Question about Western Digital Computers & Internet
P/N: WD6400H1U-00 need Plug n Play Drivers for it
The Hard Drive is not being recognized by the Computer/Running Windows XP Pro w/SP3 This is another computer that I am sending this on but I want the Drivers on it also. The 500 GB is the one I transfer my files to to keep the computer RUNNING
SOURCE: XP doesn't recognize my external 500 GB WD My book essential edition hard drive
I had the same problem some have posted about. I had a lot of data on my drive and then one day it didn't show up in "My Computer" anymore. I had to assign a separate drive letter to the external drive.
Plug in the drive.
Right click on "My Computer"
Click on "Manage
Click on "Disk Management"
On the bottom half of the right side you should find "My Book" assigned to a disk number.
Right click on "My Book"
Click "Change Drive Letter and Paths"
Click Change
Select a new drive letter and hit OK
Hope this helps some people out.
Posted on Nov 06, 2008
I had a similar problem with a WDelements 250gig.
I found that if i plugged it directly into the computer USB and NOT through the USB i had attached to the computer it rectified the problem..
not sure if this will apply to you, but i thought id share.
Posted on Dec 14, 2008
mayur_best
  • 25 Answers
SOURCE: Transcend 250 GB Hard Drive not recognized by Windows XP SP2
u may got installation cd for storage device.if not download software from www.transcend.uk  ......... otherwise try for this..
goto control panel...
then goto add hardware...
overthere check out for connectivity
Posted on Jan 29, 2009
cowboytech
  • 69 Answers
SOURCE: Seagate 9SF2A4-500 external hard drive on Windows 98
Windows 98 will not run a drive that large, so that is your problem. You will need to connect it to a newer system, and break it down into small drives by setting up different partitions. Perhaps it will see it then. Also, most manufacturers are no longer supporting Windows 98. You really need to just upgrade your system to a newer OS.
Posted on Feb 13, 2010
SOURCE: my western digital 500 gb hard drive is not recognized
is there any solution
Posted on Mar 09, 2010
Why can i play hidden object adventure pack on my dell with Windows xp
Hi Jennifer,
When you say that you are unable to play , do you mean its not loading ? unable to install it? do you get a specific error message when you try to launch it ?
hidden object adventure pack:
  • System Requirements: Windows XP (Home & Pro) SP3, Windows Vista SP1, Windows 7 . , 800 MHz processor or greater. , 512MB RAM. , 237MB free hard drive space. , DirectX 7.0. Administrator privileges are required to properly install the program on Windows XP, Windows Vista , and Windows 7. Format: WIN XP,VISTA,WIN 7 Genre: ENTERTAINMENT Rating: E10+ Age: 8386390063
if your using windows XP , make sure that you have Windows XP (Home & Pro) SP3 and the rest of the specs mentioned above.
Thank you.
Dennis
Aug 03, 2014 | Video Game Consoles & Games
2.5'' external fell down
Sorry, but if your hard disk fell down and now isn't regognized by the computer the most possible situation is that the disk is destroyed.
Stelios.
Feb 22, 2010 | Samsung 250GB HD250HJ SATA II 300 7200rpm...
Installing XP SP3 pro on my presario C700
Most likely you have a SATA drive which windows is not detecting. Restart the setup and press F6. You will need to use another system to download the SATA drivers and save to a disk. Then when prompted you can insert the disk. You can also upgrade to XP professional which will almost always recognize the SATA drives. Good Luck.
Jul 30, 2009 | Compaq Presario 700 470024-192 Notebook
WD Caviar SE16 WD3200AAKS 320GB 7200 not recognized at install
Windows XP does not have built in SATA drivers. You will need to download the XP drivers from Western Digital's website and install before the computer will allow you to format and use your new drive. Hope this helps.
Jul 18, 2009 | Western Digital (WD3200JS) 320 GB Hard...
Hard drive failure required rebuild of XP Home on Dell computer. XP Home updated to SP3. Canon Multiplass F80 printer will not now work. I downloaded latest XP drivers from Canon web site, but installation...
I found that some Windows Plug and Play services were note running and were set to start 'manually'. I started those services which seemed related to Plug and Play, and the installation went without further errors.
May 11, 2009 | Canon MultiPASS F80 All-In-One InkJet...
Have problem with windows Xp pro.
You can get the correct drivers from the Gateway website. Use another computer and download all the Windows XP files for that model number from the website. You need your model number of your pc. Get the files for your motherboard, video, sound card, network card, etc. save them to a usb key or a burn them to a cd. Take the usb key/cd to the other system and load the drivers.
This will get your system back up and running in now time.
I hope this helps you.
Feb 18, 2009 | Microsoft Windows XP Professional
SimpleTech PininFarina external hard drive - site to download drivers
the hard drive you have is plug n play.
if windows does not recognize it, you may have to uninstall the hard drive.
right click your computer. click properties.
click on the "Hardware" tab. Click on "Device Manager".
open the category of "Disk Drives".
If you see your drive with a yellow exclamation point or a red "X", continue. If it does not, either it was dropped or its a faulty drive.
Right click your drive and click "Unistall". Click OK.
Now, unplug the drive and plug it in again.
it will install by itself.
Go to my computer and check that its there. If its not, you may have a bad drive. either send it for a new one (if still in warranty) or replace it.
Aug 12, 2008 | SimpleTech SimpleDrive Pininfarina 320GB...
Won't recognize on windows XP(SP3)
try other usb port, or other computer and see whether the hdd is detected. If still not, try to go to device manager ( http://www.computerhope.com/issues/ch000833.htm ), and then assign a drive letter to the hdd. After that, try to access it from Computer, if not able to access it, format it (use quick format) and then use asoftech data recovery program to recover your files.
http://www.asoftech.com/adr/
Aug 10, 2008 | SmartDisk 160GB FIRELITE PORTABLE FIREWIRE...
Computers & Internet Logo
246 people viewed this question
Top Western Digital Computers & Internet Experts
Arora Singh
Arora Singh
Alun Cox
Marcin
Are you a Western Digital Computer and Internet Expert? Answer questions, earn points and help others
