Question about HP PSC 1610v All-in-One Printer
Mp computer wont open networking it tells me mp spooler in not working I added and organized my pc incorrectly my comp. does not install programs downloaded from web
  • Doug Linday May 11, 2010
    Sounds like you may have a security problem. Make sure you are the administrator by going to settings then users. If you are not the administrator I can’t help you. Some other geek here may. Good luck.
    Doogie
    Problem Solver:
  • 8 Answers
Go to start and then run type services.msc and look for mp spooler make sure that the start up type is set to automatic and started.
Posted on Apr 06, 2010
On the internet, on my computer download Programs or Add-ons, it wont install progams or add-ons on my pc, says i'm not hot up to the internet/OS XP
you may have the wrong ethernet driver.Right click on internet icon and click on troubleshoot problems it will tell if theres a problem.
Jan 15, 2014 | Dell Dimension Computers & Internet
Computer starts but moniter stays in sleep mode .. moniter works on different comp .. will adding a vid card to my comp fix this problem ??
Actually, Yes. It seems like you have answered your own question... Especially considering the monitor works on another computer.
Do you have another monitor to test on this computer?
Although another consideration could be if you recently installed or downloaded a program which may have changed your video output range to a setting your video monitor wont handle. If this is the case and you can start the computer in safe mode, this will allow you to go into your properties settings and change it back. This way, a new vid card is not req.
Good Luck
Sep 14, 2012 | HP Compaq dx2300 Microtower - RT950UTABA...
Kodak printer not detected
Check in your Control Panel (Printer & Faxes) if the printer is OFFLINE. Via wi-fi network, obtain the IP Address both of Printer & your computer.
Aug 06, 2009 | Kodak ESP 5 Printer
Comp will not connect to internet and tells us there is a cable not connected. It is wireless and the modem is working with all other comps in house. I have checked the modem, switched it off and...
have you installewd the drivers for the modem ? if you have go to desktop and click settings got to network settings open this up it should show any connected networks if not click new connection then go throught the proceedure you can try the first internet connection if not try the advanced option for the wireless.. make sure you installed the wireless drivers as well a it wont work without these.. Good Luck A
Jun 30, 2009 | Advent Netbook
HOW TO INSTALL EASY DVD COPY 4
If you actually purchased it, then just make up a user name and organization, but you'll need the serial number which should be on the back of the cd cover. If you don't have that, you're out of luck.
Jan 30, 2009 | Roxio Easy DVD Copy for PC
CANNOT FINISH INSTALLATION OF ROXIO CREATOR
if that is all just enter your name and for organization make something up.
Dec 25, 2008 | Roxio Easy CD & DVD Creator 6...
Cannot install my Cannon mp 210 printer
Hi, the spooler service is usually set to start automatically when the PC starts up. It sounds as if this may have been changed.
To check this right click on "My Computer" & select "Manage" (4th one down), at the bottom of the list you will see "Services & Applications" - if you click on the + next to it you will see some more options, 1 of which is services.
Click on services & the right hand pain will list all services installed on your machine, it should be in alphabetical order so work down to the "P's" & find "Print Spooler", under startup type it should say automatic if it says anything like Manual or Disabled just double click it & on the window that appears change the setting to automatic using the dropdown box, click on start to start the service & you should be flying!
Let me know how you get on.
Nov 03, 2008 | Canon PIXMA MP210 Photo All-In-One Printer
Bestbuy software on acer computer
did they give you program disks like windows i would do a reform. on comp cause i dont trust content on floor models (open box comps) make sure you have key codes handy
May 08, 2008 | Computers & Internet
HP print spooler problem and error 1068. Want my printer back!!!
There are several ways to resolve printer spooler error, probably because there are many variations of this error. The error caused by faulty software can be resolved by deleting all the information found in the directory. Thereafter, navigate to the Control Panel, click on Administrative Tools and then services icon. Find the service labeled Print Spooler, highlight it and restart the process. If that doesn’t work, the program might be corrupted. Click on start, then Run. Search for the document labeled services.msc, and this will trigger the opening of another window. On this window, scroll down and click “Print Spooler”. Check its setting and turn on automatic mode. Click Okay, and restart the machine. If you’re lucky, this might be all you have to do. Still doesn’t work? Navigate to the Add/Remove Programs screen of the Control Panel. Find the all the software responsible for making the printer run including the drivers, and uninstall them. Be sure to be thorough about it, or the problem may not be solved. Download the latest copy of your printer’s software from the manufacturer and reinstall it. get more information for printer spooler error .Hope this helps you.
Mar 03, 2008 | HP OfficeJet 4255 All-In-One InkJet...
Print Spooler Problem
Click on start
click on run
Type services.msc
A box will open up
Make sure all items below are set to automactic
To make the changes double click on each item
change to automatic if diabled. Then click apply when you are done.
Restart the computer and try testing your printer again.
Printer Spooler
LexBce Server
Remote Procedure CallRPC)
Hope this solves your problem
Oct 20, 2007 | HP DeskJet 670c InkJet Printer
HP PSC 1610v All-in-One Printer Logo
22 people viewed this question
Ben Johnson
