Question about Craftsman Gas Mini - Tiller/Edger
Start slow and fast plate assy
I have a craftsman edger model#536772210,
i believe it to be a 3.8 briggs and stratton engine,
i am unable to locate a part number and replacement assembly
described in summary,part is located atop carburetor
  • t marie Feb 01, 2009
    thanks for the perfect info I needed! Got lucky and bought one at an estate sale for $40 with no manual.
  • 138 Answers
SOURCE: Craftsman LT 1000 with Briggs and Stratton 20 OHV
lift your seat and look at the label that you got your model number from. to the right of the model number is the serial number. the first six digits of the serial number is the date your tractor was made - for example: serial no. 060802D002756 would make the unit made June 8, 2002
Posted on Aug 18, 2009
  • 127 Answers
SOURCE: I need another throttle lever for this craftsman
take top cover off look inside for a sticker or plate
Posted on Aug 22, 2009
The GR8 1
  • 7 Answers
SOURCE: Craftsman 42 inch deck mower.
That model number des not show up as a good number on the http://www.searspartsdirect.com site. Are you sure you have the belts on correctly? If it has 2 belts on the deck & 1 is not installed correctly they work against each other. Safely make sure that each blade will turn by hand. did you take the blades off? If they are too long by just a fraction, they will hit ach other, but that usually makes quiet a noise. Get your book out & systematically go over everything you touched or changed. It sounds like something really simple you have overlooked. you can go to http://www.searspartsdirect.com & enter a good model number & view all of the parts diagrams. Sometimes they are a big help, & at other times they just confuse you more:). Let me know what you find!!
Posted on Aug 13, 2010
SOURCE: what brand engine does my craftsman edger/trimmer
It is a Briggs and stratton engine.
Posted on Apr 02, 2011
  • 306 Answers
SOURCE: part no .492611 carburetor assembly (inc.key
http://www.partstree.com/parts/?lc=briggs_and_stratton&mn=130202-3129-01&dn=8994004A
Unless you broke it or lost something, rebuilding it is more better on the pocket book. Rebuilding mainly consist of long carb cleaner soak, clean air
flow tubes with piano wire and air pressure. This most times can be done without any new parts. Fix IT!
Posted on Jan 29, 2012
How can i fix my slow running lawnmower
Sounds like the air/fuel mix is off.. there should be a adjustment screw on the side of the carburator use a screw driver and turn it slowly one way or the other till it starts running right
Jun 22, 2014 | Craftsman 675 Torque 190cc 21" Briggs ...
Engine runs fast and slow
Take a spray of carb cleaner and clean the linkage mechanism from the governor to the carburetor and make sure they move with out sticking.
Dec 07, 2013 | Briggs Stratton Portable Generator 305cc...
I need a oil seal for a 15.5 briggs and stratton engine
try locating a bearing warehouse, they have listings for all size seals.
Apr 07, 2013 | Briggs & Stratton Briggs Stratton Intek V...
Craftsman Mower - 625 Briggs and Stratton Engine. The mower starts after I prime it 3 times. Starts up and runs at only half speed. I have taken the whole thing apart, changed the gas, cleaned the carb,...
Check the governer, its a lever that pulls the throttle plate from the engine side. Try manually overriding it (twist it open as the engine's running) and see if that does it.
May 09, 2011 | Craftsman 675 Torque 190cc 21" Briggs ...
I can't start my powerwasher. Where is the choke?
This Power washer has a 3.75 hp Briggs and Stratton Engine. It does not have a choke but does have a primer bulb. You must depress the primer bulb at least 3 times to start the engine. The primer bulb is on the side of the carb. It can be black or red. If your still unable to locate the primer bulb please provide your ENGINE model number and I will provide you a link to a diagram for the location of the primer bulb.
Thanks for using FixYa.
Kelly
May 29, 2010 | Briggs & Stratton Gas Pressure Washer...
Craftsman Gas Mini - Tiller/Edger Logo
168 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Dean Gruber
Roland W VanLue
Roland W VanLue
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
