How can I wall mount my craig 32inch tv
I do not see any screw holes to mount to the bracket
pgh_pa_guy
  • 2992 Answers
SOURCE: What is the screw hole size in back of tv
The screw holes are metric. The set is supplied with M5x25 screws to attach the pedestal, so the wall mount screws will be in that same range.
Posted on Mar 01, 2009
SOURCE: what is the wall mounting screw diameter for a Toshiba 40xv645u
dude, im having the same problem - 5/16" wouldnt thread. I'm guessing they are metric - on my way back to Home Depot...i'll let you know what i find out.
Posted on Oct 22, 2009
  • 3 Answers
SOURCE: Tv didnt come with screws....
The size is #8-40 X 3/4". This is a specialty screw, so you're screwed
Posted on Dec 13, 2009
budmrtn
  • 11361 Answers
SOURCE: screw size to bolt panasonic 32 inch lcd into
Metric M5 or M6, they should come with the mounting kit.
Posted on Dec 23, 2009
SOURCE: TV wall mount screws for Dynex 32" TV, which size?
Orchard supply.....Metric Cap Screw size:
M6-1.0 x 12MM
They come 2 to a package for about $1.39
Posted on Jan 30, 2011
Wall mount Sanyo LCD-32xr8DA
look at the middle of the tv the 4 screw mount thats wre the tv wall mount gos. good luck
Jun 15, 2013 | Televison & Video
Can i wall mount a 32" Craig hdtv, if so how?
There are usually 4 holes on the back of the set for wall mounts. The tv wall mount will explain how to do it when you purchase it.
Dec 29, 2012 | Craig Televison & Video
I have a 32inch Digimate flat screen 2005, can i put it on a wall support?
you can buy wall supports at walmart the are 2 or 4 holes on the back of the tv you use to screw the mount plate to.
May 02, 2012 | Televison & Video
Hi I have a digimate tv model modl lt321c2m1 and I am wondering if I can mount it on the wall. Can I?
Please look on the back, there should be 4 mounting holes (for Metric screws) Iin what is called VESA mounting pattern. Just measure the pattern.
http://en.wikipedia.org/wiki/Flat_Display_Mounting_Interface
When you buy the mounting bracket, it will come with a bag of Metric mounting screws to attach your TV to the bracket.
Jun 13, 2011 | Digimate DGL32 32 in. LCD Television
What type of screw is needed to connect the bracket to the back of my 32inch emerson tv?
You would use vesa screws 4mm x 10mm - for non-recessed vesa mounting holes.
4mm x 20mm + approx 1ccubewi_0.pngm spacer - for recessed vesa mounting holes
Mar 28, 2011 | Emerson LC320EM9 32 in. LCD HDTV
I need to know the size of screws i neddto wall mount my tv
First you need a tv wall bracket made for that tv's weight and size to have a safe tv on your wall. The tv must be secured properly or it might fall. So the screws would come with this mounting kit and if they didn't I would fined out were they are. You must mount to a strong structure, like a stud in the wall or a metal frame built for it. The screws that I would use if might mounting kit did not have them would be as big as they would fit in the mounting bracket holes and that all the mounting holes wear being used and long enough to not be pulled out and in the stud about 3/4 of the way through the stud. They would be a good metal screw with a washer and the right threads for what ever material you are mounting it to. Thanks
Oct 05, 2010 | Televison & Video
Mar 01, 2009 | Panasonic Viera TH-42PZ80U Plasma TV
How do i attach a Wall Mount to the TV?
Hi, Ok, great.Look at the back panel and you can see four holes spaced 4" between the top and bottom, and 16" from side to side. these are for universal mount. http://www.bestbuyplasma.com/Plasma/tvmounts_land.asp I think this clears your problem regards sreejith "Please use caution if wall mounting this product. Follow all directions from the manufacturer of the wall mount and be sure to securely fasten the product to the mount. While the TV can be wall mounted, improper wall installation may void the warranty."
Jul 16, 2007 | Akai LCT3285TA 32 in. LCD Television
Televison & Video Logo
183 people viewed this question
Top Televison & Video Experts
