Question about Miller TELEVIDEO 995 TERMINAL W/ GREEN SCREEN (TV995GREEN) Network Terminal
Green Screen instead of Blue
We have an Olevia flat screen tv and the background is green instead of blue. the green filters through into the picture, especially when watching a movie. Any idea what's causing it? The TV, DVD player, etc?
  • 77 Answers
Check the picture settings on the tv, if that is not the problem, then check all of your connections (RGB cables+RW Audio) that is HD component, if you have both HDMI and HD component then try one of them, or it may be a switch in the back of the DVD player or TV
Posted on Jan 14, 2009
Tv powers up to green,but just lights up dark blue screen,nopicture,sound,etc.
I just answered that a while ago, why do you people ask the same thing several times?
Sep 30, 2012 | Dynex DX-LCD32-09 LCD TV
32inch proview lcd tv has a green square instead of a picture,but i get the sound .?
if you are getting color on the screen, chances are that you might have a cable loose. I'm not sure if you are using component cables but sometimes when the blue cable is loose, it will cause a green screen. or if you are trying to watch something above your TV's capabilities, this will happen as well.
May 04, 2010 | Proview HX303 30 in. HD-Ready LCD...
There is too much green color, i tried hue - contrase - lite etc. but the color is still green
how do i get the red and green hue back on my olevia 227-s11 tv my screen is blue and brown
Dec 09, 2009 | Syntax OLEVIA LT20HV 20 in. LCD Television
The color on the screen is green when I watch movies. How do I fix this problem?
Good day sir, your inquiry about the green lcd screen can be caused by several things. 1. The monitor/tv produces 3 colors, red green and blue, the tv mixes these three colors to produce the picture. a loss of red and blue produces this green screen. so check the cable, specially the red and blue jack of the component inputs, and the red and blue cable. 2. there may be loose contact on the signal cable. try using the video input instead of the component input. 3. the dvd player may have the problem, check the player component out jack. a loose jack port can cause these problem. hope this may help. thanks
Jul 20, 2009 | Toshiba 32AV502U 31.5 in. LCD HDTV
Green purple and blue bars rolling through screen
It is probably the main total assy needs to be replaced.
Jun 26, 2009 | Samsung LN32A550 32 in. LCD TV
My set has a RED background on all Inputs--DVD,Sat, Recorded DVR.....when playing a DVD a Bright Blue FBI screen is normal and the Bright Green Movie Rating Screen is Normal but the picture is RED....
I found a way to get into the service Display, 5 ,volume + and numbers come up---could figure out how to go to a Menu-----but somehow the picture is now perfect !
Anybody know why this fixed I said the RED background was on all input screens....the screen with no signal was a solid red instead of Black......
Jun 19, 2009 | Sony Grand WEGA KDF-42WE655 42" Rear...
Color lines out of focus
dc2eb76.jpg MikeNJ1964
Rank:guru_s.gif Guru sony.gifSony Expert
Rating: 89%, 674 votes
You have a completely different problem. The screen voltage for the blue picture tube is slightly too high on your set. This will put fine lines in the background of the picture, called retrace lines. This is very common and easy to correct. Remove the front speaker cover and the access panel behind it. Look inside and you will see a black box with six controls, each control having a little white glue on it. This is the Focus/Screen block. Three controls are labeled Focus and three are labeled Screen. The screen control in the center is for green but I am not sure if the screen control on the left or right is for blue for your model. With the TV on, set it to VIDEO 1 but do not connect anything to the VIDEO 1 jacks. This will produce a pure dark picture, showing any faint lines in the background. Choose one of the screen controls and increase (turn clockwise) it slightly. If the blue lines do not get brighter it means you are turning the red screen control, so put it back where it was and choose the other screen control. When you find the blue screen control, decrease (turn counter-clockwise) it until just when the blue lines are gone. If you want you can check that the red and green screen controls are set to just below the point where their faint lines are visible. When done, replace the panels and your picture will be back to perfect.
Did you think this was helpful? Yes No
new MessageRate('spn1737581','spn1737581cnt','spn1737581stats','spnRateWord1737581','div1737581_yes','div1737581_no','imgStar1737581','ancChangeRating1737581','divChange1737581',1737581,0,0,0,false); Solution #2 posted on Jul 04, 2008 Asker's Rating 0%20stars_w.png
noavatar_s.gif gator149
Rank:nonexpert_s.gif Apprentice sony.gifSony Expert
Rating: 0%, 0 votes
MikeNJ1964 was exactly right! I have a Sony KP-65WV600 that had horizontal green lines that showed when the picture was darker. I had to remove 3 screws on the right and left side of the tv holding in the speakers...carefully pop out the middle panel from the clips holding it in....remove 4 screws from the cardboard in the middle and remove the cardboard. I then saw the six screws. The adjustment screws were the three below. I turned the middle screw until the lines dissapeared. I tried the left screw and blue lines appeared which I then adjusted away.
THANKS a bunch. SAVED me money!!!
May 15, 2009 | Sony KP-65WV600 65" Rear Projection...
Green Screen
Hi, how is the cable box hooked up to the TV? Is it HDMI cable or componet (red/green/blue) ? When you say totally green, do you mean the the picture is only green with the other colors missing or every color looks green ?
Mar 14, 2009 | Protron PLTV-37 37 in. LCD Television
Computers & Internet Logo
136 people viewed this question
Top Miller Computers & Internet Experts
mukhtar21 shaikh
mukhtar21 shaikh
ray gallant
GreenHotrod Hotrod
GreenHotrod Hotrod
Are you a Miller Computer and Internet Expert? Answer questions, earn points and help others
