SOURCE: ps3 won't load assassin's creed but loads other games/dvds
yes immediately after loading the ps3 , it looks for the online update..if no internet connection is present , the screen will go black or freeze up
SOURCE: my assassins creed wont load????
If you all are still having this problem, this is what I had to do. There are 2 places where you have to go in to and delete the assassins creed game data. One is the normal save data, but there is also a place with the game data that is corrupted. If you go in and delete both the save data AND the game data, it should reload all of that the next time you put the disk in and allow you to play.
SOURCE: since i got assassins creed my ps3 was freezing a lot
Oh dear, i'm afraid to say you've got one of the 'fatal' error codes. The error you're encountering means there is a major problem with the blu-ray drive (you're PS3 is pretty much shot)...
The only thing you can do is ring Sony's tech support and arrange for a replacement console. If you are still under their one year warranty, you will get a replacement console free of charge
or if your console still works just dont play that game
if it keeps freezeing its becuse of the blu-ray driver :( you would need to try setting it to factory def's or if that does'nt work try rolling back the firmware upgrades........or just buy a xbox 360..
SOURCE: assassin's creed 2 registration of the trophy
you cant every1 is having the same problem!!!you cant get on2 psn because the systems down apparently. we all just gotta wait it out!!!
SOURCE: my ps3 freezes while playing certain games..i.e.
try updating firmware or doing hard reset.
this is a last resort Sony support recommends.
Be sure to backup your settings/games saves by doing a System > Backup on your PS3 or you may lose your game saves! Also, this is a last resort procedure prior to exchanging/returning to sony.
1. Power Off the PS3 via the power switch in back and power back on w/switch.
2. Hold Power Button on the Front until you hear 3 beeps.
3. Then go through the initial setup and then run a full Format via System > Format. (will take approx 3 1/1 hours). You may need to have our AV cables ready if your using HDMI (in case HDMI isn’t detected after initial reset).
4. Restore your backup you made prior to doing factory/hard reset (optional, if you created a backup).
Hopefully this will solve your freezing problems.
Problems/symptons that this appears to have resolved:
-freezing when doing anything
-no harddrive activity
-freezing when trying to use onboard keyboard or bringing up keyboard
-game/movie disc freezes system
