Wiring scematic for heil model nulk075dg05 gas furnace
Model nulk075dg05
5 Suggested Answers
t1m130
  • 86 Answers
SOURCE: Heil Gas Furnace Filters
the filters will go by your blower compartment remove the doors at the furnace and look where the sheet metal opening meets the furnace
Posted on Jul 26, 2009
gear001
  • 59 Answers
SOURCE: HEIL FURNACE W/ WHITE-ROGERS GAS VALVE 36C84/410
The problem might be with your safety switches other than you gas valve poilte
Posted on Oct 12, 2009
Therinnaiguy
  • 1420 Answers
SOURCE: furnace wont start. heil gas furnace. on initial
Yes, inspect the air intake, exhaust pipe, filter and condensate piping for blockage or moisture. Also check for a hole in the hose that goes from the small exhaust blower to the pressure switch or a bad connection on the switch or control board. You may be able to temporalily jump the switch for diagnostic purposes only.
Posted on Oct 17, 2009
Therinnaiguy
  • 1420 Answers
SOURCE: i have an older model heil quaker natural gas
Test to make sure the limit switch is still working prior to the rewire. Use an Ohm meter and test for continuity. If good, use some good quality 14 or 12 guage wire to rewire. If the unit has an in-line fuse, you will need to replace that as well.
Posted on Mar 27, 2010
Heil nulk075dg05
You have a dirty or bad heat sensor. When you remove the front panel on you furnace you will see a probe that is 2 or 3 inches long that is in the flame when the furnace fires up. If it doesn't detect a certain temperature within the first 30 or 40 seconds it shuts down the furnace. You can either clean the probe off with sandpaper, or purchase a new one. They aren't very expensive and are easy to replace. In my experience it is usually a build up of carbon on the sensor and a good cleaning with sandpaper and alcohol usually takes care of the problem.
Feb 04, 2014 | Heating & Cooling
Heil furnace lights but wont stay lit 1990 model
Here is a tip that will help you try to figure out why your furnace is not working.
Basic Furnace or Heating System Troubleshooting
heatman101
Mar 04, 2011 | Honeywell International Heil Quaker...
We recently purchased a home with a heil furnace and I need to know what size filter it requires. It is a gas heil model # NUG1075DF01. Please help !
That is hard to answer but I would say that for a furnace of that size you are probably looking at somewhere around 16x20x1. On older heil furnaces they often had the filter mounted inside the blower compartment so if the case you can just remove the cover and measure it. If not it should be located on the return air duct close to the furnace. Hope this helps you some. Thank you.
Dec 30, 2010 | Water Heaters
Furnace wont start. heil gas furnace. on initial
Oct 17, 2009 | Heating & Cooling
Jul 17, 2009 | Heating & Cooling
Heating & Cooling Logo
61 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
