Question about Maytag Dryers
My maytag dryer model SDG305DAWW how to replace belt
captaynkyrk
  • 170 Answers
SOURCE: dryer belt replacement
remove the front panel. you may need to remove a kick panel below the front panel. the top panel connects to the front panel by some plastic push in retainers (you can loosen them with a screwdriver) You need to prop the top panel up. the belt goes over the top of the drum down to a drive wheel that is located at the bottom of the dryer.
Posted on Jul 07, 2008
ngfam1
  • 639 Answers
SOURCE: Belt replacement for a Maytag dryer - Model No. DE410
Peace Friend,
ngfam1 At your service!
There are many variables!
Every year thousands of people die trying to repair electrical appliances them selves!
You are worth more than that!
Bless you!
Only a trained laundry tech can make the electronic diagnoses.
Below I referred you to a great service nation wide!
A&E Factory Service
A&E has schedulers available to take appointments 24/7
And they do warranty work too, for most manufactures!
1(800) 905-9505 near me they only charge $75 service call which is reasonable in today s market!
Unfortunely, another point to consider!!
How old is the appliance?
If the appliance is 10 years old or more you it may not be advisable to put good money into bad!
New appliances are so much more efficient today that they can save you a lot of money in energy!!!!
Water,Electric and detergent! And put money back in your pocket!
The new appliance will pay for itself in only a few years!
You will be fine
Bless You ngafm1
*****PLEASE GIVE ME A GOOD RATING BEFORE YOU SIGN OFF*****
Posted on Sep 02, 2008
abhishek33
  • 1239 Answers
SOURCE: Maytag Neptune Dryer Model # MDE3000AYW
Motor malfunctions usually call for service by a professional. There are three main causes of motor failure: lack of lubrication, a defective motor switch, or worn or frozen bearings. A humming sound can be related to a burned-out motor or a defective switch. Check these trouble spots before you call a professional service person or take the motor to a repair shop. Here's how to check a dryer motor:
Step 1: Remove the back access panel. Then reach behind the drum, motor pulley, and idler arm pulley. If these areas are clogged with dirt and lint, undue strain on the motor may be causing the humming noise. Worn or broken belts can also cause a humming noise. Check the belts for wear and damage. If the belts look all right, you may be able to stop the noise by spraying them with fan belt dressing, available at automotive and hardware stores and home centers.
Step 2: Turn the dryer on. The noise you hear may be the whirl of the spinning drum, not the motor. Some noise is normal.
Step 3: Force a little 20-weight nondetergent motor oil (not all-purpose oil) around the ends of the motor shaft. This lubrication may stop the humming noise. If this doesn't solve the problem, remove the motor and take it to a professional service person.The centrifugal switch on the dryer motor may be located on top of the motor. Humming, no motor power, and no heat can be caused by a faulty centrifugal switch. If the switch is externally mounted, check the terminals of the switch to make sure they are tight and not burned. If you spot trouble, remove the switch and take it to a professional service person for testing. A faulty switch will probably have to be replaced. Some centrifugal switches are located inside the motor housing; you won't be able to remove the switch in this case. Remove the entire motor and take it to a professional for repairs.
If the motor hums, but won't run the pulley on the end of the motor shaft, try turning the pulley by hand.Caution: Before turning the pulley, make sure the power to the dryer is turned off.
Posted on Sep 12, 2008
  • 4 Answers
SOURCE: replacing maytag dryer belt
looking at the back of the motor where the belt pulley is you would grasp belt coming down from the left side of drum then come across the top of belt pulley that is on motor shaft going clockwise around that pulley then continue back to your left and over the top of belt tension pulley going counterclockwise around that pulley this is when you will have to raise pulley against spring pressure to get belt on then release belt tension pulley make sure that belt is still in belt groove on the drum hope this helps ed
Posted on Nov 01, 2008
  • 66 Answers
SOURCE: LDE412 MODEL MAYTAG DRYER, LOUD SQUEEK
Are you sure that is the model number? I can`t find that model number anywhere. Please check the tag on the machine. This tag should also have the serial number on it.
Posted on Nov 13, 2008
How do you open the casing, without causing damage, on a Maytag model # sdg305daww?
There should be several screws at the back holding the lid in place. Remove these screws and slide the lid forwards and lift it off. Remove the back cover and this will give you access to all the other sides and much of the mechanism of the machine.
Apr 12, 2011 | Dryers
MAYTAG GAS DRYER MODEL SDG305DAWW. THE IGNIGHTER GLOWS BUT DO NOT REVEIVE A FLAME
Your igniter is working fine. The problem is the flame sensor needs to be replaced. The flame sensor is a safety feature. If it doesn't detect heat from the igniter it prevents the gas from flowing. A new flame sensor will cost about 30 - 35 dollars. You can buy on online here
Jun 23, 2010 | Dryers
It takes hours to dry the clothes. The dial moves
sounds like a bad timer. if it sticks every time replace they are expensive
Mar 25, 2010 | Maytag Neptune MDG5500AW Gas Dryer
Model SDG305DAWW, gas unit...begins to dry and then stops...timer stops and unit continues to tumble but no heat...turn unit off and wait for about 2 hours then can dry again....replaced cycle timer,...
Sounds like you have the same problem I did. You need to replace the flame sensor. Takes about 15 - 30 minutes. You can order the part online here
Feb 06, 2010 | Maytag Dryers
Maytag gas dryer model SDG305DAWW. make a loud squeaking sound when you turn the dryer on. After about 30 seconds it goes away, but has been lasting longer each usage.
Your problem is most common caused by a failing/loosening drive belt that turn the dryer bask by an electric motor.
If you are not familiar with how to replace belts (like the kind on your car engine compartment, I strongly recommend you hire a professional.
Aug 11, 2009 | Maytag Dryers
Maytag gas dryer model # SDG305DAWW
replace the coils atop the burner assy itself, part number 279834..
Dec 02, 2008 | Maytag Neptune MDG5500AW Gas Dryer
No heat
Dryer Heating Element
Oct 29, 2008 | Maytag Dryers
Dryers Logo
48 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
