Question about Goodman Manufacturing Heating & Cooling
Where is reset button on R-410A split system heat pump
    New Friend:
    Problem Solver:
  • 15 Answers
No reset, high and low pressure switches are auto resetting.
Posted on Oct 12, 2016
mrgrzz
  • 88 Answers
SOURCE: New 14 seer split ruud heat pump makes very loud knocking noise
Well you may want to have a tech come out and check the freon level, but mostly when going into defrost, some units make alot of noise, the freon is reversed in the unit by way of the reversing valve, it makes a whooshing sound like freon is draining off, as far as the knocking noise, could be as I said in the beginning, might be low on freon, but it could be that, this particular unit does this, I have had units make some really strange noises in the past but functioned perfectly, hope this helped, please let us know, thanks again,
mr.grzz
Posted on Jan 24, 2009
relaga58
  • 158 Answers
SOURCE: mitsubishi 3.5 split systme fault
green light flashing means there was a fault that occurred now it could be power failure which you can try to reset by turning off and on circuit breaker it might reset itself if not there is much bigger problem which need technician
Posted on May 10, 2009
james3751
  • 614 Answers
SOURCE: where can i get a pump-down valve for an
Any air conditioning parts warehouse or order on line just type in ac parts. you need 3/8 inch solenoid vavle 24 volts. sight glasses dont help much in domestic ac. Rus
Posted on Jul 15, 2009
Therinnaiguy
  • 1420 Answers
SOURCE: i have installed a new split system. 410a i have
Either there is not enough air flow thru the coil or the charge is wrong. Is there a TXV on the system? If not, put one on.
Posted on Apr 06, 2010
hvac1
  • 338 Answers
SOURCE: Fedder Heat Pump not Running
you can check your heat pump on the outside by turning off the power and listening to see if it makes a whoosh sound. and then turn it back on you should hear it kick in. Is the outside unit running? Sounds like an electrical problem maybe in the breaker or the contactor on the inside of the unit. This is where the 24 volts from the thermostat call to the 240 volts to kick on the condenser fan and compressor. Be real careful in messing with this because of the high voltage.
Posted on Jul 09, 2010
Tip
R-410A or r410a Why This Refrigerant is Better
One of the best benefits of R-410A refrigerant is its exceptionally quiet operation. Other key benefits of R-410A and the air conditioning systems that use it are higher EER (Energy Efficiency Ratio) better heat-pump performance, increased efficiency and reliability. There is also no ozone-depleting chemicals. R410A has the lowest Global Warming TEWI (Total Equivalent Warming Impact). Probably the most important benefit of R-410A is that it will still be available long after the production of R-22 units is stopped in 2010. Although contractors are still using the lower pricing of R-22 equipment as a selling point when talking to their customers, many smart ones are now also selling the environmental benefits of R-410A.They are also selling the benefits of the new technology and the improved comfort level of the new R-410A equipment.
There are many efficiency and economical benefits to R-410A. It has become very important for techs to inform their customers of the many benefits of R-410A products. Some of the benefits of R-410A are low energy consumption, increased product performance, no ozone depleting chemicals (no chlorine), and improved product reliability. The new products that use R-410A are state of the art technology, feature enhanced heat pump and air conditioning performance and meet the clean air act requirements for 2010.
For many years most air conditioners and heat pumps sold around the world used a refrigerant called R-22. Homeowners and business owners now have the ability to ask for an air conditioner or heat pump that uses the more efficient and environmentally friendlier refrigerant called R-410A. When you buy a new air conditioning or heat pump system by selecting R-410A you virtually eliminate the possibility that refrigerant leaking from your system could contribute to the hole in the ozone layer. You will also be investing in a new comfort system that will last you for many years to come. This is because R-410A (a chlorine-free refrigerant) complies with governmental legislation to phase out ozone-depleting refrigerants well ahead of the 2010 deadline. Another thing to consider is that the costs of R-22 will begin to rapidly rise when the production of R-22 units are phased out by January 1, 2010. Because of this there will be less R-22 refrigerant produced.
One of the greatest benefits of R-410A is that it will still be available for a long after the production of R-22 units ceases in 2010. If you are installing an air conditioner or heat pump in the near future, make sure that you specify that the unit uses R-410A refrigerant.
Do not allow the installation of a R-22 unit even if the pricing is much lower. The future costs of a repair to the unit will more than offset the savings now.
http://www.fixya.com/support/r3636724-r_410a_new_refrigerant_air_conditioning
on Jan 10, 2010 | Heating & Cooling
The outside unit leds have a 29 code, before it goes into shutdown. Outside is a LAU180HSV Invertor V Split System. Installed in 2012.
That code means that the compressor is drawing too much current when it is trying to start. It is highly unlikely that the main board is bad.
May 04, 2016 | LG Art Cool LA180HSV 18,200 BTU SingZone...
The control card is displaying error ch-01
PDF]SERVICE MANUAL R?410A Ductless Split System Air ...
dms.hvacpartners.com/docs/1011/Public/.../42108920400_ICP_26610.p...
421 01 9204 00 1/03/13. SERVICE MANUAL ... Consult local building codes and National Electrical Code. (NEC) for special ..... 18000 (5970-22350). Heating Capacity (Min. - Max). Btu/h. N/A ..... Error Messages Displayed Front Panel. S.
Oct 08, 2015 | LG 18000 BTU Dual Zone Mini-Split Heat...
Heat pump runs on electric when outside temperature is higher than cutin
Check your thermostat and heat pump owner's manuals. Thermostat may be programmed to require electric heat at higher temps. Also could be bad outdoor temperature sensor tied to
Heat pump system controls (I had that problem) When was it installed? Warranty thermostat and or Heat pump? Call installer
Thermostat programming is a headache. No help from installer? call customer service heat pump and thermostat. Some possibility of bad installer wiring. There is also a heat pump "defrost" cycle. Usually the Electric coil will turn on to compensate for the Defrost cycle which is just the standard air conditioning mode therefore moves heat from inside to the outside coil to melt the frost. This cycle may be occurring too often. I had that problem. Fixed under warrantee.
Heat pumps are complex machines. The controls even more.
You need a tech, hopfully you are still under warranty.
Hope this helps.
Feb 27, 2015 | Payne 15 SEER R-410A Complete Split System...
Hookup thrmastate to conderser
yellow off of the thermostat, & common wire from the transformer in the furnace
Jul 27, 2014 | Rheem R-410A Complete Split System Heat...
Fujitsu 18000 goes into defrost once an hour at 28to 32 degrees outside temp. trying to maintain 70 degrees inside . test run was ok on start up. just installed 3 days ago .. vacuum out the lines. lost...
what is the lowest outside temp manufacturer suggests? Heat pumps are not very good when it gets good and cold... call the installers and see what they have to say for you.
Feb 21, 2010 | GE Quiet-Aire Ductless Heat Pump Split...
Heating & Cooling Logo
109 people viewed this question
Top Goodman Manufacturing Heating & Cooling Experts
Robbie Daniels
Level 1 Expert
zephyrusd
Level 1 Expert
snowmanii
Are you a Goodman Manufacturing Heating and Cooling Expert? Answer questions, earn points and help others
