Question about LG WM-1832C Front Load Washer
Small ammount of water leaks at bottom of door during wash
Wm 1832cw washer leaks small ammount of water out of the bottom of door during wash cycle
  • sanregj Jan 12, 2009
    Door leaks from bootom
    New Friend:
  • 14 Answers
Open the door. At the bottom of the gasket on the machine there are three little holes. The is where the water drains. Make certain they are not plugged. Use a close hanger or tweezers to pull what's pugging it or push in threw to unclog it. If that doesn't work, look to see if the door is crooked.
Those things get clogged easy if you have pets that shed hair. Should be checked once a month.
Posted on Jan 24, 2013
    Problem Solver:
  • 3 Answers
I have this same problem. What I do is carefully clean the part of the glass door where it meets the rubber gasket when you close the door. Bits of crud tend to accumulate there and break the seal between the smooth glass and the rubber gasket. This causes small amounts of water to leak out.
I don't use an abrasive cleanser. I generally clean it when it is dry and crusty with my hand or with my fingernails if it stubborn. You don't want to scratch the smooth glass surface. fingernails are much softer than glass and won't scratch the glass.
I also take a look at the rubber gasket and see if there is any crud sticking on that and very gently clean it off when it is dry and crusty. If the gasket gets torn, you'll probably need to replace it. I don't know how much that would cost. This should stop the dribbles.
Cheers,
Zac
Posted on Jan 25, 2009
When is a dishwsher supposd to drain? Is pump working correctly?
normal to fill pan during wash and rinse fix door seal if it leaks
Jun 15, 2015 | KitchenAid KUDE40FXSS Builtin Dishwasher
Washer will fill up with water but will only spin
is it noisey on spin? sounds like control board to me. try this , open door and turn steel bowl by hand, left then right. if u can turn the bowl in both directions it is not the bearings. please reply 4 more help.the bowl should turn free in both directions.
Apr 14, 2010 | LG WM-1832C Front Load Washer
Water leaking bottom front door
Check out the front seal carefully for a replacement. Due to the flexibility of the seal, it is not to easy to spot a tear mark, Under pressure of an operation load, a small tear will allow water leaking through, so there is a leak. It is very common that a hard sharp object left inside clothing and during washing cycle, it makes its way to the seal and cause a damage. Hope this can help.
Jan 08, 2010 | LG WM2487H Front Load Washer
Maytage MAH6500AWW Overloaded washer now leaks when filling
since you can drain it
take off the back and watch what happens when u turn it on
i believe you make have a loose drain connection
Oct 09, 2009 | Maytag MAH6500 Neptune Front Loading...
During the wash and rinse cycle I have water seeping out of the bottom of the door on my LG washer. WM2277HW.
Give a good clean around the door seal and make sure you close it firmly.This does usually fix it but you can also twist the door manually to help the seal.
Oct 04, 2009 | LG WM-2277HW Front Load Washer
My machine has a small water leak though the door during washing
Replace the gasket. Or make sure that the gasket is sealed properly
Feb 10, 2009 | LG WM-2032H Front Load Washer
Water Leaking from pre-wash and main wash cold water solenoid
We had the small leak problem. It was a cut in the bellows at the door. Lower side. We could see it if we just spread the gasket just inside the door.
Jul 14, 2008 | LG WM-2277HW Front Load Washer
Leak
It sounds like you have a leak somewhere around the door bellow. This is the rubber boot that seals the wash tub to the door frame. Pull the folds back and inspect around the entire perimeter of the rubber. You could have a small rip or tear somewhere. There are a series of small holes in the bottom of the bellow that are supposed to be there. This is the allow any standing water to drain back into the wash tub. If you cannot find any obvious signs of leaks, remove the lower panel under the door. This is accomplished by removing the screws under the bottom edge of the panel. With the screws removed, the panel will drop down, then off. Start the washer on a normal wash and watch for any leaks. If the door bellow leaks, the front counterweight (usually a concrete block) will begin to get wet and drip. This could also be an indication of the bellow clamp around the wash tub being loose. If the leak starts to pool under the washer and run out the front, this is usually an indication of a drain pump leak or drain line leak. Please inspect the washer with the panel removed and the washer on a load and post back and let me know. Go to my profile and use the "Ask Me" feature for a quicker response. I hope this helps you.
PS One other item. On the left hand side of the door bellow is the a dispenser tube that penetrates through the bellow and allows water to enter the wash tub. Sometimes the dispenser tube is not seated all the way into the rubber (should be seated past the flange) and it will dispense water behind the rubber instead of into the wash tub. Just something else to consider...
Jun 20, 2008 | Whirlpool Duet GHW9150P Front Load Washer
KHWS01PWH0 Front Loading Automatic Washer Leaking
out the bottom of door?? no through the bottom panel???. check the rubber door seal for rips or tears pull it back and look around entire circumference. smalll rip in very front of seal where door should close against will cause leak for sure
Mar 07, 2008 | KitchenAid KHWS02RMT 3.7 Cu. Ft. Ensemble...
LG WM 1832CW
if your getting LE code on your LG washer check if your hot and cold water is hooked up right
Jan 27, 2008 | LG WM-2277HW Front Load Washer
LG WM-1832C Front Load Washer Logo
341 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
