Tv remote code for toshiba mw20fp3
Need universal TV remote code for Toshiba TV mw20fp3 for universal remote RCA RCR425R
ctf1800
  • 4402 Answers
SOURCE: tv remote setup code for toshiba
Remote codes
http://www.remotecentral.com/index.html
Posted on Feb 22, 2008
aprmaejun
  • 97 Answers
SOURCE: philips remote codes
http://www.remotecodelist.com/remotes/magnavox/Philips-Magnavox_PM525S.pdf
This is the user's manual for a Phillips remote control. There is a list of codes in it. They should be rather universal. There's also instructions as to how to program it. I believe that there is a way to program it without using the codes.
Programming with Code Search
1. Manually turn on the device (TV, VCR, etc.) to be controlled.
2. Press and hold Code Search button until the red indicator stays on. Release the Code Search button.
3. Press and release the desired mode button (TV, VCR, etc.). The red indicator blink, then stays lit.
4. Press the Channel Up button repeatedly (up to 300 times) until the device could be controlled changes channel. The red indicator blinks, then stays lit. If you accidentally overshoot the code required, press the Channel Down button to backtrack through the library until the device changes channel. Pressing Channel Up changes direction to forward again. Press and release the Mute button to install the code.
Hope this helps :)
Posted on Jun 22, 2008
AvioriX
  • 689 Answers
SOURCE: PHILIPS CL034 UNIVERSAL REMOTE
Hi
I am attaching a link that you can obtain free user's manual which contains step by step instructions and code list. Click on the link below
http://rsk.imageg.net/graphics/uc/rsk/Support/ProductManuals/1500115_AD_EN.pdf
Good Luck
Posted on Nov 10, 2008
SOURCE: tv codes for a rca universal remote controller
need remote control codes for a toshiba 32A35 with a rca remote
Posted on Jun 24, 2009
SOURCE: need code to program toshiba tv with Direct tv remote
someone esle found this.. and it worked for me
Program AV1 with 20695, program TV with 10765, then switch to AV1, press select/mute, enter 933, and press select
This will allow volume and mute controls while in DTV mode and allow power on and off while in TV mode. This worked for me on the RC32 remote control.
Posted on Aug 28, 2009
Tv code
Buenos Dias, por favor estea necesito de su ayuda Ojala que la ONU su alcanse de Hacerlo, control tengo remoto de la ONU (RCA universales D * 770) y necesito el Codico p?rrafo Este tipo de televisi?n. TOSHIBA 37 " Muchas Gracias.
??? tv-code-wfb10cpomwor51hin1oy0zit-5-0.jpg ??? tv-code-wfb10cpomwor51hin1oy0zit-5-5.jpg
Good Morning, please this need your help UN Hopefully your alcanse do, have remote monitoring of the UN (RCA universal D 770) and I need Codico paragraph This kind of television. TOSHIBA 37 " Thank you.
Jun 10, 2013 | Universal Remote Control Remote Control
I have a RCA RCU400c remote control and need codes for a Toshiba 32a33 TV
Hello
Codes for Toshiba with RCA RCU 400 universal remote control are:
016, 049, 052, 044
OK.
Jun 29, 2011 | Toshiba 32A33 32" TV
I have a toshiba universal remote model ct-90121. I need the program codes and programing instructions for an rca tv
According to Toshiba, the CT-90121 isn't a universal remote control. This remote only works with TOSHIBA TVs with the following model numbers:
32AFX62, 32AFX63, 32HFX72, 34HDX82, 36AFX62, 36AFX63, 36FX72, 36HFX72, 42HDX52, 42HDX82, 50HX70, 57HDX82, 57HL83, 57HLX82, 65HDX82, 65HLX83
Unless you posted the wrong remote model number (?) your Toshiba remote isn't going to work with your RCA TV.
Please rate this solution if you find it helpful. Thanks!
Nov 02, 2010 | Toshiba Televison & Video
I need to program an RCA universal remote for a Toshiba TV
Ideally I need the exact model number of the RCA remote you are using as these remotes use different 3 or 4 digit codes.
However I have listed the common codes RCA use for Toshiba. You will need to go through them, one by one, until you hit on the one that works for your particular Toshiba TV.
If for some reason these codes do not work - please post up the exact model number of the RCA remote and I will look at it again for you.
1) Common 4 digit codes for Toshiba
1000, 1048, 1072, 1105, 1109, 1118, 1160, 1190, 1241.
2) Common 3 digit codes for Toshiba
000, 048, 049, 071, 072, 073, 105, 109, 117, 118, 160, 161, 162, 190, 201, 207, 283.
Hope this helps. If so a rating is appreciated.
Otherwise please post additional information as requested.
Thanks for using FixYa.
Jan 08, 2010 | RCA Universal Remote Control
Need Toshiba remote access code for this product so I can use a universal remote to operate the VCR and DVD
remote codes are set by the manufacurer of the remote not the tv. if there are any others not listed in instructions for remote, the manufacturer of remote would have them. most combo unit are not able to be programmed into universal remotes due to the fact that there are alot of specialized function buttons on original remote. you can obtain a replacement remote thru toshiba
May 16, 2009 | Toshiba MW24F51 24 in. TV/VCR/DVD Combo
Tv codes for a rca universal remote controller
Programminng an RCA remote cotroller for a Toshiba ,CE19H15 model
Jan 25, 2009 | Televison & Video
Can't find code for my RCR312W to work on my Toshiba TV. I tried all different codes. Any suggestions?
Have you tried these codes?
Code 1000 for Toshiba TV Code 1048 for Toshiba TV Code 1072 for Toshiba TV Code 1105 for Toshiba TV Code 1109 for Toshiba TV Code 1118 for Toshiba TV Code 1160 for Toshiba TV Code 1190 for Toshiba TV Code 1241 for Toshiba TV
Sep 10, 2008 | RCA Universal Remote Control
Lost my manuel "codes" to my rca universal remote control crk74ba3
magnavox codes, 11454, 10054, 10030, 10706, 11990, 11963, 11944, 11931, 11904, 11525, 11365, 11254, 1198, 10802, 13=0386, 10230, 10187, 10186, 10179, 10096, 10036, 11028, 10024, 10020
Nov 07, 2007 | RCA Universal Remote Control
Televison & Video Logo
124 people viewed this question
Top Televison & Video Experts
