Frequent tripping of high limit switch for HEIL Ultimate II gas furnace
Model No. CDGE075AF01
muttandjeff
  • 359 Answers
SOURCE: Rollout Limit Switch Keeps Tripping
have someone check the gas presure most likely too high no more than 11
Posted on Dec 17, 2008
FunnyPlumber
  • 43 Answers
SOURCE: where can I purchase parts?
Try Orange County Appliance Parts in Garden Grove, CA. http://www.ocapsupply.com/
Posted on Jun 25, 2009
t1m130
  • 86 Answers
SOURCE: Heil Gas Furnace Filters
the filters will go by your blower compartment remove the doors at the furnace and look where the sheet metal opening meets the furnace
Posted on Jul 26, 2009
Therinnaiguy
  • 1420 Answers
SOURCE: furnace wont start. heil gas furnace. on initial
Yes, inspect the air intake, exhaust pipe, filter and condensate piping for blockage or moisture. Also check for a hole in the hose that goes from the small exhaust blower to the pressure switch or a bad connection on the switch or control board. You may be able to temporalily jump the switch for diagnostic purposes only.
Posted on Oct 17, 2009
Therinnaiguy
  • 1420 Answers
SOURCE: I have JANITROL GAS FURNACE that the MAIN LIMIT
First, replace the limit. What causes a furnace to cycle frequently would be either a malfunctioning thermostat, a shorted thermostat wire, a bad control or the thermostats heat anticipator is not set right.
Posted on Jan 30, 2010
Testimonial: "Thaks man, And yhea the thermostat is an old dial one and full of dust i messed with the arm and probably fudged it up. "
Igniter isnt lighting
IF YOU LOST POWER WHEN FURNACE WAS RUNNING IT TRIPPED ROLLOUT SWITCHES AND POSSIBLY THE HIGH LIMIT . IN CENTER OF ROLLOUT SWITCHES IS A LITTLE RED BUTTON THAT YOU RESET . YOU CAN ALSO TRY FINDING HIGH LIMIT WITH POWER SHUT OFF TO FURNACE PULL BOTH WIRES OFF HIGH LIMIT AND USE PAPER CLIP TO JUMP BETWEEN THE TWO WIRES MAKE SURE YOU DONT SHORT OUT AGAINST ANY METAL WHEN YOU TURN BACK ON IF IT WORKS YOU NEED A NEW HIGH LIMIT SWITCH.
Jan 08, 2014 | Coleman 7990-319p Evcon Gas Furnace...
Furnace gas valve is not opening
YOUR FURNACE IS IN LOCKOUT MODE DUE TO A SAFETY FEATURE OF UNIT. USUALLY THE HIGH LIMIT HAS BEEN TRIPPED, OR YOU PRESSURE SWITCH FROM DRAFT INDUCER MOTOR FAULTY OR PLUGGED. IT WILL CONTINUE LOCKOUT MODE UNTIL THIS IS FIXED.
Dec 23, 2012 | Carrier Weathermaker 8000 Gas Furnace 125k...
How often should filters be replaced on a Heil Ultimate II gas furnace? Once at the beginning of the "heating" season and once at the end - would that be sufficient?
Hello, it depends what type of filters you are using, if you have the pleated filters such as the 3m brand they should be changed every three months If you are using the blue filters they should be changed every month.
May 03, 2011 | Heating & Cooling
I have a Ducane MPGA100B4B gas furnace. The furnace only runs for about a minute then shut off. It does this far too frequent.\r\n First the induce draft blower turned on for a few seconds to check for...
Hello, sounds like the limit switch is opening on the furnace.Usually when a furnace goes off on its high limit is becuase the airflow is being restricted making the furnace overheat. a limit switch is there to protect the furnaace from overheating, most cuases are either dirt or the blower motor not running up to speed, anything that cuts down on the airflow will cause the high limt switch to open.
Feb 24, 2011 | Heating & Cooling
I have an older model heil quaker natural gas furnace. the wiring to the blower limit switch has dry rot and melted thru causing a short. is this common? can i just rewire or may there be other problems
Test to make sure the limit switch is still working prior to the rewire. Use an Ohm meter and test for continuity. If good, use some good quality 14 or 12 guage wire to rewire. If the unit has an in-line fuse, you will need to replace that as well.
Mar 27, 2010 | Honeywell Heating & Cooling
Jan 30, 2010 | Heating & Cooling
Furnace wont start. heil gas furnace. on initial
Oct 17, 2009 | Heating & Cooling
Carrier 58 Series Furnace Blower Motor Won't Shut Off
Yes. If the high limit is tripped, the furnace will bring on the fan continuously until the limit resets. Often, they will not reset if tripped repeatedly. If the furnace is too large for your application, you probably are not able to move enough air to keep the heat exchanger cool enough.
Oct 03, 2009 | Heating & Cooling
Dec 14, 2008 | Coleman Propane Forced Air Heater...
Heating & Cooling Logo
50 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
