Question about Dryers
Maytag MED9600SQ0 dryer squealing noise - Dryers
  • 3 Answers
SOURCE: Flashing "touchup" and dryer won't start
What I did was unplug it for 1 min., plug it back in. Push the "off" button once, then push the off button again and hold it for 10 seconds. This is supposed to reset the computer. It worked for me.
Posted on Nov 14, 2007
SOURCE: My Maytag dryer makes an aweful noise.
Typical parts that wear out and get noisy on that model are the two drum rollers (part # 12001541), the front drum glides #306508, the idler pulley Y303705 and the blower wheel 303836. None of these parts are very expensive, but to do all of them would definitely add up to the point that you might want to think about whether or not you want to keep the machine in operation especially after 10 years of good service.
Posted on Jan 04, 2008
CMV9
  • 594 Answers
SOURCE: Dryer Noise
You need to have you belt replaced. Over time the belt will strech.
this causes the dryer to still spin but the belt will sometimes loose the grasp of the drum and cause the belt to spin only.
This happens because over time with heavy loads of towles and jeans pull down on the drum as it is being loaded. Than when in cycle the jeans will drop from the top to the bottom pulling aginst it even more..
Posted on Aug 14, 2008
Healeyman
  • 1198 Answers
SOURCE: Maytag Atlantis Dryer squeals
Try Repairclinic.com for help and parts. You are going to need heat resistant grease, and probably snap ring pliers.
Posted on Apr 28, 2009
hunter19_46m
  • 7482 Answers
SOURCE: Dryer makes a loud squealing when first started
ALWAYS UNPLUG YOUR DRYER BEFORE STARTING ANY REPAIRS
Your problem sounds like drum rollers have flat spots on them or in need of lubrication, or maybe your belt has slipped off of the idler arm pulley.
If you have a front loading machine, Remove the electrical console that holds the timer switch, start switch, etc. from the top of the dryer. Be REAL CAREFUL not to knock any of the wires off of the timer switch. Then remove the top of the dryer. Remove the front of the dryer. This will expose the drum and belt. Remove the drum and belt and this will expose the drum rollers, idler arm pulley and motor. Now is a good time to check the belt to see if it has slipped off of the idler arm pulley and also to check the belt condition for wear. Be sure to note the route of the belt, this will come in handy when you go to reinstall the belt. Check your drum rollers for flat spots or wear, if they have flat spots or wear on them replace them. If the drum rollers don't have flat spots or wear on them then they probably only need lubrication. Lubricate the shaft of the rollers with a good grade of machine oil such as 3 in One oil. Reassemble the dryer, plug back in. This should solve your noise problem. I will include these two websites for parts and further help: http://www.partselect.com/ http://www.appliancepartspros.com/index.aspx Both also have chat assistance 24/7. Good Luck, I hope this helps Please rate me, Thank You
Posted on Dec 05, 2009
Testimonial: "Removed the drum and oiled the various rollers Quieted the noise. Sounds like a new one again. Thanks "
How to fix Maytag dryer MED9600SQ0
Check the thermal cut off, the cycling and the hi limit thermostats.
For continuity or OHMS. If no ohms or resistance they need replacement.
In some dryer's the control panel relies on a thermistor rather than a CYCLING thermostat to regulate the drum's air temperature by monitoring the component's resistance changes; resistance goes down as temperature increases and up when temperature decreases. Once the drum's air temperature reaches a certain level required to dry clothes, the control panel shuts off the heater. The panel will turn the heater on again and begin another heating cycle when the thermistor indicates that more heat is needed to keep the air temperature constant inside the drum 9 this is why in some cases the dryer will operate at lower cycles like gentle or low heat but not at higher settings?)
Lastly check your moister sensor. ( located inside the dryer door usually) Especially if machine seems to shut down early and clothes are still wet.
Test with a meter at room temperature and it should show continuity.
A failed moisture sensor will affect the dryer run time in the automatic moisture sensing cycle but it will not affect the heating of the dryer or the timed cycle. Which are reflected by the thermostats.
Read more :http://www.ehow.com/info_12203962_check-dryer-thermistor.htmlGOD IS So GOOD !!!! AND THAT'S WHY MY ADVICE IS FREE
Jan 26, 2016 | Maytag Dryers
Dryer squeals then quites then squeals
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
Asker's Testimonial "That answer was very informative - thank you fortaking the time to educate me. " - teresa241964
Oct 25, 2010 | Maytag MDE308DAYW Electric Dryer
Maydryer is squealing Maytag MDE5500AYW
heatman101
Asker's Testimonial "That answer was very informative - thank you for taking the time to educate me. " - teresa241964
Aug 26, 2010 | Maytag Neptune MDE5500AY Electric Dryer
Maytag electric dryer is making a high pitched noise
The squealing noise is from the belt tensioner. Replace the pulley only on the tensioner along with a new belt. The bearing in the pulley is causing the squeal. Sears will sell this in a kit. The top and the front panel of the dryer will have to be removed to replace these parts
Jul 16, 2010 | Maytag Dryers
Extreme squealing noise
heatman101
456yt
Jan 30, 2010 | Maytag Neptune MDE4000 Electric Dryer
MAKING SQUEALING NOISE
heatman101
fgsj
Oct 19, 2009 | Whirlpool GGW9250PL Gas Dryer
Maytag gas dryer squealing
Hi, this is a belt issue. make sure the tension on the belt/motor is sufficient. adjust to specs. if the belt is fine, this will be bad bearings in the roller assembly.
Replace the rollers in this case.
May 21, 2009 | Maytag Dryers
Maytag electic dryer noise
First, pop up the top of the dryer -- use a large slotted screwdriver under each corner of the top. There will be screws holding the front of the dryer -- take these out and take the front off. The squealing is coming from roller bushings which need lubricating. Apply machine oil to all the axles/bushings -- this most likely will stop the squealing -- and don't forget to unplug it first.
Apr 23, 2009 | Maytag Dryers
I have a maytage front load washer,it is stuck in control lock ,and i can't get it to do anything. the model#is mfw9800tq0. washer
med9600sq0 model #
as per maytag website=hold the "cycle signal button for 3 seconds" and it w i l l unlock. I just did it!!!
Aug 02, 2008 | Dryers
Dryers Logo
52 people viewed this question
Top Dryers Experts
