Question about Frigidaire GLEF378 Electric Kitchen Range
How do I take the door off of my range for cleaning??
We can not find any screws or any means to take the door off for cleaning. Please help Thanks
  • 883 Answers
Try pushing in on the hinges in a lateral motion (parallel to the hinge axis)
Posted on Jun 09, 2007
Please I like to know how can I clean the door stove from inside I mean between the class
Most oven doors come apart once you have removed the door from the oven. Look for clips, screws etc that you can undo to release the glass.. Sometimes you have to remove the front handle as well. Do it carefully and slowly. The glass can slide out when you least expect it and can smash on the floor or you can get cut. Take note of how it comes apart so you can put it back together again correctly.
Sep 30, 2015 | Kitchen Ranges
Cleaning glass in oven door double glass
You would have to take the door apart. Two screws at the handle and 3 screws on the bottom. BE sure to take the door off the oven first and lay everything on a soft sheet. Do not put uneven pressure on the door glass, wear safety glasses and do not over tighten any screws.
Mar 18, 2014 | Kenmore 95882 / 95884 / 95889 Electric...
Whirlpool Electric Range Model # RF369LXPB. Self cleaning function does not work. A code displays after self cleaning function has been on for about 3 minutes. The code is F5EO. What does this mean?
Hello, Thank You for using FixYa. I will be helping you today.It means the door lock and door switch dont agree. Check the door switch does the oven light go on and off? does the door lock? It is either the door lock or oven door switch that controls the light.
Thank You and please rate my answer if it was helpful..
Jun 14, 2011 | Whirlpool RF369LXPQ Electric Kitchen Range
The Oven and Range are working; however I have a F5 code on the display. Can you tell me what this means?
The F5 code means that the range door isn't latching properly (for some Whirlpool ranges). Check the latch when the oven is cool. If it is loose, tighten the screws that hold the latch. Try opening and closing the door to see if the latch is clicking shut properly. Then unplug the range for 30 seconds to a minute to reset the unit. If the error clears, you're done.
If the error persists, clean the latch area. With the oven not in use, rub the latch area with a cloth that you dunked in hot water and wrung out the excess water. Then dry with a paper towel.
If cleaning doesn't help, the latch probably needs to be replaced.
I hope this helps. Please give me the model number of your range for additional ideas. Whirlpool has the user's manuals for most of their appliances at their site. See http://www.whirlpool.com/custserv/index.jsp and the Manuals and Literature search box.
Jun 06, 2011 | Whirlpool 30" Self-Cleaning Freestanding...
The handle to the stove has fallen off. How do I fix it?
hello. Get an assistant. Open the door about 1/5 until it stays open. With the help of the assistant lift the door straight up and off of the hinges. Put the door upside down on some towels or other padding on a table. Use a screwdriver to remove all of the screws. Then lift inner panel off. Now you will see where the handle screws are. Put the handle back, screw it on, then replace the inner panel and screw it down. With the assistant slide the door back onto the hinges. Done!
4 thumbs up please. thanks. Joe
Oct 09, 2010 | Frigidaire 30" Self-Cleaning Slide-In...
Kitchen aid double convection oven - glass needs cleaning!
Had to remove the screws on the BOTTOM of the outside door, then panel came off after all the screws (inside oven door included) were off...
Reversed the order to put back on.. Cleaned (all) three glass pieces nicely... Now after reading the problems with the self cleaning part (doors getting stuck!) - I'm afraid to try mine!
Jan 22, 2010 | KitchenAid KESC307 Electric Kitchen Range
I have an JGR8855 Jenn-Air gas range and just got a F9 fault code. What does it mean?
- Unplug the power
- Remove the the range plates
- Lift the front of the range lip gently and not much.
- You will see a cardboard covered piece.
- Pull down the door and unscrew the two front screws where the latch is
- Unscrew the bottom screw below the two front screws.
- look under the range lip and lift up the cardboard case
- use your finger and push the inside of the metal piece within the cardboard case.
- you will hear the latch click which means it has been reset.
Note- it looks confusing, but worth it if you want to save on a tech charging you hundreds of dollars. trust me, they will use the same procedures I just metioned
- Reverse the steps to put your stove back together.
- You may want to cover that clean option on the stove. this is what causes the F9
Hope this helps
Dec 20, 2009 | Jenn-Air JGS8750 Gas Kitchen Range
Liquid dripped into the door and onto the glass, how do I clean it?
Hi, The door has anywhere from 2 to 4 glass pains. Some models ranges you can just lift the door up and remove it from hinges. There are screws holding seceral layers of frame work. The outer shell should remove first with screws on the bottom edge of the door. With any luck, that is all you will need to remove.
I hope this helps you.
Please provide model # and let me know if I can assist you further.
Vic
May 27, 2009 | Kitchen Ranges
Clean Oven Door Glass
To remove oven door:
1. The oven door is held to the oven door hinges by two
screws. (One in each hinge.)
2. To remove the oven door remove the two screws.
Two screws
3. Close the door to the broil stop position and lift up.
then remove the door handle and take out all the screws around the edges of the door and pull the out side cover from the inner but a word of caution there are about three or 4 pieces of glass they are tempered and about 100 bucks a piece and most times they wont get real clean and will get messy again
May 24, 2008 | Frigidaire FES367 Electric Kitchen Range
F9 door locked
This means that the door latch motor assembly is broken.. I too am having the same problem.. And I am hosting easter dinner.. I am screwed, the part alone is about 100.00, http://www.applianceblog.com/mainforums/archive/index.php/t-6539.html
Mar 06, 2008 | Frigidaire FEF366 Electric Kitchen Range
Frigidaire GLEF378 Electric Kitchen Range Logo
Top Frigidaire Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Paul Carew
Are you a Frigidaire Kitchen Range Expert? Answer questions, earn points and help others
