE4 Electric Dryer
F-22 problem I can set my dryer for any setting and after several minutes it shuts off and flashes a F-22 sign.
  • ecbopp Jan 21, 2009
    I have the serviceman from Sears coming this afternoon to fix the dryer so I have been waiting to write the comment. My washing machine decided to show a F-24- water temperature sensor gone. Willupdate you when he is finished.
  • ecbopp Jan 22, 2009
    The service man said it was the sensor at the back of the dryer that controls the flap for the heat.It was not registering and so shutting off the dryer.
  • 198 Answers
F22 is a problem with the touch pad, check connections to the touch pad if ok replace touch pad assembly
Posted on Jan 18, 2009
Model WS55819: Shut off by itself. Power ON with remote, Green light next to power button on TV flashes twice fir 10 cycles and shuts off. Unplugged TV for 30 minutes and for 4+ hours. Same results.
The Error Code designations indicating a malfunction, or no malfunction, are listed below:
"12" ... indicates no error has occurred.
"21" ... X-Ray Protect circuit.
"22" ... Short Protect circuit.
"23" ... Horizontal Deflection failure.
"24" ... Vertical Deflection failure.
you will have to count the blinks, then there is a short pause and then following a second set of blinks this tells what is wrong with set.
Mar 07, 2011 | Mitsubishi Televison & Video
The aircon starts up okay. set the mode at auto. set the required temp at 22 degrees. starts to cool down then flashes E4. Can't find any reference to what E4 signals.
try to check your thermistor it is connected to your pcb board or shut of the main breaker after aseveral minutes shutt it to on to reset the alarm then observe the unit.
Feb 20, 2011 | Heating & Cooling
Dryer will only run for 10 minutes at a time
Hi, this is heat related. the timer module on this unit is overheating, in return, it is shutting down due to the heat generated but the faulty timer circuits. you will need to replace the timer device asap.
May 27, 2009 | Kenmore 73952 Gas Dryer
Kenmore HE2 Gas Dryer Control Panel Does Not Work Properly
I have the same problem..really disappointed in this product. I bought mine in 07 as well..I found that if i hold all the buttons down and then hit start it (Sometimes starts), but after it starts it turns off after 10 seconds.
Mar 27, 2009 | Kenmore Dryers
Kenmore Elite HE4 electric dryer locked on express dry only......
Shut the breaker off for several hours. Turned it back on.
Nov 30, 2008 | Kenmore Elite HE4 Electric Dryer
F 70 code on the Kenmore elete smartheat HE4
hello Whgispers42,
Huuum At your service!
You said,
We frequently have to start the dryer several times during one load. The dryer will run fine for a while then all the sudden give 3 beeps and then the F 70 code. Sometimes when you go to start the dryer you can press power and the panel will light up for about 3 - 5 seconds and then shut off again, this will happen several times in a row. We have been unable to solve this issue ourselves and are becoming very frustrated since this washer/dryer set are less than a year old. Any help you could offer would be greatly appreciated. (If we are unable to fix this problem soon, it is likely that the dryer will make a sudden leap from the second floor window to the backyard)
Try this first!!
This is an error code.
This can reset the system.
First unplug the washer and wait a 5 minutes then restart it.
It's like rebooting your computer when its acting strange!
Usually it corrects some error problems if they are not serious.
Or they are sometimes just a glitch.
If this does not help, you said the machine is not one year old.
All appliances have a 1 -year warranty and the service and parts are free for that first year!
I hope you succeed with my recommendations.
Please contact me with your progress1
Bless You
Thank You
Jul 27, 2008 | Kenmore Elite HE4 Electric Dryer
Set shuts itself off
sounds like a solder issue on the main deflection board. Check for signs of cracked or dull solder on that board. Its the large board on the right looking in from the back
Jun 30, 2008 | Samsung HCM4216W 42" Rear Projection...
Kenmore Elite dryer shutting off several times...
Sounds like you have a high limit thermostat that is failing. Hence, the reason it works on light weight items, but not on heavier items where more heat is required. When replacing the high limit thermostat it's also a good idea to replace the thermal cut-out (they are usually sold in pairs). Both should be mounted somewhere near the heating element, and both have two wires going to them. Remove power to the dryer before servicing, however. There is one more thermostat the is called the operating thermostat. It has four wires going to it and is mounted near the blower fan housing. There's a chance it could be malfunctioning but I doubt it. Let me know what you find and if I can help any further.
Jun 06, 2007 | Kenmore 60172 Electric Commercial Dryer
Kenmore Elite HE4 Electric Dryer Logo
110 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal De
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
