Question about Kitchen Ranges
I have an amana gas cook top model number AKS3040SS and need to take it apart to replace 2 of tne gas controls how do i go about this
2 Suggested Answers
  • 41 Answers
SOURCE: I have an amana gas stove model ARG7800WW . The
u need a new clock , or the oven wont work , u can bypass the clock to get the oven going but u need to know which two wire to join
Posted on Oct 27, 2009
My Maytag glass cook top PER5710BAQ stove has broken cook top are the similar product model tops compatible or do I need to buy the exact top... IE could I buy an amana cook top or whirlpool since they are...
It will depend how the tops electrical terminations are. Many internal/fuses/switches/elements are the same, but though may tag is the parent manufacturer it always isn't interchangable. Like a Pontiac g6 and Pontiac sunfire...
They're both 2 door cars
Both made by Pontiac
Some parts are identicle
But some aren't.
Nov 12, 2014 | Kitchen Ranges
Amana Gas Cookertop flame goes out on burner but gas keeps flowing
which burner goes out on you when you use it. the front. the back. the left side. the right side. or all of them
Jan 04, 2013 | Kitchen Ranges
Was cooking I'n oven. Heard a big pop sound and saw lghtning I'n tne oven. Now oven will heat a little but won't cook or broil ?
That sounds like the heating element went out when it first goes it could look like a lightning strike. Replacing the bake or broil element ,depending which one was on at the time will fix your oven. If you were baking replace bake element if ya werebroiling replace that one.
Reply with EXACT model number and i'll give ya the part number
GENE
Aug 27, 2011 | Frigidaire Kitchen Ranges
My gas oven keeps shutting off during cooking amana apartment size free standing gas oven
The ignitor is not working right and is going bad....
have the repair man replace the ignitor, or DIY....
Check out this tip about your problem...
Oven not Working or
Oven not Heating
Oven Problems Replacing the Igniter
heatman101
Jan 18, 2011 | Amana Ovens
F-3 is flashing after about five minutes of cook time
This is an oven temperature sensor problem. Check the sensor first it should have a reading of about 1100 ohms. If it is good replace the control otherwise replace the sensor. It is located inside the oven near the top, long thin tube like. Enter your model # at www.appliancehelponline.com for a diagram or illustration.
Apr 09, 2010 | Amana ARGS7650SS Gas Kitchen Range
I have an amana gas stove model ARG7800WW . The cook top works but the display (Clock Timer) doesn't light up and the oven doesn't work.
Oct 27, 2009 | Amana ARGS7650SS Gas Kitchen Range
Amana gas oven not working
The ignitor may be too weak to open the gas valve. If you have a volt/ohm meter capable of reading AMPS you can hook up to a ignitor wire and turn the oven ON. If you read less than 3.5 amps replace the ignitor. If 3.5 amps or more are read,replace the gas valve.
Aug 30, 2009 | Amana ARGS7650SS Gas Kitchen Range
One of my gas burners won't start
Only 2 potential culprits in this case.
The Control Valve (behind the control knob) is bad... or the gas outlet on top of the stove is clogged with food :D
Take it apart and give it a good cleaning or replace.
Thanks for using FixYa - a Very Helpful rating is appreciated for answering your FREE question.
Jul 29, 2009 | GE Profile Spectra JGBP90 Gas Kitchen...
Fire from top of Microwave
It's not a dangerous or diffcult job for a do-it-yourselfer.
That would be the waveguide cover (also called the stirrer fan cover), and it would need to be replaced to prevent future damage to the magnetron.
Check your model number sticker to get the full model number with suffix and the manufacturer number (PACO1860AB0 for example).
Then you can find helpful exploded view diagrams and order parts by entering your full model number here: http://tinyurl.com/gv383
Good luck and good cooking!
We appreciate your thoughtful rating of our answer.
Nov 11, 2007 | Amana ACO1860 Microwave Oven
Kitchen Ranges Logo
41 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
