Question about HP PL4260N 42 in. Plasma HDTV
My hp 42 plasma tv cptoh-0602, picture is so fuzzy. keep on blinking sometimes whenit blink picture looks good sometimes not
2 Suggested Answers
SOURCE: hp 42 plasma tv cptoh 0602 I get sound but no picture
I had the same problem today, Hp wanted $629+tax to fix. With a little mechanical ablity anyone can fix this.
1. remove back covers
2. left-hand side is the video board
3. two white fuses
4. replace
this fixed mine and they only cost $1.50 each
Posted on Nov 26, 2008
Hi! I have a 2006 HP High Def Plasma TV model CPTOH-0602, serial CNH6131576. It lost picture, I can hear sound. Wonder what couls be the problem?
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent.
Dec 09, 2014 | HP Televison & Video
LG 42PC!R Plasma TV turns on and then green led blinking with no ppicture and sound !
Your problem is most likely a fried circuit board. I always connect my good electronic to a back up battery. but your problem might have been storm or surge related, I would take it to a repair center and get an estimate.
Sep 19, 2014 | LG 42PC1R 42 in. Plasma HDTV
Picture just went out on my tv but I still have sound
I have the same problem with my HP PL4260N 42" Plasma HDTV serial # CNH6141988, model # CPTOH-0602. I have perfect sound and can change channels still with sound but NO PICTURE. I am a consumer with a question that need the advise of an expert.
Apr 17, 2013 | HP PL4260N 42 in. Plasma HDTV
HOW TO FIX DIM PICTURE ON 42 HP HPCT 0602
look for the brightness setting some where in the tools option and turn up the brightness or if it as presetting options for the display try changing those. some have a vivid option or standard and so on.
Apr 28, 2012 | Daewoo DSP4210GM 42 in. Plasma Television
I replaced the module on YSUS board and replaced the FS2 fuse on hp cptoh-0602 plazma tv. TV worked great for about 2 hrs of usage time. however, while i was changing the channal few days later since...
Usually, when you replace Y-sustain board, for older plasma, they suggest to replace both Ydrive board (up and low). And sometimes, Z-sustaint.
Im not sure your are an expertise in this matter so be very careful when you open a TV because hasardous voltages can kill you in the worst escenario.
If you are not, don't work on your TV. It will be your sole responsibility.
Check ships on Y drive board (both board are installed on the right side of Y-sustain. They have square black ships that used to get bad. If they don't have aluminum cooler on them, you can see if they are burned or have holes on them. Old plasmas use to have issues with those boards. Before you installed the Y Sustain you should check Ydrive boards. Maybe you damage the Y Sustain because the Y drives weren't good.
Try to replace the fuse, disconnect the Ydrive from Y Sustain, turn on TV and check for voltages on Y sustain (panel has a sticker with each voltage). Hope you didn't damage Y sustain and can find Ydrive board to fix your TV.
And REMEMBER, you can kill yourself when you work on TVs.
Sep 26, 2011 | HP PL4260N 42 in. Plasma HDTV
My picture is flickering but there the sound is
Did you try buying a new HDMI cable? You can also try some of the solutions in the post called "Hp 42 plasma tv cptoh 0602 I get sound but no picture."
Dec 31, 2009 | HP PL4260N 42 in. Plasma HDTV
Hp 42 plasma tv cptoh 0602 specs all the time and wavy sd video
Mine has done this from day one, appears to be a resolution problem. All I do is go to a HD channel let it tune in and then go back the the SD channel and don't have to worry about it until next time the power has cycled.
Jul 22, 2009 | HP PL4260N 42 in. Plasma HDTV
Philips 42 in. Plasma shut down
did u cheak the input cables does it do it on dvd input as well as others ?
Feb 01, 2008 | Philips 42PF7320A 42 in. Plasma HDTV
HP PL4260N 42 in. Plasma HDTV Logo
49 people viewed this question
Top HP Televison & Video Experts
Computer Links
vbalag
Level 1 Expert
Alun Cox
Are you a HP Televison and Video Expert? Answer questions, earn points and help others
